I’m wanting to change the colors of each keypoint detected by the posenet model individually. I looked at the c++ source code and there appears to be a command to do this.
To my knowledge, the python command binding doesn’t pass this command through. There is a python command to change the opacity and I’ve been playing around with this command to test the concept out.
It works when I change every keypoints’ opacity, but causes an error when I try to change just one keypoint’s opacity.
My code is based on an example provided in the jetson-inference repository…
#!/usr/bin/python3
# Copyright (c) 2021, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
import jetson.inference
import jetson.utils
import argparse
import sys
# parse the command line
parser = argparse.ArgumentParser(description="Run pose estimation DNN on a video/image stream.",
formatter_class=argparse.RawTextHelpFormatter, epilog=jetson.inference.poseNet.Usage() +
jetson.utils.videoSource.Usage() + jetson.utils.videoOutput.Usage() + jetson.utils.logUsage())
parser.add_argument("input_URI", type=str, default="", nargs='?', help="URI of the input stream")
parser.add_argument("output_URI", type=str, default="", nargs='?', help="URI of the output stream")
parser.add_argument("--network", type=str, default="resnet18-body", help="pre-trained model to load (see below for options)")
parser.add_argument("--overlay", type=str, default="links,keypoints", help="pose overlay flags (e.g. --overlay=links,keypoints)\nvalid combinations are: 'links', 'keypoints', 'boxes', 'none'")
parser.add_argument("--threshold", type=float, default=0.15, help="minimum detection threshold to use")
try:
opt = parser.parse_known_args()[0]
except:
print("")
parser.print_help()
sys.exit(0)
# load the pose estimation model
net = jetson.inference.poseNet(opt.network, sys.argv, opt.threshold)
# create video sources & outputs
input = jetson.utils.videoSource(opt.input_URI, argv=sys.argv)
output = jetson.utils.videoOutput(opt.output_URI, argv=sys.argv)
# process frames until the user exits
while True:
# capture the next image
img = input.Capture()
# perform pose estimation (with overlay)
poses = net.Process(img, overlay=opt.overlay)
# print the pose results
# print("detected {:d} objects in image".format(len(poses)))
# [TRT] poseNet -- keypoint 00 'nose' color 0 255 0 255
# [TRT] poseNet -- keypoint 01 'left_eye' color 0 255 0 255
# [TRT] poseNet -- keypoint 02 'right_eye' color 0 255 0 255
# [TRT] poseNet -- keypoint 03 'left_ear' color 0 255 0 255
# [TRT] poseNet -- keypoint 04 'right_ear' color 0 255 0 255
# [TRT] poseNet -- keypoint 05 'left_shoulder' color 0 255 0 255
# [TRT] poseNet -- keypoint 06 'right_shoulder' color 0 255 0 255
# [TRT] poseNet -- keypoint 07 'left_elbow' color 0 255 0 255
# [TRT] poseNet -- keypoint 08 'right_elbow' color 0 255 0 255
# [TRT] poseNet -- keypoint 09 'left_wrist' color 0 255 0 255
# [TRT] poseNet -- keypoint 10 'right_wrist' color 0 255 0 255
# [TRT] poseNet -- keypoint 11 'left_hip' color 0 255 0 255
# [TRT] poseNet -- keypoint 12 'right_hip' color 0 255 0 255
# [TRT] poseNet -- keypoint 13 'left_knee' color 0 255 0 255
# [TRT] poseNet -- keypoint 14 'right_knee' color 0 255 0 255
# [TRT] poseNet -- keypoint 15 'left_ankle' color 0 255 0 255
# [TRT] poseNet -- keypoint 16 'right_ankle' color 0 255 0 255
# [TRT] poseNet -- keypoint 17 'neck' color 0 255 0 255
# [TRT] poseNet -- loaded 18 class colors
# index 6 is right shoulder
# Code below causes error
# net.SetKeypointAlpha(alpha=20.0,keypoint=6)
for pose in poses:
print(pose)
print(pose.Keypoints)
print(net.GetNumKeypoints())
print('Links', pose.Links)
# render the image
output.Render(img)
# update the title bar
output.SetStatus("{:s} | Network {:.0f} FPS".format(opt.network, net.GetNetworkFPS()))
# print out performance info
# net.PrintProfilerTimes()
# exit on input/output EOS
if not input.IsStreaming() or not output.IsStreaming():
break
I’m currently going to try to recode the example in c++ and see if that works. Any advise is appreciated.
