Hi!
I was able to run every project of this tutorial: GitHub - dusty-nv/jetson-inference: Hello AI World guide to deploying deep-learning inference networks and deep vision primitives with TensorRT and NVIDIA Jetson.
This week I had to reflash my JetsonTX2. I followed this guide step by step: jetson-inference/building-repo-2.md at master · dusty-nv/jetson-inference · GitHub
I got an error at “make” step:
/usr/bin/ld: cannot find -lGL
collect2: error: ld returned 1 exit status
utils/CMakeFiles/jetson-utils.dir/build.make:4801: recipe for target ‘aarch64/lib/libjetson-utils.so’ failed
make[2]: *** [aarch64/lib/libjetson-utils.so] Error 1
CMakeFiles/Makefile2:713: recipe for target ‘utils/CMakeFiles/jetson-utils.dir/all’ failed
make[1]: *** [utils/CMakeFiles/jetson-utils.dir/all] Error 2
Makefile:129: recipe for target ‘all’ failed
make: *** [all] Error 2
Please help me how to solve the problem. Thank you!
Hi @anon40263254, can you run this ls command below and let me know what the output looks like for you?
$ ls -ll /usr/lib/aarch64-linux-gnu/libGL.so*
lrwxrwxrwx 1 root root 14 May 10 2019 /usr/lib/aarch64-linux-gnu/libGL.so -> libGL.so.1.0.0
lrwxrwxrwx 1 root root 14 May 10 2019 /usr/lib/aarch64-linux-gnu/libGL.so.1 -> libGL.so.1.0.0
-rw-r--r-- 1 root root 972968 May 10 2019 /usr/lib/aarch64-linux-gnu/libGL.so.1.0.0
Sure! My output is:
lrwxrwxrwx 1 root root 14 júl 16 11:21 /usr/lib/aarch64-linux-gnu/libGL.so → tegra/libGL.so
lrwxrwxrwx 1 root root 14 máj 10 2019 /usr/lib/aarch64-linux-gnu/libGL.so.1 → libGL.so.1.0.0
-rw-r–r-- 1 root root 972968 máj 10 2019 /usr/lib/aarch64-linux-gnu/libGL.so.1.0.0
OK, try running this:
sudo rm /usr/lib/aarch64-linux-gnu/libGL.so
sudo ln -s /usr/lib/aarch64-linux-gnu/libGL.so.1.0.0 /usr/lib/aarch64-linux-gnu/libGL.so
That should restore your libGL.so link to the correct location.
Is it possible that you were using an old copy of jetson-inference? Long ago, I recall that I used to set that symlink to tegra/libGL.so, but it has since moved so that code from the install script was removed.
