Is there a way to ignore or hide the return messages after running a Python script? I’m talking about the code shown below. They just look like very scary error messages and I don’t want to see them! They are not pertinent to my python code which I am finding a target in the frame, calculates stepper motor values to move the device and relays it to the Arduino, but I feel like it’s a lot of garbage that I don’t need to see half the time.
detectNet – loading detection network model from:
– model networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff
– input_blob ‘Input’
– output_blob ‘NMS’
– output_count ‘NMS_1’
– class_labels networks/SSD-Mobilenet-v2/ssd_coco_labels.txt
– threshold 0.500000
– batch_size 1
[TRT] TensorRT version 7.1.3
[TRT] loading NVIDIA plugins…
[TRT] Registered plugin creator - ::GridAnchor_TRT version 1
[TRT] Registered plugin creator - ::NMS_TRT version 1
[TRT] Registered plugin creator - ::Reorg_TRT version 1
[TRT] Registered plugin creator - ::Region_TRT version 1
[TRT] Registered plugin creator - ::Clip_TRT version 1
[TRT] Registered plugin creator - ::LReLU_TRT version 1
[TRT] Registered plugin creator - ::PriorBox_TRT version 1
[TRT] Registered plugin creator - ::Normalize_TRT version 1
[TRT] Registered plugin creator - ::RPROI_TRT version 1
[TRT] Registered plugin creator - ::BatchedNMS_TRT version 1
[TRT] Could not register plugin creator - ::FlattenConcat_TRT version 1
[TRT] Registered plugin creator - ::CropAndResize version 1
[TRT] Registered plugin creator - ::DetectionLayer_TRT version 1
[TRT] Registered plugin creator - ::Proposal version 1
[TRT] Registered plugin creator - ::ProposalLayer_TRT version 1
[TRT] Registered plugin creator - ::PyramidROIAlign_TRT version 1
[TRT] Registered plugin creator - ::ResizeNearest_TRT version 1
[TRT] Registered plugin creator - ::Split version 1
[TRT] Registered plugin creator - ::SpecialSlice_TRT version 1
[TRT] Registered plugin creator - ::InstanceNormalization_TRT version 1
[TRT] detected model format - UFF (extension ‘.uff’)
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] native precisions detected for GPU: FP32, FP16
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff.1.1.7103.GPU.FP16.engine
[TRT] loading network plan from engine cache… /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff.1.1.7103.GPU.FP16.engine
[TRT] device GPU, loaded /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff
[TRT] Deserialize required 3018144 microseconds.
[TRT]
[TRT] CUDA engine context initialized on device GPU:
[TRT] – layers 117
[TRT] – maxBatchSize 1
[TRT] – workspace 0
[TRT] – deviceMemory 35449856
[TRT] – bindings 3
[TRT] binding 0
– index 0
– name ‘Input’
– type FP32
– in/out INPUT
– # dims 3
– dim #0 3 (SPATIAL)
– dim #1 300 (SPATIAL)
– dim #2 300 (SPATIAL)
[TRT] binding 1
– index 1
– name ‘NMS’
– type FP32
– in/out OUTPUT
– # dims 3
– dim #0 1 (SPATIAL)
– dim #1 100 (SPATIAL)
– dim #2 7 (SPATIAL)
[TRT] binding 2
– index 2
– name ‘NMS_1’
– type FP32
– in/out OUTPUT
– # dims 3
– dim #1 1 (SPATIAL)
– dim #2 1 (SPATIAL)
[TRT]
[TRT] binding to input 0 Input binding index: 0
[TRT] binding to input 0 Input dims (b=1 c=3 h=300 w=300) size=1080000
[TRT] binding to output 0 NMS binding index: 1
[TRT] binding to output 0 NMS dims (b=1 c=1 h=100 w=7) size=2800
[TRT] binding to output 1 NMS_1 binding index: 2
[TRT] binding to output 1 NMS_1 dims (b=1 c=1 h=1 w=1) size=4
[TRT]
[TRT] device GPU, /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff initialized.
[TRT] W = 7 H = 100 C = 1
[TRT] detectNet – maximum bounding boxes: 100
[TRT] detectNet – loaded 91 class info entries
[TRT] detectNet – number of object classes: 91
[gstreamer] initialized gstreamer, version 1.14.5.0
[gstreamer] gstCamera – attempting to create device v4l2:///dev/video0
[gstreamer] gstCamera – found v4l2 device: HD 1080P PC-Camera
[gstreamer] v4l2-proplist, device.path=(string)/dev/video0, udev-probed=(boolean)false, device.api=(string)v4l2, v4l2.device.driver=(string)uvcvideo, v4l2.device.card=(string)“HD\ 1080P\ \ PC-Camera”, v4l2.device.bus_info=(string)usb-70090000.xusb-2.4, v4l2.device.version=(uint)264649, v4l2.device.capabilities=(uint)2216689665, v4l2.device.device_caps=(uint)69206017;
[gstreamer] gstCamera – found 22 caps for v4l2 device /dev/video0
[gstreamer] [0] video/x-raw, format=(string)YUY2, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)5/1;
[gstreamer] [1] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)10/1;
[gstreamer] [2] video/x-raw, format=(string)YUY2, width=(int)1024, height=(int)768, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)10/1;
[gstreamer] [3] video/x-raw, format=(string)YUY2, width=(int)1024, height=(int)576, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)10/1;
[gstreamer] [4] video/x-raw, format=(string)YUY2, width=(int)960, height=(int)544, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)10/1;
[gstreamer] [5] video/x-raw, format=(string)YUY2, width=(int)800, height=(int)600, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)10/1;
[gstreamer] [6] video/x-raw, format=(string)YUY2, width=(int)800, height=(int)448, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)10/1;
[gstreamer] [7] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [8] video/x-raw, format=(string)YUY2, width=(int)352, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [9] video/x-raw, format=(string)YUY2, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [10] image/jpeg, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [11] image/jpeg, width=(int)1600, height=(int)1200, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [12] image/jpeg, width=(int)1600, height=(int)896, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [13] image/jpeg, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [14] image/jpeg, width=(int)1024, height=(int)768, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [15] image/jpeg, width=(int)1024, height=(int)576, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [16] image/jpeg, width=(int)960, height=(int)544, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [17] image/jpeg, width=(int)800, height=(int)600, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [18] image/jpeg, width=(int)800, height=(int)448, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [19] image/jpeg, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [20] image/jpeg, width=(int)352, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [21] image/jpeg, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] gstCamera – selected device profile: codec=mjpeg format=unknown width=1280 height=720
[gstreamer] gstCamera pipeline string:
[gstreamer] v4l2src device=/dev/video0 ! image/jpeg, width=(int)1280, height=(int)720 ! jpegdec ! video/x-raw ! appsink name=mysink
[gstreamer] gstCamera successfully created device v4l2:///dev/video0
[OpenGL] glDisplay – X screen 0 resolution: 1920x1080
[OpenGL] glDisplay – X window resolution: 1920x1080
[OpenGL] glDisplay – display device initialized (1920x1080)
[video] created glDisplay from display://0
Now working in webcam object detection mode.
Target is: Person
Running. Press ‘Q’ to exit.
Arduino found! /dev/ttyACM0 connected!
[gstreamer] opening gstCamera for streaming, transitioning pipeline to GST_STATE_PLAYING
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter1
[gstreamer] gstreamer changed state from NULL to READY ==> jpegdec0
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter0
[gstreamer] gstreamer changed state from NULL to READY ==> v4l2src0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter1
[gstreamer] gstreamer changed state from READY to PAUSED ==> jpegdec0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter0
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> v4l2src0
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer message new-clock ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> jpegdec0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> v4l2src0
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer message stream-start ==> pipeline0
[gstreamer] gstCamera – onPreroll
[gstreamer] gstCamera – map buffer size was less than max size (1382400 vs 1382407)
[gstreamer] gstCamera recieve caps: video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)1:4:0:0, framerate=(fraction)30/1
[gstreamer] gstCamera – recieved first frame, codec=mjpeg format=i420 width=1280 height=720 size=1382407
RingBuffer – allocated 4 buffers (1382407 bytes each, 5529628 bytes total)
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
[gstreamer] gstreamer message async-done ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> mysink
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> pipeline0
RingBuffer – allocated 4 buffers (14745600 bytes each, 58982400 bytes total)
