Run inference with model exported by Jetson Orin Nano 8GB on Jetson Orin Nano 4GB
Description
I have exported custom trained YOLO (.pt) model to tensorrt engine (.engine) using yolov5 export.py on my Jetson Orin Nano (8GB). Exporting utilize the major part of memory, so I can not do the same exportation on the Jetson Orin Nano 4GB, is there a way to use model for inference exported by Jetson Orin Nano (8GB) on the Jetson Orin Nano (4GB)?
Model Details
PyTorch: starting from custom.pt with output shape (32, 7056, 9) (659.0 MB)
ONNX: 329 MB
TensorRT: input “images” with shape(32, 3, 256, 448) DataType.FLOAT
TensorRT: output “output0” with shape(32, 7056, 9) DataType.FLOAT
TensorRT: building FP32 engine as custom.engine
We are moving this post to the Jetson Orin Nano forum to get better help.
Thank you.
The TensorRT engine doesn’t support portability.
So you will need to create the engine directly on the Orin Nano 4GB.
Have you tried to generate the engine on Orin Nano 4GB?
Any error message is shown?
Thanks for your reply.
Parameters are:
weights=“custom.pt”,
include=(“engine”,),
device=torch.cuda.current_device(),
batch_size=32,
imgsz=(256, 448),
conf_thres=0.5,
iou_thres=0.3
Here is error message:
[07/21/2023-11:44:22] [TRT] [W] Tactic Device request: 560MB Available: 328MB. Device memory is insufficient to use tactic.
[07/21/2023-11:44:22] [TRT] [W] Skipping tactic 25 due to insufficient memory on requested size of 560 detected for tactic 0x000000000000001d.
[07/21/2023-11:44:22] [TRT] [W] Skipping tactic 26 due to insufficient memory on requested size of 560 detected for tactic 0x000000000000001e.
[07/21/2023-11:44:23] [TRT] [E] 10: [optimizer.cpp::computeCosts::3728] Error Code 10: Internal Error (Could not find any implementation for node PWN(PWN(/model.0/act/Sigmoid), /model.0/act/Mul).)
TensorRT: export failure ❌ 256.3s: __enter__
Sorry for the late update.
Based on the error log, the TensorRT optimizer cannot find a suitable implementation within the limited memory resources.
It seems that you set the batch size to 32.
Would you mind lower the value and try it again?
