Jetson AGX Xavier UFS Connections issue
Why UFS Design Guidelines can not match with Carrier_Board_Design_Files_B03(P2822_B03_OrCAD_schematics)? Can you help me to confirm whether the connections of this UFS flash is correct?
  1. Jetson_AGX_Xavier_Series_OEM_Product_Design_Guide_DG-09840-001_v2.6
    Figure 7-7. UFS Connections Example
    ---- UPHY_TX10_N is connect to UFS Device DIN0_T, UPHY_TX10_P is connect to UFS Device DIN0_C.
    ---- UPHY_RX10_N is connect to UFS Device DOUT0_T, UPHY_RX10_P is connect to UFS Device DOUT0_C.
  2. Jetson_Xavier_Developer_Kit_Carrier_Board_Design_Files_B03(P2822_B03_OrCAD_schematics)
    ---- UPHY_TX10_N is connect to UFS Device DIN0_C, UPHY_TX10_P is connect to UFS Device DIN0_T.
    ---- UPHY_RX10_N is connect to UFS Device DOUT0_C, UPHY_RX10_P is connect to UFS Device DOUT0_T.
  3. JEDEC standards
    ---- DIN_t is the positive node of the differential signal. DOUT_t is the positive node of the differential signal.
Hi, please follow the carrier board schematic. The DG will be changed, thanks for the finding.
