Hi @mi_k, you might want to check out this thread:
or you can build jetson-inference source outside of container and use GPIO without docker.
| Jetson.GPIO not working on Python inside the container | 3 | 4200 | June 15, 2021 | |
| Jetson Inference Jetson.GPIO does not work | 4 | 1303 | August 18, 2021 | |
| Using GPIO from within a docker container | 20 | 9987 | April 28, 2021 | |
| Unable to import Jetson.GPIO Module in Docker Environment | 1 | 1438 | February 25, 2022 | |
| Jetson GPIO inside docker container | 3 | 750 | October 19, 2023 | |
| Accessing GPIO from a Noetic Container Error | 4 | 599 | April 10, 2024 | |
| How to get Jetson.GPIO visible from within a container | 2 | 1068 | January 6, 2021 | |
| Why I Can't Use Pin GPIO When I Run SSD Mobilenetv2 in Docker/run.sh | 1 | 532 | June 12, 2023 | |
| Using servos, stepper motors in jetson-inference | 4 | 2014 | July 23, 2021 | |
| GPIO Permission error through Docker | 8 | 1497 | November 28, 2023 |
