Hi All,
The minimum memory requirement for Jetson Benchmark is how much?
I can get result from Orin NX 8G but I got 0fps and “Error opening engine file” in Orin Nano 4G. I also saw the low memory warning.
Is the memory status normal?
Which command are you using for running on the Orin Nano?
Based on your log, there is still some memory available in your environment.
Could you share the complete log with us?
My step about execute jetson_benchmark:
$ sudo apt install nvidia-jetpack
$ sudo unzip jetson_benchmarks.zip
$ cd jetson_benchmarks
$ sudo sh install_requirements.sh
$ sudo mkdir models
$ sudo python3 utils/download_models.py --all --csv_file_path benchmark_csv/orin-nano-benchmarks.csv --save_dir models
$ sudo python3 benchmark.py --all --csv_file_path benchmark_csv/orin-nano-benchmarks.csv --model_dir $PWD/models/ --jetson_clocks
And i got result:
Model Name FPS
0 inception_v4 0.000000
1 vgg19_N2 0.000000
2 super_resolution_bsd500 0.000000
3 unet-segmentation 0.000000
4 pose_estimation 0.000000
5 yolov3-tiny-416 0.000000
6 ResNet50_224x224 0.000000
7 mobilenet_v1_ssd 1154.754585
8 ssd_resnet34_1200x1200 0.000000
inception_v4 log:
inception_v4_b32_ws2048_gpu.txt (4.9 KB)
vgg19_N2 log:
vgg19_N2_b64_ws2048_gpu.txt (4.9 KB)
super_resolution_bsd500 log:
super_resolution_bsd500_b8_ws2048_gpu.txt (5.1 KB)
unet-segmentation log:
unet-segmentation_b32_ws2048_gpu.txt (5.0 KB)
pose_estimation log:
pose_estimation_b64_ws2048_gpu.txt (4.9 KB)
yolov3-tiny-416 log:
yolov3-tiny-416_b32_ws2048_gpu.txt (5.0 KB)
ResNet50_224x224 log:
ResNet50_224x224_b32_ws2048_gpu.txt (4.9 KB)
ssd_resnet34_1200x1200 log:
ssd_resnet34_1200x1200_b1_ws2048_gpu.txt (5.0 KB)
dmesg:
dmesg.txt (136.0 KB)
Thanks for your testing.
We are checking with our internal team.
Will update more info with you later.
Thanks for your patience. We expect the jetson_benchmarks to work on Orin Nano.
From your log files, it seems like the models are saved in a directory named models but the path specified in the command is looking for models in a directory named modules.
Could you please try again after changing the last 2 commands to:
Please ensure that $PWD/models/ correctly points to where the downloaded models are located.
Sorry for confusing. The log files is the second time test,and the second time test use “modules” to save benchmark models. In fact, the command i used matches the save models path.
test with:
I also tried using GitHub - JetsonHacksNano/installSwapfile: Install a swap file on the NVIDIA Jetson Nano Developer Kit. This should help with memory pressure issues.. It seems slightly improved.
Result:
0 inception_v4 183.265680
1 vgg19_N2 0.000000
5 yolov3-tiny-416 389.784717
6 ResNet50_224x224 634.665598
7 mobilenet_v1_ssd 1156.875674
8 ssd_resnet34_1200x1200 17.787978
log:
Thanks for the feedback.
We need to discuss this with our internal team.
Will get back to you later.
Hi @AastaLLL ,
Are there any updates about the issue?
Our internal team is still checking on this.
Will get back to you once we get a response.
Please give the attached CSV file a try.
orin-nano-4gb-benchmarks.csv (1.3 KB)
It mainly modifies the batch size for the non-working model.
So you can also modify it based on your environment status.
Thank you for your suggestion.
I have tried the attchment.
below is the score :
Model Name FPS
0 inception_v4 113.736908
1 vgg19_N2 95.358279
2 super_resolution_bsd500 101.997273
3 unet-segmentation 69.097159
4 pose_estimation 221.999593
5 yolov3-tiny-416 322.847119
6 ResNet50_224x224 327.531229
7 mobilenet_v1_ssd 1048.020436
8 ssd_resnet34_1200x1200 17.603146
That can solve my issue but I observed that the result is much lower than the standard score. Is there are any suggestions that can improve it?
Did you run the test in the below environment?
https://developer.nvidia.com/embedded/jetson-benchmarks
Could you reboot the system and try the benchmark again?
Please don’t enable any disk-based swap memory since the access time is relatively longer.
I tried remove the additional swap size,and try the benchmark again with orin-nano-4gb-benchmarks.csv .
Model Name FPS
1 vgg19_N2 0.000000
2 super_resolution_bsd500 102.007965
3 unet-segmentation 68.727215
4 pose_estimation 220.685477
5 yolov3-tiny-416 323.757111
7 mobilenet_v1_ssd 1054.882615
8 ssd_resnet34_1200x1200 17.517354
Some process have been killed,cause by not enough memory.
dmesg as below:
benchmarkDmesg.txt (136.2 KB)
Thanks for testing.
We need to check with our internal team.
Will get back to you soon.
Please adjust the batch size to get the best performance.
For example, the best batch size Inception_v4 is 32.
Is it normal to get 0 fps for Orin Nano 4GB?
I know 32 batch size can get the best performance but now even set batch size to 1, it still got 0 fps after I remove extra swapsize.
Can you help me to check what is the expected normal performance for Orin Nano 4GB?
Please ignore the disable swap suggestion.
Just try it as the way you tried with the attached csv.
Below is the batch size and fps we got with Orin Nano 4GB.
