How can i do this problem?
Every time see this words, so i’m serching this words , but i can’t find solution.
Could help me please?
sudo pip install tensorflow-addons
ERROR: Could not find a version that satisfies the requirement tensorflow-addons (from versions: none)
ERROR: No matching distribution found for tensorflow-addons
This means that there is no pre-built package for Jetson (arm/aarch64 architecture).
You need to install it from source. Good luck.
Um… one more porblem.
bazel doesn’t work it
bazel build --enable_runfiles build_pip_pkg
bazel-bin/build_pip_pkg artifacts
command not found or no dirctory and name.
bazel 3.4.1 version is not good?
what should i do bazel version?
Each TensorFlow version requires a specific Bazel-Build version, see the build instructions for your TF-version. Btw: building TF on the Nano will take 10+ hours…
The bazel problem was solved.
There was a problem in progress.
Install with cpu option.
The " tensorflow_addons-*.whl" file does not exist in artifacts.
should i just give up?
Its really hard :-(
Thank you for your help.
Output from Ubuntu
SyntaxError: invalid syntax
- true
- cp ‘dist/.whl’ /home/bb110/addons/artifacts
cp: cannot stat 'dist/.whl’: No such file or directory
Content inside the “Build_pip_pkg” shell
python ${BUILD_CMD} || true
else
python ${BUILD_CMD} ${NIGHTLY_FLAG} || true
fi
cp dist/*.whl “${DEST}”
popd
rm -rf ${TMPDIR}
echo $(date) : “=== Output wheel file is in: ${DEST}”
It looks like there is a similar topic on the TensorFlow addons GitHub:
https://github.com/tensorflow/addons/issues/1982
Please check it for information first.
Addons is really simple and speedy to compile
The setup.py just needs a hack for aarm64 but Raspberry Pi 64 OS + Jetson Nano configure.py by Qengineering · Pull Request #2420 · tensorflow/addons · GitHub qengineering is trying to get a pull request through.
But you just need to hack setup.py and then symlink to /usr/lib the pythonlib which setup.py will show location.
If thats a bit confusing use GitHub - Qengineering/TensorFlow-Addons-Jetson-Nano: TensorFlow Addons installation wheels for Jetson Nano
