I have a Jetson NANO 2GB devkit. I want to understand how I can communicate between the CPU and GPU. I do not want to use any IDE. I want to understand what the physical medium is and protocol, and how I would address the GPU.
e.g. in some systems I might use I2C or SPI. But I have no idea where to find this detail for the Jetson NANO 2GB devkit.
Generally we call NvBufferMemSyncForCpu()/NvBufferMemSyncForDevice() to make sure the process is done on CPU or GPU. There is no direct communication between CPU and GPU.
If you run a CUDA sample, you can see similar APIs for synchronization.
