Jetson Nano Adafruit_Servokit Issue
I am trying to run the following code to use servo motor:
from adafruit_servokit import ServoKit
myKit = ServoKit(channels=16)
myKit.servo[0].angle=90
however, I am getting the following error when I run it.
File “servo.py”, line 1, in
ImportError: No module named adafruit_servokit
I had already run the following command to install adafruit_servokit
pip3 install adafruit-circuitpython-servokit==1.3.8
I’m not what the issue is because it says at the end of the command that the following was successfully installed
Successfully installed Adafruit-Blinka-6.15.0 Adafruit-PlatformDetect-3.20.1 Adafruit-PureIO-1.1.9 Jetson.GPIO-2.0.21 adafruit-circuitpython-busdevice-5.2.3 adafruit-circuitpython-motor-3.4.7 adafruit-circuitpython-pca9685-3.4.7 adafruit-circuitpython-register-1.9.15 adafruit-circuitpython-requests-1.12.12 adafruit-circuitpython-servokit-1.3.8 adafruit-circuitpython-typing-1.8.3 pyftdi-0.53.3 pyserial-3.5 pyusb-1.2.1 typing-extensions-4.1.1
Probably you’re using the wrong version of python.
You use pip3 but
$ python --version
is probably 2.7
either specify python3 or change the default with update-alternatives or other method
How to change from default to alternative Python version on Debian Linux - Linux Tutorials - Learn Linux Configuration
Using python3 does get rid of the error a new error shows up.
File “/home/capstone/.local/lib/python3.6/site-packages/adafruit_servokit.py”, line 35, in
import board
File “/home/capstone/.local/lib/python3.6/site-packages/board.py”, line 39, in
import adafruit_platformdetect.constants.boards as ap_board
File “/home/capstone/.local/lib/python3.6/site-packages/adafruit_platformdetect/init.py”, line 10, in
from .board import Board
File “/home/capstone/.local/lib/python3.6/site-packages/adafruit_platformdetect/board.py”, line 24
from future import annotations
SyntaxError: future feature annotations is not defined
try python 3.8
