Jetson nano blank screen sudo systemctl set-default multi-user.target and sudo systemctl reboot
Jetson nano is on a blank screen and i cant do anything, i need urgent help. I tried ctrl + alt + f2 and it didnt work.
Hi yjain0102,
Are you using the devkit or custom board for Jetson Nano?
Could you share the full serial console log for further check?
Would I work if you reset the board?
