Jetson nano 4gb dev kit , MCP251x didn't enter in conf mode after reset in 4.6.1
Subject: Issue with Implementing CAN Connection on Jetson Nano 4GB with (MCP251x) using CAN SPI Click 3.3V shield.
I am facing issues while implementing a CAN connection on my Jetson Nano 4GB Developer Kit using the CAN SPI Click 3.3V shield - CAN SPI click 3.3v - Breakout board for SN65HVD230 CAN transciever .
System Details:
  • L4T Version: 32.7.1
  • JetPack Version: 4.6.1
Steps Followed:
Followed the steps from this post, just edited the oscillator value to 10 MHz to match the spi click shield from Mikro E.
Steps :
  1. Downloaded JetPack 4.6.1 image and flashed it using Balena Etcher.
  2. After setting up the system and connecting to Wi-Fi, I followed these steps:
Cloning Repository:
git clone https://github.com/Seeed-Studio/seeed-linux-dtoverlays
cd seeed-linux-dtoverlays
Creating DTS File:
  • Created a jetson-mcp251x.dts file with the following code and saved it in the seeed-linux-dtoverlays/overlays/jetsonnano directory:
/dts-v1/;
/plugin/;
#include <dt-bindings/pinctrl/pinctrl-tegra.h>
#include <dt-bindings/gpio/tegra-gpio.h>
    overlay-name = "MCP251x CAN Controller";
    compatible = "nvidia,p3449-0000-b00+p3448-0000-b00";
    fragment@0 {
        target-path = "/";
        __overlay__ {
            clocks {
                can_clock: can_clock {
                    compatible = "fixed-clock";
                    #clock-cells = <0>;
                    clock-frequency = <10000000>;
                    clock-accuracy = <100>;
    fragment@1 {
        target = <&spi0>;
        __overlay__ {
            #address-cells = <1>;
            #size-cells = <0>;
            spi@0 {
                status = "okay";
                compatible = "microchip,mcp2515";
                reg = <0x0>;
                spi-max-frequency = <10000000>;
                nvidia,enable-hw-based-cs;
                nvidia,rx-clk-tap-delay = <0x7>;
                clocks = <&can_clock>;
                interrupt-parent = <&gpio>;
                interrupts = <TEGRA_GPIO(Z, 0) 0x1>;
                controller-data {
                    nvidia,cs-setup-clk-count = <0x1e>;
                    nvidia,cs-hold-clk-count = <0x1e>;
                    nvidia,rx-clk-tap-delay = <0x1f>;
                    nvidia,tx-clk-tap-delay = <0x0>;
            spi@1 {
                status = "disabled";
    fragment@2 {
        target = <&spi1>;
        __overlay__ {
            #size-cells = <0>;
            spi@0 {
            spi@1 {
                status = "okay";
                reg = <0x0>;
                interrupts = <TEGRA_GPIO(V, 0) 0x1>;
                controller-data {
    fragment@3 {
        target = <&pinmux>;
        __overlay__ {
            pinctrl-names = "default";
            pinctrl-0 = <&jetson_io_pinmux>;
            jetson_io_pinmux: exp-header-pinmux {
                hdr40-pin19 {
                    nvidia,pins = "spi1_mosi_pc0";
                    nvidia,function = "spi1";
                    nvidia,pull = <TEGRA_PIN_PULL_DOWN>;
                    nvidia,tristate = <TEGRA_PIN_DISABLE>;
                    nvidia,enable-input = <TEGRA_PIN_ENABLE>;
                hdr40-pin21 {
                    nvidia,pins = "spi1_miso_pc1";
                hdr40-pin23 {
                    nvidia,pins = "spi1_sck_pc2";
                hdr40-pin24 {
                    nvidia,pins = "spi1_cs0_pc3";
                    nvidia,pull = <TEGRA_PIN_PULL_UP>;
                hdr40-pin37 {
                    nvidia,pins = "spi2_mosi_pb4";
                    nvidia,function = "spi2";
                hdr40-pin22 {
                    nvidia,pins = "spi2_miso_pb5";
                hdr40-pin13 {
                    nvidia,pins = "spi2_sck_pb6";
                hdr40-pin18 {
                    nvidia,pins = "spi2_cs0_pb7";
Compiling and Installing:
3. Ran make all_jetsonnano in the seeed-linux-dtoverlays directory.
4. Removed existing overlays:
sudo rm /boot/tegra210-p3448-0000-p3449-0000-a01-mcp251x.dtbo
sudo rm /boot/tegra210-p3448-0000-p3449-0000-a02-mcp251x.dtbo
  1. Created .dtbo file:
sudo make install_jetsonnano
  1. Copied the generated jetson-mcp251x.dtbo file to /boot/:
cd /seeed-linux-dtoverlays-master/overlays/jetsonnano
sudo cp jetson-mcp251x.dtbo /boot/
ls /boot/jetson-mcp251x.dtbo
  1. Applied the overlay:
fdtoverlay -i tegra210-p3448-0000-p3449-0000-b00.dtb -o tegra210-p3448-0000-p3449-0000-b00-extended.dtb jetson-mcp251x.dtbo
  1. Edited extlinux.conf:
cd /boot/extlinux
Added:
FDT /boot/tegra210-p3448-0000-p3449-0000-b00-extended.dtb
Reboot and Verify:
9. Rebooted the system:
sudo reboot
  1. Verified SPI setup with:
dmesg | grep spi
Issue:
Despite following these steps, I encounter the following errors:
[    5.210328] mcp251x spi0.0: MCP251x didn't enter in conf mode after reset
[    5.220996] mcp251x spi0.0: Probe failed, err=16
[    5.249674] mcp251x: probe of spi0.0 failed with error -16
[    6.270321] mcp251x spi1.0: MCP251x didn't enter in conf mode after reset
[    6.277363] mcp251x spi1.0: Probe failed, err=16
[    6.285015] mcp251x: probe of spi1.0 failed with error -16
I was able to establish the CAN connection following the same steps before and successfully send and receive CAN messages, but now i am stuck with this error.
please let know if there is any solution
Hi bahie3398,
Are you using the devkit or custom board for Jetson Nano?
This error seems the reset failed.
What do you mean about “before”? Is there any diff could be shared?
I am using devkit.
Yes, i was able to implement can connection through exact same steps, but the connection failed after update.
Now with even jetpack 4.6.1, the same method fails. Is there any other steps?
It may be caused from wrong connection.
Please confirm that your connection is correct and match the configuration in device tree.
What do you mean about “update”?
Have you verified it working before? If so, which is that release?
I have rechecked the connection, Anyway i am going to try it with another Mikro E can shield i have, let me know once its done.
yes, i verified with Jetpack 4.6.1.
CAN loopback test was sucessful, i was even able to send and receive can msgs in jetson nano.
We don’t have this module and not verified it before.
Please share the block diagram of your connections for further check.
