I see that there are many example on object detection for Nvidia platform, so I don’t know where to start. I would to use my Jetson Nano to detect and track only person from a webcam. Could you suggest me a models? I see that with ssd-mobilenet-v2 I can get good fps. There is a way to select just person using detectnet in Jetson-inference or I need to re-train ssd-mobilenet-v1 only for person?
Yolo seems to be fast and more accurant when you compare the models. You can train you custom Yolo model. You can check this link for training custom model.
Thank you so much for fast reply :) , another question, I’m trying to crop a cudaImage from jetson-inference example (detectnet.py) to get a 360 degree image from insta360 oneX2.
This is what I get from /dev/video1:
I need to crop the image half height and then concatenate the image horizontally. Using cv2 and numpy I can do it simply but I don’t know how to do using cudaCrop. I can successfully crop a cudaImage but I don’t
know how to concatenate the 2 images horizontally. I try to convert it to NumPy and then back to cudaImage and give it to detections but I got many errors .Is there a simple way to modify the input source for detectnet.py?
