Hi Trumany,
I have another question, I saw the P2822 schematic, the UART1_CTS is conneting on the level shift, when it is input pin, it can change the value by VCC/GND.
What is the different between pin11 and pin36??
Hi Trumany,
Pin 36 is set to input only by same level shift.
Hi Trumany,
I set the Pin 36 to input, but Pin 36 couold be changed its value by VCC/GND
This is my step:
I dont get what you mean… pin 36 can be as input only, do you mean you can’t get the correct value on it by connecting it to high or low?
Hi Trumany,
I am sorry that I got a mistake, so Pin11 only can be output and Pin36 only can be the input, Do I have the ability to modify the state? If Yes, how to change?
No, you can’t change that on devkit as there is a level shift that limit pins direction.
