Hello all,
I am trying to install TensorFlow 2 Object detection API
I first installed TensorFlow from the official TensorFlow topic in this forum
using the command below: sudo pip3 install --pre --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v44 tensorflow==2.3.1+nv20.12
The installation runs successfully, when I try to follow the TensorFlow official website to install object detection API https://github.com/tensorflow/models/blob/master/research/object_detection/g3doc/tf2.md
I get error when in the last command
ERROR: Could not find a version that satisfies the requirement tensorflow_io (from object-detection) (from versions: none)
ERROR: No matching distribution found for tensorflow_io
I tried to install tensorflow_io using pip but it returns the same error. sudo pip3 install tensorflow-io
I saw in another thread that you must build tensorflow-io from source but I do not know how?
Can someone help resolve this issue?
Thanks in advance
Jetpack 4.4.1
cuda 10.2
cuDNN 8.0
TensorRT 7.1.3.0
Hi AastaLLL;
Thanks for your reply
I tried building from source TensorFlow io but still getting the same error. I installed Bazel correctly but TensorFlow io throws the same error
could you please give me a step by step how to build it correctly
Your help is very appreciated
The error is caused by pip3.
Since there is no prebuilt available for ARM, please compile it from the source rather than using pip3.
I’ve done it from scrach using bazel from this link: TensorFlow I/O
And I’ve tried using docker still the same problem persists, so I commented every dependencies on tensorflow io, if you have clear steps on building it from source we’ll be grateful
