Hi, I have Jetson Nano 4gb and flashed Jetpack 4.6.3 to SD Card using sdk manager. I’m using 5V/4A power supply. Plus I’m using Nomachine and MobaXterm for headless mode.
However it stucks on NVIDIA logo but can connect via ssh.
Here is my boot log.
[ 0.439892] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 1.068315] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.574082] Host read timeout at address 545c00c4
[ 1.810827] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.810928] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.818574] imx219 7-0010: board setup failed
[ 1.823025] imx219: probe of 7-0010 failed with error -121
[ 1.846895] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.846986] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.854562] imx219 8-0010: board setup failed
[ 1.859004] imx219: probe of 8-0010 failed with error -121
[ 2.052465] Root device found: mmcblk0p1
[ 2.257394] Found dev node: /dev/mmcblk0p1
[ 2.716906] Rootfs mounted over mmcblk0p1
[ 2.737287] Switching from initrd to actual rootfs
[ 2.930761] r8168 Copyright (C) 2017 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 2.982686] cgroup: cgroup2: unknown option “nsdelegate”
[ 3.160031] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 3.160041] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 4.465205] using random self ethernet address
[ 4.493051] using random host ethernet address
[ 5.372043] using random self ethernet address
[ 5.376572] using random host ethernet address
[ 9.518670] tegra-i2c 7000c000.i2c: no acknowledge from address 0x50
[ 9.525994] tegra-i2c 7000c400.i2c: no acknowledge from address 0x50
[ 10.521961] tegra-i2c 7000c000.i2c: no acknowledge from address 0x50
[ 10.528767] tegra-i2c 7000c400.i2c: no acknowledge from address 0x50
[ 25.316480] tegra-i2c 7000c000.i2c: no acknowledge from address 0x50
[ 25.323320] tegra-i2c 7000c400.i2c: no acknowledge from address 0x50
[ 25.428132] tegra-i2c 7000c000.i2c: no acknowledge from address 0x50
[ 25.435396] tegra-i2c 7000c400.i2c: no acknowledge from address 0x50
