jetson_clocks.sh script
Hi!
I have jetson_clocks script in place and what to let TX2 to run at top processing speed. During testing, I found for most TX2, it can reach top speed in 90 seconds as promised, after running jetson_clocks. But for few it takes 3-5 minutes to reach top speed. does anyone know what factor can lead to jetson_clocks.sh to delay?
Thank you very very much!
Chenxuan Cui
How do you know tegra processor is on “top speed”?
sudo ./jetson_clocks --show
Did you run “sudo nvpmodel -m 0” prior to the show? FYI, jetson_clocks.sh only sets the max speed for the current performance model. Unless you first went to the max performance model (the “-m 0” model), then you might be maxed out for a model intended for some sort of energy savings.
chenxuan,
So you found one device need to take 3~5 min to reach top cpu/gpu frequency?
Doe it affect any of your app’s performance?
