Jetson device (NVIDIA AGX ORIN 64G DevKit or SEEED Studio ORIN NX 32G DevKit) throttles when running deep learning inference using ultralytics yolov10
TLDR: System trottled due to overcurrent but current temp is way below threshold for system trottle or shutdown.
I would like to know why I get this message? I used jetson_clock command once. After I got this message, and saw the temperature, I turned off the device and disconnected the camera. This is of concern since the device is not that cheap (@2k$) and more concerning if on a demo day the device breaks or burns.
Could you please advice what to do?
As you see in the image below in the top right corner, MAXN becomes red while typically it is green.
When converting the model to engine I used the default params which is fp32. When it converts to engine, it first creates an onnx file.
Please let me know if more details may be necessary.
Sys info for NVIDIA AGX ORIN 6G DevKit:
mona@ubuntu:~$ cat /etc/nv_tegra_release
# R36 (release), REVISION: 3.0, GCID: 36923193, BOARD: generic, EABI: aarch64, DATE: Fri Jul 19 23:24:25 UTC 2024
# KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
mona@ubuntu:~$ uname -a
Linux ubuntu 5.15.136-tegra #1 SMP PREEMPT Mon May 6 09:56:39 PDT 2024 aarch64 aarch64 aarch64 GNU/Linux
mona@ubuntu:~$ lsb_release -a
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Ubuntu 22.04.4 LTS
Release:	22.04
Codename:	jammy
There are 3 types of OC events in the Orin series: Under Voltage, Average Overcurrent, and Instantaneous Overcurrent.
The GPU and CPU usage of the snapshot is pretty low.
Do you capture the figure when the throttling alarm is reported?
Right after I saw the throttle warning (it was still active)
Would you mind sharing the screenshot (or recording) before/after the throttling alarm?
This helps us know more about the behavior.
