Here is dmesg:
valmet@valmet-desktop:~ sudo dmesg
[ 450.374347] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 450.374373] usb 1-2: USB disconnect, device number 59
[ 450.410306] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 450.674155] usb 1-2: new high-speed USB device number 60 using tegra-xusb
[ 450.674400] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 450.890318] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 451.106485] usb 1-2: device not accepting address 60, error -22
[ 451.438675] usb 1-2: new high-speed USB device number 61 using tegra-xusb
[ 451.439434] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 451.666512] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 451.886137] usb 1-2: device not accepting address 61, error -22
[ 451.892262] usb usb1-port2: attempt power cycle
[ 453.578099] usb 1-2: new high-speed USB device number 62 using tegra-xusb
[ 453.719060] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 453.719083] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 453.719100] usb 1-2: Product: USB 2.0 Hub
[ 453.720559] hub 1-2:1.0: USB hub found
[ 453.720662] hub 1-2:1.0: 4 ports detected
[ 453.850199] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 453.870110] usb 1-2: usb_suspend_both: status 0
[ 453.898513] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 454.126260] usb 1-2.4: new low-speed USB device number 63 using tegra-xusb
[ 454.157719] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2005
[ 454.157736] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 454.157748] usb 1-2.4: Product: DELL USB Keyboard
[ 454.157759] usb 1-2.4: Manufacturer: DELL
[ 454.165826] input: DELL DELL USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2005.007F/input/input128
[ 454.223556] hid-generic 0003:413C:2005.007F: input,hidraw1: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 454.639840] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 454.639943] usb 1-2: USB disconnect, device number 62
[ 454.639969] usb 1-2.4: USB disconnect, device number 63
[ 454.744957] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 455.010285] usb 1-2: new high-speed USB device number 64 using tegra-xusb
[ 455.030884] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 455.030896] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 455.030904] usb 1-2: Product: USB 2.0 Hub
[ 455.033969] hub 1-2:1.0: USB hub found
[ 455.034038] hub 1-2:1.0: 4 ports detected
[ 455.328243] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 455.328489] usb 1-2: USB disconnect, device number 64
[ 455.346240] usb 1-2.4: new low-speed USB device number 65 using tegra-xusb
[ 455.346654] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 455.599024] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 455.870139] usb 1-2.4: device not accepting address 65, error -22
[ 455.888425] sysrq: SysRq : HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-backtrace-all-active-cpus(l) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers(p) show-all-timers(q) unraw(r) sync(s) show-task-states(t) unmount(u) show-blocked-tasks(w) dump-ftrace-buffer(z)
[ 455.912065] usb 1-2-port4: attempt power cycle
[ 456.227972] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 456.494095] usb 1-2: new high-speed USB device number 69 using tegra-xusb
[ 456.514929] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 456.514939] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 456.514946] usb 1-2: Product: USB 2.0 Hub
[ 456.517371] hub 1-2:1.0: USB hub found
[ 456.517457] hub 1-2:1.0: 4 ports detected
[ 456.642191] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 456.662119] usb 1-2: usb_suspend_both: status 0
[ 457.866229] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 458.063239] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 458.063274] usb 1-2: USB disconnect, device number 69
[ 458.094118] usb 1-2.4: new low-speed USB device number 70 using tegra-xusb
[ 458.094324] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 458.311246] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 458.526592] usb 1-2.4: device not accepting address 70, error -22
[ 458.561118] usb 1-2-port4: attempt power cycle
[ 458.875421] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 459.410177] usb 1-2: new high-speed USB device number 74 using tegra-xusb
[ 459.410541] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 459.626979] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 459.874199] usb 1-2: device not accepting address 74, error -22
[ 460.034466] usb 1-2: new high-speed USB device number 75 using tegra-xusb
[ 460.055201] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 460.055222] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 460.055238] usb 1-2: Product: USB 2.0 Hub
[ 460.057038] hub 1-2:1.0: USB hub found
[ 460.057110] hub 1-2:1.0: 4 ports detected
[ 460.165705] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 460.165740] usb 1-2: USB disconnect, device number 75
[ 460.202298] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 460.470205] usb 1-2: new high-speed USB device number 76 using tegra-xusb
[ 460.490722] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 460.490728] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 460.490732] usb 1-2: Product: USB 2.0 Hub
[ 460.492005] hub 1-2:1.0: USB hub found
[ 460.492316] hub 1-2:1.0: 4 ports detected
[ 460.766014] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 460.766038] usb 1-2: USB disconnect, device number 76
[ 460.806168] usb 1-2.4: new low-speed USB device number 77 using tegra-xusb
[ 460.806431] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 461.130443] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 461.466134] usb 1-2.4: device not accepting address 77, error -22
[ 461.523424] sysrq: SysRq : HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-backtrace-all-active-cpus(l) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers(p) show-all-timers(q) unraw(r) sync(s) show-task-states(t) unmount(u) show-blocked-tasks(w) dump-ftrace-buffer(z)
[ 461.545611] usb 1-2-port4: attempt power cycle
[ 461.725698] sysrq: SysRq : Changing Loglevel
[ 461.794362] sysrq: Loglevel set to 0
[ 461.975777] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 462.242249] usb 1-2: new high-speed USB device number 81 using tegra-xusb
[ 462.242656] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 462.450415] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 462.658245] usb 1-2: device not accepting address 81, error -22
[ 462.778135] usb 1-2: new high-speed USB device number 82 using tegra-xusb
[ 462.778351] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 462.986282] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 463.194139] usb 1-2: device not accepting address 82, error -22
[ 463.194242] usb usb1-port2: attempt power cycle
[ 464.258371] usb 1-2: new high-speed USB device number 83 using tegra-xusb
[ 464.378269] usb 1-2: device descriptor read/64, error -71
[ 464.606423] usb 1-2: device descriptor read/64, error -71
[ 465.042467] usb 1-2: new high-speed USB device number 84 using tegra-xusb
[ 465.162325] usb 1-2: device descriptor read/64, error -71
[ 465.410749] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 465.410761] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 465.410769] usb 1-2: Product: USB 2.0 Hub
[ 465.411913] hub 1-2:1.0: USB hub found
[ 465.411984] hub 1-2:1.0: 4 ports detected
[ 465.558615] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 465.558650] usb 1-2: USB disconnect, device number 84
[ 465.598305] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 465.862135] usb 1-2: new high-speed USB device number 85 using tegra-xusb
[ 465.886497] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 465.886503] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 465.886507] usb 1-2: Product: USB 2.0 Hub
[ 465.887380] hub 1-2:1.0: USB hub found
[ 465.888496] hub 1-2:1.0: 4 ports detected
[ 466.178102] usb 1-2.4: new low-speed USB device number 86 using tegra-xusb
[ 466.207909] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2005
[ 466.207918] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 466.207924] usb 1-2.4: Product: DELL USB Keyboard
[ 466.207929] usb 1-2.4: Manufacturer: DELL
[ 466.213010] input: DELL DELL USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2005.0080/input/input129
[ 466.259181] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 466.259228] usb 1-2: USB disconnect, device number 85
[ 466.275314] hid-generic 0003:413C:2005.0080: input,hidraw1: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 466.275451] usb 1-2.4: USB disconnect, device number 86
[ 466.377891] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 467.058568] usb 1-2: new high-speed USB device number 87 using tegra-xusb
[ 467.082548] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 467.082555] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 467.082559] usb 1-2: Product: USB 2.0 Hub
[ 467.083527] hub 1-2:1.0: USB hub found
[ 467.083605] hub 1-2:1.0: 4 ports detected
[ 467.255921] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 467.255959] usb 1-2: USB disconnect, device number 87
[ 467.294145] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 467.558258] usb 1-2: new high-speed USB device number 88 using tegra-xusb
[ 467.558482] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 467.766350] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 467.974155] usb 1-2: device not accepting address 88, error -22
[ 468.094112] usb 1-2: new high-speed USB device number 89 using tegra-xusb
[ 468.119169] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 468.119193] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 468.119209] usb 1-2: Product: USB 2.0 Hub
[ 468.120887] hub 1-2:1.0: USB hub found
[ 468.120975] hub 1-2:1.0: 4 ports detected
[ 468.321480] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 468.321580] usb 1-2: USB disconnect, device number 89
[ 468.358421] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 468.626691] usb 1-2: new high-speed USB device number 90 using tegra-xusb
[ 468.647625] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 468.647658] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 468.647682] usb 1-2: Product: USB 2.0 Hub
[ 468.649823] hub 1-2:1.0: USB hub found
[ 468.649896] hub 1-2:1.0: 4 ports detected
[ 468.958542] usb 1-2.4: new low-speed USB device number 91 using tegra-xusb
[ 468.983641] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2005
[ 468.983647] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 468.983651] usb 1-2.4: Product: DELL USB Keyboard
[ 468.983654] usb 1-2.4: Manufacturer: DELL
[ 468.987440] input: DELL DELL USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2005.0081/input/input130
[ 469.047987] hid-generic 0003:413C:2005.0081: input,hidraw1: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 469.957810] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 469.957893] usb 1-2: USB disconnect, device number 90
[ 469.957914] usb 1-2.4: USB disconnect, device number 91
[ 470.056444] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 470.318286] usb 1-2: new high-speed USB device number 92 using tegra-xusb
[ 470.343117] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 470.343134] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 470.343147] usb 1-2: Product: USB 2.0 Hub
[ 470.344645] hub 1-2:1.0: USB hub found
[ 470.344716] hub 1-2:1.0: 4 ports detected
[ 470.654313] usb 1-2.4: new low-speed USB device number 93 using tegra-xusb
[ 470.683487] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2005
[ 470.683494] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 470.683498] usb 1-2.4: Product: DELL USB Keyboard
[ 470.683501] usb 1-2.4: Manufacturer: DELL
[ 470.687822] input: DELL DELL USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2005.0082/input/input131
[ 470.747171] hid-generic 0003:413C:2005.0082: input,hidraw1: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 471.427349] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 471.427468] usb 1-2: USB disconnect, device number 92
[ 471.427497] usb 1-2.4: USB disconnect, device number 93
[ 471.533024] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 471.798355] usb 1-2: new high-speed USB device number 94 using tegra-xusb
[ 471.819688] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 471.819723] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 471.819748] usb 1-2: Product: USB 2.0 Hub
[ 471.826007] hub 1-2:1.0: USB hub found
[ 471.826165] hub 1-2:1.0: 4 ports detected
[ 472.134591] usb 1-2.4: new low-speed USB device number 95 using tegra-xusb
[ 472.160659] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2005
[ 472.160670] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 472.160679] usb 1-2.4: Product: DELL USB Keyboard
[ 472.160686] usb 1-2.4: Manufacturer: DELL
[ 472.166053] input: DELL DELL USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2005.0083/input/input132
[ 472.227653] hid-generic 0003:413C:2005.0083: input,hidraw1: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 472.872591] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 472.872617] usb 1-2: USB disconnect, device number 94
[ 472.872622] usb 1-2.4: USB disconnect, device number 95
[ 472.963600] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 473.226691] usb 1-2: new high-speed USB device number 96 using tegra-xusb
[ 473.247316] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 473.247347] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 473.247370] usb 1-2: Product: USB 2.0 Hub
[ 473.249447] hub 1-2:1.0: USB hub found
[ 473.249519] hub 1-2:1.0: 4 ports detected
[ 473.542489] usb 1-2.4: new low-speed USB device number 97 using tegra-xusb
[ 473.567636] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2005
[ 473.567642] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 473.567646] usb 1-2.4: Product: DELL USB Keyboard
[ 473.567649] usb 1-2.4: Manufacturer: DELL
[ 473.574528] input: DELL DELL USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2005.0084/input/input133
[ 473.636810] hid-generic 0003:413C:2005.0084: input,hidraw1: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 474.566013] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 474.566059] usb 1-2: USB disconnect, device number 96
[ 474.568310] usb 1-2.4: USB disconnect, device number 97
[ 474.655606] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 475.126283] usb 1-2: new high-speed USB device number 98 using tegra-xusb
[ 475.151215] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 475.151238] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 475.151254] usb 1-2: Product: USB 2.0 Hub
[ 475.153213] hub 1-2:1.0: USB hub found
[ 475.153508] hub 1-2:1.0: 4 ports detected
[ 475.462111] usb 1-2.4: new low-speed USB device number 99 using tegra-xusb
[ 475.488844] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2005
[ 475.488851] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 475.488855] usb 1-2.4: Product: DELL USB Keyboard
[ 475.488859] usb 1-2.4: Manufacturer: DELL
[ 475.493229] input: DELL DELL USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2005.0085/input/input134
[ 475.553310] hid-generic 0003:413C:2005.0085: input,hidraw1: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 475.948757] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 475.948923] usb 1-2: USB disconnect, device number 98
[ 475.948953] usb 1-2.4: USB disconnect, device number 99
[ 476.051080] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 476.526158] usb 1-2: new high-speed USB device number 100 using tegra-xusb
[ 476.546884] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 476.546907] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 476.546924] usb 1-2: Product: USB 2.0 Hub
[ 476.549164] hub 1-2:1.0: USB hub found
[ 476.549237] hub 1-2:1.0: 4 ports detected
[ 476.659801] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 476.659846] usb 1-2: USB disconnect, device number 100
[ 476.698148] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 476.962263] usb 1-2: new high-speed USB device number 101 using tegra-xusb
[ 476.982756] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 476.982762] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 476.982766] usb 1-2: Product: USB 2.0 Hub
[ 476.983695] hub 1-2:1.0: USB hub found
[ 476.983800] hub 1-2:1.0: 4 ports detected
[ 477.136757] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 477.136873] usb 1-2: USB disconnect, device number 101
[ 477.178169] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 478.274159] usb 1-2: new high-speed USB device number 102 using tegra-xusb
[ 478.274401] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 478.482330] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 478.690096] usb 1-2: device not accepting address 102, error -22
[ 478.810196] usb 1-2: new high-speed USB device number 103 using tegra-xusb
[ 478.831225] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 478.831247] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 478.831263] usb 1-2: Product: USB 2.0 Hub
[ 478.833250] hub 1-2:1.0: USB hub found
[ 478.833344] hub 1-2:1.0: 4 ports detected
[ 479.035284] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 479.035322] usb 1-2: USB disconnect, device number 103
[ 479.070138] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 479.750440] usb 1-2: new high-speed USB device number 104 using tegra-xusb
[ 479.770837] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 479.770843] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 479.770847] usb 1-2: Product: USB 2.0 Hub
[ 479.771707] hub 1-2:1.0: USB hub found
[ 479.771781] hub 1-2:1.0: 4 ports detected
[ 480.030708] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 480.030803] usb 1-2: USB disconnect, device number 104
[ 480.066228] usb 1-2.4: new low-speed USB device number 105 using tegra-xusb
[ 480.066472] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 480.274334] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 480.482130] usb 1-2.4: device not accepting address 105, error -22
[ 480.482334] usb 1-2-port4: attempt power cycle
[ 480.803454] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 481.074236] usb 1-2: new high-speed USB device number 109 using tegra-xusb
[ 481.074555] usb 1-2: Device not responding to setup address.
[ 481.282332] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 481.490104] usb 1-2: device not accepting address 109, error -22
[ 481.818146] usb 1-2: new high-speed USB device number 110 using tegra-xusb
[ 481.839248] usb 1-2: device descriptor read/8, error -71
[ 481.966863] usb 1-2: device descriptor read/8, error -71
[ 482.074215] usb usb1-port2: attempt power cycle
[ 483.134908] usb 1-2: new high-speed USB device number 111 using tegra-xusb
[ 483.482475] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 483.482481] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 483.482485] usb 1-2: Product: USB 2.0 Hub
[ 483.483423] hub 1-2:1.0: USB hub found
[ 483.483497] hub 1-2:1.0: 4 ports detected
[ 483.770223] usb 1-2.4: new low-speed USB device number 112 using tegra-xusb
[ 483.795674] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2005
[ 483.795688] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 483.795697] usb 1-2.4: Product: DELL USB Keyboard
[ 483.795705] usb 1-2.4: Manufacturer: DELL
[ 483.800505] input: DELL DELL USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2005.0086/input/input135
[ 483.859848] hid-generic 0003:413C:2005.0086: input,hidraw1: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 484.736259] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 484.736300] usb 1-2: USB disconnect, device number 111
[ 484.736309] usb 1-2.4: USB disconnect, device number 112
[ 484.819729] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 485.082173] usb 1-2: new high-speed USB device number 113 using tegra-xusb
[ 485.107145] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 485.107168] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 485.107184] usb 1-2: Product: USB 2.0 Hub
[ 485.109393] hub 1-2:1.0: USB hub found
[ 485.109503] hub 1-2:1.0: 4 ports detected
[ 485.173734] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 485.173761] usb 1-2: USB disconnect, device number 113
[ 485.214148] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 485.686113] usb 1-2: new high-speed USB device number 114 using tegra-xusb
[ 485.686325] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 485.894354] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 486.102238] usb 1-2: device not accepting address 114, error -22
[ 486.222288] usb 1-2: new high-speed USB device number 115 using tegra-xusb
[ 486.243531] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 486.243564] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 486.243588] usb 1-2: Product: USB 2.0 Hub
[ 486.246994] hub 1-2:1.0: USB hub found
[ 486.247131] hub 1-2:1.0: 4 ports detected
[ 486.422874] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 486.422913] usb 1-2: USB disconnect, device number 115
[ 486.458327] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 486.722192] usb 1-2: new high-speed USB device number 116 using tegra-xusb
[ 486.744585] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 486.744599] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 486.744609] usb 1-2: Product: USB 2.0 Hub
[ 486.745817] hub 1-2:1.0: USB hub found
[ 486.745892] hub 1-2:1.0: 4 ports detected
[ 486.830022] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 486.830371] usb 1-2: USB disconnect, device number 116
[ 486.866247] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 487.134240] usb 1-2: new high-speed USB device number 117 using tegra-xusb
[ 487.156052] usb 1-2: device descriptor read/8, error -71
[ 487.283029] usb 1-2: device descriptor read/8, error -71
[ 487.510182] usb 1-2: new high-speed USB device number 118 using tegra-xusb
[ 487.530872] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 487.530889] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 487.530901] usb 1-2: Product: USB 2.0 Hub
[ 487.532224] hub 1-2:1.0: USB hub found
[ 487.532322] hub 1-2:1.0: 4 ports detected
[ 487.633139] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 487.633202] usb 1-2: USB disconnect, device number 118
[ 487.674154] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 487.938293] usb 1-2: new high-speed USB device number 119 using tegra-xusb
[ 487.963022] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 487.963031] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 487.963037] usb 1-2: Product: USB 2.0 Hub
[ 487.966565] hub 1-2:1.0: USB hub found
[ 487.966707] hub 1-2:1.0: 4 ports detected
[ 488.258414] usb 1-2.4: new low-speed USB device number 120 using tegra-xusb
[ 488.284219] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2005
[ 488.284225] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 488.284228] usb 1-2.4: Product: DELL USB Keyboard
[ 488.284232] usb 1-2.4: Manufacturer: DELL
[ 488.288713] input: DELL DELL USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2005.0087/input/input136
[ 488.342979] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 488.343057] usb 1-2: USB disconnect, device number 119
[ 488.348214] hid-generic 0003:413C:2005.0087: input,hidraw1: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 488.348327] usb 1-2.4: USB disconnect, device number 120
[ 488.419330] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 488.682170] usb 1-2: new high-speed USB device number 121 using tegra-xusb
[ 488.703696] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 488.703704] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 488.703709] usb 1-2: Product: USB 2.0 Hub
[ 488.706054] hub 1-2:1.0: USB hub found
[ 488.706319] hub 1-2:1.0: 4 ports detected
[ 488.962468] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 488.962495] usb 1-2: USB disconnect, device number 121
[ 489.014181] usb 1-2.4: new low-speed USB device number 122 using tegra-xusb
[ 489.014430] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 489.222903] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 489.430136] usb 1-2.4: device not accepting address 122, error -22
[ 489.430449] usb 1-2-port4: attempt power cycle
[ 489.748519] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 490.011401] usb 1-2: new high-speed USB device number 126 using tegra-xusb
[ 490.035204] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 490.035236] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 490.035259] usb 1-2: Product: USB 2.0 Hub
[ 490.037258] hub 1-2:1.0: USB hub found
[ 490.037333] hub 1-2:1.0: 4 ports detected
[ 490.346183] usb 1-2.4: new low-speed USB device number 127 using tegra-xusb
[ 490.375486] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2005
[ 490.375492] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 490.375496] usb 1-2.4: Product: DELL USB Keyboard
[ 490.375499] usb 1-2.4: Manufacturer: DELL
[ 490.379441] input: DELL DELL USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2005.0088/input/input137
[ 490.439735] hid-generic 0003:413C:2005.0088: input,hidraw1: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 490.826226] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 490.826377] usb 1-2: USB disconnect, device number 126
[ 490.826404] usb 1-2.4: USB disconnect, device number 127
[ 490.911098] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 491.174187] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 491.194886] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 491.194894] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 491.194898] usb 1-2: Product: USB 2.0 Hub
[ 491.196052] hub 1-2:1.0: USB hub found
[ 491.196166] hub 1-2:1.0: 4 ports detected
[ 491.502474] usb 1-2.4: new low-speed USB device number 4 using tegra-xusb
[ 491.528880] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2005
[ 491.528892] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 491.528900] usb 1-2.4: Product: DELL USB Keyboard
[ 491.528907] usb 1-2.4: Manufacturer: DELL
[ 491.534471] input: DELL DELL USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2005.0089/input/input138
[ 491.595277] hid-generic 0003:413C:2005.0089: input,hidraw1: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 492.048690] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 492.048807] usb 1-2: USB disconnect, device number 2
[ 492.048835] usb 1-2.4: USB disconnect, device number 4
[ 492.164281] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 492.426308] usb 1-2: new high-speed USB device number 5 using tegra-xusb
[ 492.451874] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 492.451896] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 492.451911] usb 1-2: Product: USB 2.0 Hub
[ 492.453388] hub 1-2:1.0: USB hub found
[ 492.453496] hub 1-2:1.0: 4 ports detected
[ 492.649593] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 492.649697] usb 1-2: USB disconnect, device number 5
[ 492.686263] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 493.574159] usb 1-2: new high-speed USB device number 6 using tegra-xusb
[ 493.574410] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 493.783335] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 493.990139] usb 1-2: device not accepting address 6, error -22
[ 494.110276] usb 1-2: new high-speed USB device number 7 using tegra-xusb
[ 494.131575] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 494.131608] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 494.131631] usb 1-2: Product: USB 2.0 Hub
[ 494.133707] hub 1-2:1.0: USB hub found
[ 494.133781] hub 1-2:1.0: 4 ports detected
[ 494.446262] usb 1-2.4: new low-speed USB device number 8 using tegra-xusb
[ 494.471485] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2005
[ 494.471491] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 494.471495] usb 1-2.4: Product: DELL USB Keyboard
[ 494.471498] usb 1-2.4: Manufacturer: DELL
[ 494.475450] input: DELL DELL USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2005.008A/input/input139
[ 494.535675] hid-generic 0003:413C:2005.008A: input,hidraw1: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 495.039409] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 495.039646] usb 1-2: USB disconnect, device number 7
[ 495.039705] usb 1-2.4: USB disconnect, device number 8
[ 495.144013] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 495.410412] usb 1-2: new high-speed USB device number 9 using tegra-xusb
[ 495.430887] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 495.430904] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 495.430915] usb 1-2: Product: USB 2.0 Hub
[ 495.432233] hub 1-2:1.0: USB hub found
[ 495.432302] hub 1-2:1.0: 4 ports detected
[ 495.644119] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 495.644234] usb 1-2: USB disconnect, device number 9
[ 495.658675] usb 1-2-port4: attempt power cycle
[ 495.976102] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 496.874159] usb 1-2: new high-speed USB device number 14 using tegra-xusb
[ 496.874367] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 497.082384] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 497.290140] usb 1-2: device not accepting address 14, error -22
[ 497.410512] usb 1-2: new high-speed USB device number 15 using tegra-xusb
[ 497.410788] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 497.618396] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 497.826197] usb 1-2: device not accepting address 15, error -22
[ 497.826293] usb usb1-port2: attempt power cycle
[ 499.782109] usb 1-2: new high-speed USB device number 16 using tegra-xusb
[ 499.906334] usb 1-2: device descriptor read/64, error -71
[ 500.343362] usb 1-2: device descriptor read/64, error -71
[ 500.570167] usb 1-2: new full-speed USB device number 17 using tegra-xusb
[ 501.320032] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 501.354632] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 501.618190] usb 1-2: new high-speed USB device number 18 using tegra-xusb
[ 501.639018] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 501.639036] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 501.639048] usb 1-2: Product: USB 2.0 Hub
[ 501.640532] hub 1-2:1.0: USB hub found
[ 501.640602] hub 1-2:1.0: 4 ports detected
[ 501.954249] usb 1-2.4: new low-speed USB device number 19 using tegra-xusb
[ 501.958819] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 501.958867] usb 1-2: USB disconnect, device number 18
[ 501.978967] usb 1-2.4: device descriptor read/8, error -71
[ 502.107312] usb 1-2.4: device descriptor read/8, error -71
[ 502.214430] usb 1-2-port4: attempt power cycle
[ 502.534202] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 503.690467] usb 1-2: new high-speed USB device number 23 using tegra-xusb
[ 503.712696] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 503.712765] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 503.712815] usb 1-2: Product: USB 2.0 Hub
[ 503.716182] hub 1-2:1.0: USB hub found
[ 503.716256] hub 1-2:1.0: 4 ports detected
[ 503.920283] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 503.920322] usb 1-2: USB disconnect, device number 23
[ 503.958312] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 504.222235] usb 1-2: new high-speed USB device number 24 using tegra-xusb
[ 504.244742] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 504.244757] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 504.244767] usb 1-2: Product: USB 2.0 Hub
[ 504.250268] hub 1-2:1.0: USB hub found
[ 504.250350] hub 1-2:1.0: 4 ports detected
[ 504.558356] usb 1-2.4: new low-speed USB device number 25 using tegra-xusb
[ 504.588677] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2005
[ 504.588688] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 504.588695] usb 1-2.4: Product: DELL USB Keyboard
[ 504.588702] usb 1-2.4: Manufacturer: DELL
[ 504.593023] input: DELL DELL USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2005.008B/input/input140
[ 504.633651] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 504.633748] usb 1-2: USB disconnect, device number 24
[ 504.651630] hid-generic 0003:413C:2005.008B: input,hidraw1: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 504.651761] usb 1-2.4: USB disconnect, device number 25
[ 504.725795] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 504.990162] usb 1-2: new high-speed USB device number 26 using tegra-xusb
[ 505.014823] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 505.014833] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 505.014840] usb 1-2: Product: USB 2.0 Hub
[ 505.015981] hub 1-2:1.0: USB hub found
[ 505.016046] hub 1-2:1.0: 4 ports detected
[ 505.148647] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 505.148686] usb 1-2: USB disconnect, device number 26
[ 505.186301] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 505.454389] usb 1-2: new high-speed USB device number 27 using tegra-xusb
[ 505.474855] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 505.474861] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 505.474864] usb 1-2: Product: USB 2.0 Hub
[ 505.475846] hub 1-2:1.0: USB hub found
[ 505.477013] hub 1-2:1.0: 4 ports detected
[ 505.629336] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 505.629438] usb 1-2: USB disconnect, device number 27
[ 505.633344] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 505.894354] usb 1-2: new high-speed USB device number 28 using tegra-xusb
[ 505.915426] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 505.915460] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 505.915483] usb 1-2: Product: USB 2.0 Hub
[ 505.918059] hub 1-2:1.0: USB hub found
[ 505.918884] hub 1-2:1.0: 4 ports detected
[ 506.136936] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 506.137138] usb 1-2: USB disconnect, device number 28
[ 506.146451] usb 1-2-port4: attempt power cycle
[ 506.465533] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 506.726138] usb 1-2: new high-speed USB device number 33 using tegra-xusb
[ 506.748452] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 506.748521] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 506.748570] usb 1-2: Product: USB 2.0 Hub
[ 506.751902] hub 1-2:1.0: USB hub found
[ 506.752602] hub 1-2:1.0: 4 ports detected
[ 506.858573] hub 1-2:1.0: hub_ext_port_status failed (err = -71)
[ 506.858699] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 506.858776] usb 1-2: USB disconnect, device number 33
[ 506.858792] usb 1-2: Failed to suspend device, error -19
[ 506.858799] usb 1-2: usb_suspend_both: status -19
[ 506.894330] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 507.162243] usb 1-2: new high-speed USB device number 34 using tegra-xusb
[ 507.182738] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 507.182745] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 507.182748] usb 1-2: Product: USB 2.0 Hub
[ 507.183892] hub 1-2:1.0: USB hub found
[ 507.184095] hub 1-2:1.0: 4 ports detected
[ 507.454790] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 507.454839] usb 1-2: USB disconnect, device number 34
[ 507.490415] usb 1-2.4: new low-speed USB device number 35 using tegra-xusb
[ 507.490773] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 507.698609] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 507.906515] usb 1-2.4: device not accepting address 35, error -22
[ 507.907043] usb 1-2-port4: attempt power cycle
[ 508.227927] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 508.490119] usb 1-2: new high-speed USB device number 39 using tegra-xusb
[ 508.510637] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 508.510646] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 508.510652] usb 1-2: Product: USB 2.0 Hub
[ 508.511708] hub 1-2:1.0: USB hub found
[ 508.511778] hub 1-2:1.0: 4 ports detected
[ 508.665941] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 508.665975] usb 1-2: USB disconnect, device number 39
[ 508.702210] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 508.966146] usb 1-2: new high-speed USB device number 40 using tegra-xusb
[ 508.986531] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 508.986538] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 508.986543] usb 1-2: Product: USB 2.0 Hub
[ 508.987539] hub 1-2:1.0: USB hub found
[ 508.987627] hub 1-2:1.0: 4 ports detected
[ 509.114141] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 509.134164] usb 1-2: usb_suspend_both: status 0
[ 509.946268] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 510.074219] usb 1-2: USB disconnect, device number 40
[ 510.074286] hub 1-2:1.0: hub_ext_port_status failed (err = -71)
[ 510.338197] usb 1-2: new high-speed USB device number 41 using tegra-xusb
[ 510.338484] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 510.546476] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 510.754385] usb 1-2: device not accepting address 41, error -22
[ 510.874197] usb 1-2: new high-speed USB device number 42 using tegra-xusb
[ 510.874440] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 511.082326] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 511.290163] usb 1-2: device not accepting address 42, error -22
[ 511.290257] usb usb1-port2: attempt power cycle
[ 512.350257] usb 1-2: new high-speed USB device number 43 using tegra-xusb
[ 512.490994] usb 1-2: device descriptor read/all, error -71
[ 512.610156] usb 1-2: new high-speed USB device number 44 using tegra-xusb
[ 512.751245] usb 1-2: device descriptor read/all, error -71
[ 512.751407] usb usb1-port2: unable to enumerate USB device
[ 512.751575] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 512.786160] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 513.050404] usb 1-2: new high-speed USB device number 45 using tegra-xusb
[ 513.070782] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 513.070788] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 513.070792] usb 1-2: Product: USB 2.0 Hub
[ 513.071708] hub 1-2:1.0: USB hub found
[ 513.071781] hub 1-2:1.0: 4 ports detected
[ 513.257030] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 513.257071] usb 1-2: USB disconnect, device number 45
[ 513.294149] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 513.558296] usb 1-2: new high-speed USB device number 46 using tegra-xusb
[ 513.558568] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 513.770384] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 513.978095] usb 1-2: device not accepting address 46, error -22
[ 514.098141] usb 1-2: new high-speed USB device number 47 using tegra-xusb
[ 514.119396] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 514.119429] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 514.119454] usb 1-2: Product: USB 2.0 Hub
[ 514.121463] hub 1-2:1.0: USB hub found
[ 514.121576] hub 1-2:1.0: 4 ports detected
[ 514.334609] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 514.334752] usb 1-2: USB disconnect, device number 47
[ 514.351051] usb 1-2-port4: attempt power cycle
[ 514.670354] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 515.142233] usb 1-2: new high-speed USB device number 52 using tegra-xusb
[ 515.162849] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 515.162856] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 515.162860] usb 1-2: Product: USB 2.0 Hub
[ 515.164242] hub 1-2:1.0: USB hub found
[ 515.164366] hub 1-2:1.0: 4 ports detected
[ 515.267867] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 515.267896] usb 1-2: USB disconnect, device number 52
[ 515.302302] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 515.566251] usb 1-2: new high-speed USB device number 53 using tegra-xusb
[ 515.586607] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 515.586617] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 515.586638] usb 1-2: Product: USB 2.0 Hub
[ 515.588322] hub 1-2:1.0: USB hub found
[ 515.588673] hub 1-2:1.0: 4 ports detected
[ 515.894115] usb 1-2.4: new low-speed USB device number 54 using tegra-xusb
[ 515.919924] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2005
[ 515.919946] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 515.919962] usb 1-2.4: Product: DELL USB Keyboard
[ 515.919976] usb 1-2.4: Manufacturer: DELL
[ 515.925569] input: DELL DELL USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2005.008C/input/input141
[ 515.982636] hid-generic 0003:413C:2005.008C: input,hidraw1: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 516.322485] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 516.322526] usb 1-2: USB disconnect, device number 53
[ 516.322537] usb 1-2.4: USB disconnect, device number 54
[ 516.395153] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 516.658301] usb 1-2: new high-speed USB device number 55 using tegra-xusb
[ 516.679024] usb 1-2: device descriptor read/8, error -71
[ 516.807092] usb 1-2: device descriptor read/8, error -71
[ 517.510271] usb 1-2: new high-speed USB device number 56 using tegra-xusb
[ 517.531032] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 517.531048] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 517.531061] usb 1-2: Product: USB 2.0 Hub
[ 517.532989] hub 1-2:1.0: USB hub found
[ 517.533063] hub 1-2:1.0: 4 ports detected
[ 517.838168] usb 1-2.4: new low-speed USB device number 57 using tegra-xusb
[ 517.863890] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2005
[ 517.863902] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 517.863910] usb 1-2.4: Product: DELL USB Keyboard
[ 517.863917] usb 1-2.4: Manufacturer: DELL
[ 517.868392] input: DELL DELL USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2005.008D/input/input142
[ 517.927263] hid-generic 0003:413C:2005.008D: input,hidraw1: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 518.352667] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 518.352798] usb 1-2: USB disconnect, device number 56
[ 518.352828] usb 1-2.4: USB disconnect, device number 57
[ 518.447201] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 518.710121] usb 1-2: new high-speed USB device number 58 using tegra-xusb
[ 518.730922] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 518.730934] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 518.730942] usb 1-2: Product: USB 2.0 Hub
[ 518.732600] hub 1-2:1.0: USB hub found
[ 518.732900] hub 1-2:1.0: 4 ports detected
[ 519.042310] usb 1-2.4: new low-speed USB device number 59 using tegra-xusb
[ 519.068311] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2005
[ 519.068325] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 519.068335] usb 1-2.4: Product: DELL USB Keyboard
[ 519.068343] usb 1-2.4: Manufacturer: DELL
[ 519.073250] input: DELL DELL USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2005.008E/input/input143
[ 519.131938] hid-generic 0003:413C:2005.008E: input,hidraw1: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 519.531534] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 519.531573] usb 1-2: USB disconnect, device number 58
[ 519.531582] usb 1-2.4: USB disconnect, device number 59
[ 519.635475] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 519.898183] usb 1-2: new high-speed USB device number 60 using tegra-xusb
[ 519.918911] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 519.918921] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 519.918928] usb 1-2: Product: USB 2.0 Hub
[ 519.920073] hub 1-2:1.0: USB hub found
[ 519.920171] hub 1-2:1.0: 4 ports detected
[ 520.022763] hub 1-2:1.0: hub_ext_port_status failed (err = -71)
[ 520.023204] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 520.023261] usb 1-2: USB disconnect, device number 60
[ 520.023451] usb 1-2: Failed to suspend device, error -71
[ 520.023458] usb 1-2: usb_suspend_both: status -71
[ 520.062195] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 520.326214] usb 1-2: new high-speed USB device number 61 using tegra-xusb
[ 520.348503] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 520.348568] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 520.348617] usb 1-2: Product: USB 2.0 Hub
[ 520.353422] hub 1-2:1.0: USB hub found
[ 520.354264] hub 1-2:1.0: 4 ports detected
[ 520.458780] hub 1-2:1.0: hub_ext_port_status failed (err = -71)
[ 520.459304] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 520.459362] usb 1-2: USB disconnect, device number 61
[ 520.459563] usb 1-2: Failed to suspend device, error -71
[ 520.459582] usb 1-2: usb_suspend_both: status -71
[ 520.494152] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 520.758190] usb 1-2: new high-speed USB device number 62 using tegra-xusb
[ 520.778519] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 520.778526] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 520.778530] usb 1-2: Product: USB 2.0 Hub
[ 520.779484] hub 1-2:1.0: USB hub found
[ 520.779564] hub 1-2:1.0: 4 ports detected
[ 520.937577] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 520.937660] usb 1-2: USB disconnect, device number 62
[ 520.974181] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 521.238399] usb 1-2: new high-speed USB device number 63 using tegra-xusb
[ 521.259017] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 521.259030] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 521.259039] usb 1-2: Product: USB 2.0 Hub
[ 521.260270] hub 1-2:1.0: USB hub found
[ 521.260343] hub 1-2:1.0: 4 ports detected
[ 521.468331] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 521.468371] usb 1-2: USB disconnect, device number 63
[ 521.506188] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 521.774124] usb 1-2: new high-speed USB device number 64 using tegra-xusb
[ 521.774378] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 521.982367] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 522.190115] usb 1-2: device not accepting address 64, error -22
[ 522.730141] usb 1-2: new high-speed USB device number 65 using tegra-xusb
[ 522.751077] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 522.751110] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 522.751134] usb 1-2: Product: USB 2.0 Hub
[ 522.752413] hub 1-2:1.0: USB hub found
[ 522.752512] hub 1-2:1.0: 4 ports detected
[ 522.955319] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 522.955372] usb 1-2: USB disconnect, device number 65
[ 522.990172] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 523.254369] usb 1-2: new high-speed USB device number 66 using tegra-xusb
[ 523.254679] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 523.462350] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 523.670176] usb 1-2: device not accepting address 66, error -22
[ 524.206315] usb 1-2: new high-speed USB device number 67 using tegra-xusb
[ 524.230997] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 524.231009] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 524.231017] usb 1-2: Product: USB 2.0 Hub
[ 524.232471] hub 1-2:1.0: USB hub found
[ 524.232584] hub 1-2:1.0: 4 ports detected
[ 524.433293] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 524.433393] usb 1-2: USB disconnect, device number 67
[ 524.470198] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 524.734152] usb 1-2: new high-speed USB device number 68 using tegra-xusb
[ 524.755083] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 524.755097] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 524.755106] usb 1-2: Product: USB 2.0 Hub
[ 524.756245] hub 1-2:1.0: USB hub found
[ 524.756309] hub 1-2:1.0: 4 ports detected
[ 524.820253] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 524.820288] usb 1-2: USB disconnect, device number 68
[ 524.854317] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 525.122687] usb 1-2: new high-speed USB device number 69 using tegra-xusb
[ 525.123236] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 525.330416] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 525.538259] usb 1-2: device not accepting address 69, error -22
[ 525.658447] usb 1-2: new high-speed USB device number 70 using tegra-xusb
[ 525.678756] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 525.678762] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 525.678765] usb 1-2: Product: USB 2.0 Hub
[ 525.681712] hub 1-2:1.0: USB hub found
[ 525.682219] hub 1-2:1.0: 4 ports detected
[ 525.970165] usb 1-2.4: new low-speed USB device number 71 using tegra-xusb
[ 525.995484] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2005
[ 525.995492] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 525.995496] usb 1-2.4: Product: DELL USB Keyboard
[ 525.995501] usb 1-2.4: Manufacturer: DELL
[ 525.999341] input: DELL DELL USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2005.008F/input/input144
[ 526.059126] hid-generic 0003:413C:2005.008F: input,hidraw1: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 526.833431] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 526.833494] usb 1-2: USB disconnect, device number 70
[ 526.833510] usb 1-2.4: USB disconnect, device number 71
[ 526.927432] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 527.190479] usb 1-2: new high-speed USB device number 72 using tegra-xusb
[ 527.211137] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 527.211146] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 527.211151] usb 1-2: Product: USB 2.0 Hub
[ 527.213162] hub 1-2:1.0: USB hub found
[ 527.213519] hub 1-2:1.0: 4 ports detected
[ 527.526320] usb 1-2.4: new low-speed USB device number 73 using tegra-xusb
[ 527.552233] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2005
[ 527.552250] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 527.552262] usb 1-2.4: Product: DELL USB Keyboard
[ 527.552274] usb 1-2.4: Manufacturer: DELL
[ 527.558447] input: DELL DELL USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2005.0090/input/input145
[ 527.618968] hid-generic 0003:413C:2005.0090: input,hidraw1: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 528.023957] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 528.024025] usb 1-2: USB disconnect, device number 72
[ 528.024041] usb 1-2.4: USB disconnect, device number 73
[ 528.107224] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 528.370170] usb 1-2: new high-speed USB device number 74 using tegra-xusb
[ 528.390640] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 528.390645] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 528.390649] usb 1-2: Product: USB 2.0 Hub
[ 528.391888] hub 1-2:1.0: USB hub found
[ 528.392213] hub 1-2:1.0: 4 ports detected
[ 528.619438] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 528.619530] usb 1-2: USB disconnect, device number 74
[ 528.638979] usb 1-2-port4: attempt power cycle
[ 528.956810] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 529.646392] usb 1-2: new high-speed USB device number 79 using tegra-xusb
[ 529.670719] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 529.670725] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 529.670729] usb 1-2: Product: USB 2.0 Hub
[ 529.671628] hub 1-2:1.0: USB hub found
[ 529.671706] hub 1-2:1.0: 4 ports detected
[ 529.958367] usb 1-2.4: new low-speed USB device number 80 using tegra-xusb
[ 529.983740] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2005
[ 529.983748] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 529.983752] usb 1-2.4: Product: DELL USB Keyboard
[ 529.983755] usb 1-2.4: Manufacturer: DELL
[ 529.989250] input: DELL DELL USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2005.0091/input/input146
[ 530.047843] hid-generic 0003:413C:2005.0091: input,hidraw1: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 530.426441] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 530.426504] usb 1-2: USB disconnect, device number 79
[ 530.426520] usb 1-2.4: USB disconnect, device number 80
[ 530.504995] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 530.766119] usb 1-2: new high-speed USB device number 81 using tegra-xusb
[ 530.786474] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 530.786480] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 530.786484] usb 1-2: Product: USB 2.0 Hub
[ 530.787334] hub 1-2:1.0: USB hub found
[ 530.787413] hub 1-2:1.0: 4 ports detected
[ 530.939832] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 530.939925] usb 1-2: USB disconnect, device number 81
[ 530.974216] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 531.238430] usb 1-2: new high-speed USB device number 82 using tegra-xusb
[ 531.259284] usb 1-2: device descriptor read/8, error -71
[ 531.386988] usb 1-2: device descriptor read/8, error -71
[ 531.614383] usb 1-2: new high-speed USB device number 83 using tegra-xusb
[ 531.614771] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 531.822561] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 532.030139] usb 1-2: device not accepting address 83, error -22
[ 532.030239] usb usb1-port2: attempt power cycle
[ 532.882170] usb 1-2: new high-speed USB device number 84 using tegra-xusb
[ 533.002678] usb 1-2: device descriptor read/64, error -71
[ 533.251427] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 533.251451] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 533.251468] usb 1-2: Product: USB 2.0 Hub
[ 533.255401] hub 1-2:1.0: USB hub found
[ 533.255521] hub 1-2:1.0: 4 ports detected
[ 533.453829] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 533.453911] usb 1-2: USB disconnect, device number 84
[ 533.490181] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 533.754229] usb 1-2: new high-speed USB device number 85 using tegra-xusb
[ 533.754481] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 533.962347] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 534.170117] usb 1-2: device not accepting address 85, error -22
[ 534.290167] usb 1-2: new high-speed USB device number 86 using tegra-xusb
[ 534.311088] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 534.311110] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 534.311128] usb 1-2: Product: USB 2.0 Hub
[ 534.313490] hub 1-2:1.0: USB hub found
[ 534.313650] hub 1-2:1.0: 4 ports detected
[ 534.622274] usb 1-2.4: new low-speed USB device number 87 using tegra-xusb
[ 534.648087] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2005
[ 534.648104] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 534.648116] usb 1-2.4: Product: DELL USB Keyboard
[ 534.648128] usb 1-2.4: Manufacturer: DELL
[ 534.653730] input: DELL DELL USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2005.0092/input/input147
[ 534.710816] hid-generic 0003:413C:2005.0092: input,hidraw1: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 535.172594] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 535.172620] usb 1-2: USB disconnect, device number 86
[ 535.172625] usb 1-2.4: USB disconnect, device number 87
[ 535.263119] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 535.534194] usb 1-2: new high-speed USB device number 88 using tegra-xusb
[ 535.554951] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 535.554965] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 535.554975] usb 1-2: Product: USB 2.0 Hub
[ 535.556128] hub 1-2:1.0: USB hub found
[ 535.556203] hub 1-2:1.0: 4 ports detected
[ 535.754642] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 535.754684] usb 1-2: USB disconnect, device number 88
[ 535.790132] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 536.054232] usb 1-2: new high-speed USB device number 89 using tegra-xusb
[ 536.074971] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 536.074980] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 536.074986] usb 1-2: Product: USB 2.0 Hub
[ 536.076584] hub 1-2:1.0: USB hub found
[ 536.076697] hub 1-2:1.0: 4 ports detected
[ 536.381358] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 536.381385] usb 1-2: USB disconnect, device number 89
[ 536.390107] usb 1-2.4: new low-speed USB device number 90 using tegra-xusb
[ 536.390318] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 536.598365] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 536.806283] usb 1-2.4: device not accepting address 90, error -22
[ 536.806612] usb 1-2-port4: attempt power cycle
[ 537.124821] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 537.390168] usb 1-2: new high-speed USB device number 94 using tegra-xusb
[ 537.390423] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 537.598298] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 537.806099] usb 1-2: device not accepting address 94, error -22
[ 537.926107] usb 1-2: new high-speed USB device number 95 using tegra-xusb
[ 537.946643] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 537.946649] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 537.946653] usb 1-2: Product: USB 2.0 Hub
[ 537.947539] hub 1-2:1.0: USB hub found
[ 537.947610] hub 1-2:1.0: 4 ports detected
[ 538.154833] usb 1-2-port4: cannot reset (err = -71)
[ 538.154965] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 538.155043] usb 1-2: USB disconnect, device number 95
[ 538.155156] usb 1-2-port4: cannot reset (err = -71)
[ 538.155578] usb 1-2-port4: attempt power cycle
[ 538.476028] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 539.518442] usb usb1-port2: Cannot enable. Maybe the USB cable is bad?
[ 539.642760] usb 1-2: new high-speed USB device number 101 using tegra-xusb
[ 539.662530] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 539.662538] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 539.662544] usb 1-2: Product: USB 2.0 Hub
[ 539.663522] hub 1-2:1.0: USB hub found
[ 539.663593] hub 1-2:1.0: 4 ports detected
[ 539.876412] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 539.876457] usb 1-2: USB disconnect, device number 101
[ 539.898472] usb 1-2-port4: attempt power cycle
[ 540.217447] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 540.478120] usb 1-2: new high-speed USB device number 106 using tegra-xusb
[ 540.478417] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 540.686316] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 540.894108] usb 1-2: device not accepting address 106, error -22
[ 541.222193] usb 1-2: new high-speed USB device number 107 using tegra-xusb
[ 541.243272] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 541.243289] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 541.243301] usb 1-2: Product: USB 2.0 Hub
[ 541.244902] hub 1-2:1.0: USB hub found
[ 541.244971] hub 1-2:1.0: 4 ports detected
[ 541.408381] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 541.408463] usb 1-2: USB disconnect, device number 107
[ 541.450336] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 542.130135] usb 1-2: new high-speed USB device number 108 using tegra-xusb
[ 542.130530] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 542.338427] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 542.546423] usb 1-2: device not accepting address 108, error -22
[ 542.666109] usb 1-2: new high-speed USB device number 109 using tegra-xusb
[ 542.686561] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 542.686567] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 542.686571] usb 1-2: Product: USB 2.0 Hub
[ 542.687419] hub 1-2:1.0: USB hub found
[ 542.687493] hub 1-2:1.0: 4 ports detected
[ 542.879970] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 542.879996] usb 1-2: USB disconnect, device number 109
[ 542.914273] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 543.182192] usb 1-2: new high-speed USB device number 110 using tegra-xusb
[ 543.202990] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 543.202997] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 543.203001] usb 1-2: Product: USB 2.0 Hub
[ 543.203863] hub 1-2:1.0: USB hub found
[ 543.204969] hub 1-2:1.0: 4 ports detected
[ 543.444816] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 543.444910] usb 1-2: USB disconnect, device number 110
[ 543.450506] usb 1-2-port4: attempt power cycle
[ 543.768089] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 544.034951] usb 1-2: new high-speed USB device number 115 using tegra-xusb
[ 544.058909] usb 1-2: device descriptor read/8, error -71
[ 544.186909] usb 1-2: device descriptor read/8, error -71
[ 544.414197] usb 1-2: new high-speed USB device number 116 using tegra-xusb
[ 544.434856] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 544.434869] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 544.434879] usb 1-2: Product: USB 2.0 Hub
[ 544.436357] hub 1-2:1.0: USB hub found
[ 544.436429] hub 1-2:1.0: 4 ports detected
[ 544.638868] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 544.639027] usb 1-2: USB disconnect, device number 116
[ 544.678200] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 544.942216] usb 1-2: new high-speed USB device number 117 using tegra-xusb
[ 544.962813] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 544.962822] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 544.962827] usb 1-2: Product: USB 2.0 Hub
[ 544.963881] hub 1-2:1.0: USB hub found
[ 544.963965] hub 1-2:1.0: 4 ports detected
[ 545.069829] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 545.069862] usb 1-2: USB disconnect, device number 117
[ 545.106208] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 545.370145] usb 1-2: new high-speed USB device number 118 using tegra-xusb
[ 545.390732] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 545.390743] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 545.390750] usb 1-2: Product: USB 2.0 Hub
[ 545.391882] hub 1-2:1.0: USB hub found
[ 545.391952] hub 1-2:1.0: 4 ports detected
[ 545.533460] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 545.533558] usb 1-2: USB disconnect, device number 118
[ 545.606447] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 545.870138] usb 1-2: new high-speed USB device number 119 using tegra-xusb
[ 545.870389] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 546.078343] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 546.290082] usb 1-2: device not accepting address 119, error -22
[ 546.411117] usb 1-2: new high-speed USB device number 120 using tegra-xusb
[ 546.435490] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 546.435517] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 546.435537] usb 1-2: Product: USB 2.0 Hub
[ 546.438312] hub 1-2:1.0: USB hub found
[ 546.438435] hub 1-2:1.0: 4 ports detected
[ 546.624918] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 546.625055] usb 1-2: USB disconnect, device number 120
[ 546.662227] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 547.550312] usb 1-2: new high-speed USB device number 121 using tegra-xusb
[ 547.574747] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 547.574753] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 547.574756] usb 1-2: Product: USB 2.0 Hub
[ 547.576115] hub 1-2:1.0: USB hub found
[ 547.576282] hub 1-2:1.0: 4 ports detected
[ 547.882136] usb 1-2.4: new low-speed USB device number 122 using tegra-xusb
[ 547.907498] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2005
[ 547.907509] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 547.907516] usb 1-2.4: Product: DELL USB Keyboard
[ 547.907523] usb 1-2.4: Manufacturer: DELL
[ 547.913098] input: DELL DELL USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2005.0093/input/input148
[ 547.964357] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 547.964390] usb 1-2: USB disconnect, device number 121
[ 547.970803] hid-generic 0003:413C:2005.0093: input,hidraw1: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 547.971020] usb 1-2.4: USB disconnect, device number 122
[ 548.073928] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 548.334166] usb 1-2: new high-speed USB device number 123 using tegra-xusb
[ 548.358748] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 548.358759] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 548.358767] usb 1-2: Product: USB 2.0 Hub
[ 548.359935] hub 1-2:1.0: USB hub found
[ 548.360004] hub 1-2:1.0: 4 ports detected
[ 548.633944] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 548.634060] usb 1-2: USB disconnect, device number 123
[ 548.670172] usb 1-2.4: new low-speed USB device number 124 using tegra-xusb
[ 548.670423] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 548.878358] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 549.086131] usb 1-2.4: device not accepting address 124, error -22
[ 549.086324] usb 1-2-port4: attempt power cycle
[ 549.408079] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 549.678116] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 549.700699] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 549.700707] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 549.700712] usb 1-2: Product: USB 2.0 Hub
[ 549.702625] hub 1-2:1.0: USB hub found
[ 549.702700] hub 1-2:1.0: 4 ports detected
[ 549.930143] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 549.950761] usb 1-2: usb_suspend_both: status 0
[ 551.114222] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 551.270294] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 551.270317] usb 1-2: USB disconnect, device number 2
[ 551.286331] usb 1-2-port4: attempt power cycle
[ 551.605069] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 551.866327] usb 1-2: new high-speed USB device number 8 using tegra-xusb
[ 551.886542] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 551.886548] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 551.886552] usb 1-2: Product: USB 2.0 Hub
[ 551.890009] hub 1-2:1.0: USB hub found
[ 551.890130] hub 1-2:1.0: 4 ports detected
[ 552.078340] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 552.078366] usb 1-2: USB disconnect, device number 8
[ 552.122220] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 552.394215] usb 1-2: new high-speed USB device number 9 using tegra-xusb
[ 552.415199] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 552.415221] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 552.415237] usb 1-2: Product: USB 2.0 Hub
[ 552.416946] hub 1-2:1.0: USB hub found
[ 552.417020] hub 1-2:1.0: 4 ports detected
[ 552.660034] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 552.660080] usb 1-2: USB disconnect, device number 9
[ 552.662382] usb 1-2-port4: attempt power cycle
[ 552.980158] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 553.250259] usb 1-2: new high-speed USB device number 14 using tegra-xusb
[ 553.250860] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 553.458537] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 553.666134] usb 1-2: device not accepting address 14, error -22
[ 553.786111] usb 1-2: new high-speed USB device number 15 using tegra-xusb
[ 553.807126] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 553.807149] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 553.807165] usb 1-2: Product: USB 2.0 Hub
[ 553.810681] hub 1-2:1.0: USB hub found
[ 553.810771] hub 1-2:1.0: 4 ports detected
[ 553.968552] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 553.968579] usb 1-2: USB disconnect, device number 15
[ 554.002312] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 554.266108] usb 1-2: new high-speed USB device number 16 using tegra-xusb
[ 554.286489] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 554.286495] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 554.286498] usb 1-2: Product: USB 2.0 Hub
[ 554.287451] hub 1-2:1.0: USB hub found
[ 554.288693] hub 1-2:1.0: 4 ports detected
[ 554.363768] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 554.363806] usb 1-2: USB disconnect, device number 16
[ 554.398247] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 554.810109] usb 1-2: new high-speed USB device number 17 using tegra-xusb
[ 554.834902] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 554.834918] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 554.834931] usb 1-2: Product: USB 2.0 Hub
[ 554.836409] hub 1-2:1.0: USB hub found
[ 554.836478] hub 1-2:1.0: 4 ports detected
[ 554.984068] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 554.984177] usb 1-2: USB disconnect, device number 17
[ 555.018202] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 555.290105] usb 1-2: new high-speed USB device number 18 using tegra-xusb
[ 555.290325] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 555.498467] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 555.706190] usb 1-2: device not accepting address 18, error -22
[ 555.826210] usb 1-2: new high-speed USB device number 19 using tegra-xusb
[ 555.851197] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 555.851219] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 555.851235] usb 1-2: Product: USB 2.0 Hub
[ 555.853702] hub 1-2:1.0: USB hub found
[ 555.853878] hub 1-2:1.0: 4 ports detected
[ 555.920974] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 555.921017] usb 1-2: USB disconnect, device number 19
[ 555.962157] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 556.230314] usb 1-2: new high-speed USB device number 20 using tegra-xusb
[ 556.251476] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 556.251509] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 556.251532] usb 1-2: Product: USB 2.0 Hub
[ 556.253525] hub 1-2:1.0: USB hub found
[ 556.253595] hub 1-2:1.0: 4 ports detected
[ 556.532607] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 556.532838] usb 1-2: USB disconnect, device number 20
[ 556.566114] usb 1-2.4: new low-speed USB device number 21 using tegra-xusb
[ 556.566323] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 556.774370] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 556.982117] usb 1-2.4: device not accepting address 21, error -22
[ 556.982319] usb 1-2-port4: attempt power cycle
[ 557.301833] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 557.986146] usb 1-2: new high-speed USB device number 25 using tegra-xusb
[ 558.010891] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 558.010902] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 558.010909] usb 1-2: Product: USB 2.0 Hub
[ 558.012451] hub 1-2:1.0: USB hub found
[ 558.012669] hub 1-2:1.0: 4 ports detected
[ 558.227392] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 558.227430] usb 1-2: USB disconnect, device number 25
[ 558.238532] usb 1-2-port4: attempt power cycle
[ 558.557144] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 558.818192] usb 1-2: new high-speed USB device number 30 using tegra-xusb
[ 558.818463] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 559.027289] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 559.234362] usb 1-2: device not accepting address 30, error -22
[ 560.126361] usb usb1-port2: Cannot enable. Maybe the USB cable is bad?
[ 560.126441] usb usb1-port2: attempt power cycle
[ 561.818377] usb 1-2: new high-speed USB device number 32 using tegra-xusb
[ 561.958465] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 561.958472] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 561.958477] usb 1-2: Product: USB 2.0 Hub
[ 561.959439] hub 1-2:1.0: USB hub found
[ 561.959503] hub 1-2:1.0: 4 ports detected
[ 562.082109] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 562.102283] usb 1-2: usb_suspend_both: status 0
[ 562.522232] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 562.650433] usb 1-2: USB disconnect, device number 32
[ 562.918206] usb 1-2: new high-speed USB device number 33 using tegra-xusb
[ 562.939042] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 562.939056] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 562.939067] usb 1-2: Product: USB 2.0 Hub
[ 562.944899] hub 1-2:1.0: USB hub found
[ 562.944971] hub 1-2:1.0: 4 ports detected
[ 563.250153] usb 1-2.4: new low-speed USB device number 34 using tegra-xusb
[ 563.275484] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2005
[ 563.275491] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 563.275495] usb 1-2.4: Product: DELL USB Keyboard
[ 563.275498] usb 1-2.4: Manufacturer: DELL
[ 563.279739] input: DELL DELL USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2005.0094/input/input149
[ 563.338846] hid-generic 0003:413C:2005.0094: input,hidraw1: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 563.938317] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 563.938417] usb 1-2: USB disconnect, device number 33
[ 563.938442] usb 1-2.4: USB disconnect, device number 34
[ 564.044386] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 565.082209] usb usb1-port2: Cannot enable. Maybe the USB cable is bad?
[ 565.202104] usb 1-2: new high-speed USB device number 36 using tegra-xusb
[ 565.222946] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 565.222956] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 565.222964] usb 1-2: Product: USB 2.0 Hub
[ 565.226468] hub 1-2:1.0: USB hub found
[ 565.226588] hub 1-2:1.0: 4 ports detected
[ 565.405247] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 565.405278] usb 1-2: USB disconnect, device number 36
[ 565.442348] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 565.706124] usb 1-2: new high-speed USB device number 37 using tegra-xusb
[ 565.727322] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 565.727334] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 565.727342] usb 1-2: Product: USB 2.0 Hub
[ 565.728867] hub 1-2:1.0: USB hub found
[ 565.728959] hub 1-2:1.0: 4 ports detected
[ 565.737859] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 565.737883] usb 1-2: USB disconnect, device number 37
[ 565.774295] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 566.818219] usb usb1-port2: Cannot enable. Maybe the USB cable is bad?
[ 566.938267] usb 1-2: new high-speed USB device number 39 using tegra-xusb
[ 566.938852] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 567.146504] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 567.358172] usb 1-2: device not accepting address 39, error -22
[ 567.358245] usb usb1-port2: attempt power cycle
[ 569.814367] usb usb1-port2: Cannot enable. Maybe the USB cable is bad?
[ 569.934226] usb 1-2: new high-speed USB device number 41 using tegra-xusb
[ 570.075123] usb 1-2: device descriptor read/all, error -71
[ 570.075188] usb usb1-port2: unable to enumerate USB device
[ 570.075298] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 570.110262] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 570.374168] usb 1-2: new high-speed USB device number 42 using tegra-xusb
[ 570.374416] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 570.582530] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 570.790114] usb 1-2: device not accepting address 42, error -22
[ 571.682257] usb usb1-port2: Cannot enable. Maybe the USB cable is bad?
[ 571.682314] usb usb1-port2: attempt power cycle
[ 573.366159] usb 1-2: new high-speed USB device number 44 using tegra-xusb
[ 574.230784] usb 1-2: new high-speed USB device number 45 using tegra-xusb
[ 575.122353] usb usb1-port2: Cannot enable. Maybe the USB cable is bad?
[ 575.122426] usb usb1-port2: unable to enumerate USB device
[ 651.236786] tegradc tegradc.0: blank - powerdown
[ 651.292852] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 651.292854] Extcon AUX1(HDMI) disable
[ 677.944130] extcon-disp-state extcon:disp-state: cable 51 state 0
[ 677.945429] Extcon HDMI: HPD disabled
[ 677.945478] tegradc tegradc.0: hdmi: unplugged
[ 677.969968] tegradc tegradc.0: blank - powerdown
[ 677.969980] tegradc tegradc.0: unblank
[ 677.970007] tegradc tegradc.0: unblank
[ 677.970016] tegradc tegradc.1: blank - powerdown
[ 678.121664] tegradc tegradc.0: blank - powerdown
[ 678.121681] tegradc tegradc.0: unblank
[ 678.132120] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 678.133185] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 678.134239] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 678.134249] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 678.169066] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 678.169069] Extcon AUX1(HDMI) enable
[ 678.169203] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 678.169206] Extcon HDMI: HPD enabled
[ 678.169229] tegradc tegradc.0: hdmi: plugged
[ 678.207127] tegradc tegradc.0: blank - powerdown
[ 678.268063] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 678.268066] Extcon AUX1(HDMI) disable
[ 678.288383] tegradc tegradc.0: unblank
[ 678.298660] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 678.298741] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 678.299752] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 678.299759] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 678.336460] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 678.336463] Extcon AUX1(HDMI) enable
[ 678.336677] tegradc tegradc.0: unblank
[ 678.336684] tegradc tegradc.1: blank - powerdown
[ 678.490923] tegradc tegradc.0: unblank
[ 678.490933] tegradc tegradc.1: blank - powerdown
valmet@valmet-desktop:~
