Hi. Have a question about Jetson`s SDK. Is it possible to connect to the controller via ethernet several IP cameras, sensors (like GPS), make some work with metada in video and start stream updated video in network? Also i want to set some settings on connected cameras.
anton109
1
kayccc
2
Hi anton109.
That should be no problem to do, you can find more interesting use case at Jetson Projects - NVIDIA Developer Forums
anton109
3
thanks!
Related topics
| Jetson TX2 unable to access GigE camera over PCIe ethernet expansion board | 10 | 1701 | October 18, 2021 | |
| How to Interface a IP Camera? | 3 | 3507 | January 30, 2019 | |
| Jetson from ethernet to SDI and vice versa | 2 | 404 | October 18, 2021 | |
| Jetson TX2-usb camera streaming-seek shot pro | 13 | 1028 | October 18, 2021 | |
| Multiple camera setup Jetson Nano | 2 | 687 | October 12, 2021 | |
| Can i try connect and transtfer data on jetson-PoE switch ? | 2 | 649 | August 3, 2018 | |
| Connect several cameras to Jetson TX2 wirelessly | 1 | 611 | November 13, 2019 | |
| Jetson Telescope Mount Controller with Video Capturing and Processing | 12 | 2796 | October 18, 2021 | |
| Raspberry Pi camera and Jetson TX2 | 11 | 1513 | October 18, 2021 | |
| How to Interface a IP Camera? | 12 | 3919 | October 18, 2021 |
