Hi.
I want to konw is cpu and gpu use the same memory in jetson?
Is it possible i use gpu without using cudamemcpy for host to dev?
On Jetson, CPU and GPU do share the same physical memory.
You can try zero-copy memory or unified memory to share buffer between CPU and GPU without copying.
Please find more details below:
