My Jetson Nano is crashing whenever i am trying to run normal yolov3 model or trying to convert into tensorrt engine. Recorded tegrastats and journalctl while crashing. Help me to solve this problem if anyone encountered the same.
tengrastats -
latest_tegrastats.txt (19.4 KB)
journalctl -
Uploading: journalctl.txt…
Specs:
Jetson Nano
Jetpack 4.6
torch 1.7
ram - 4gb
tensorrt 8.2
Dear @user71960,
Could you share the yolo model to reproduce?
Dear @user71960,
Could you please share the yolov3 ONNX model to reproduce the issue using trtexec?
https://drive.google.com/file/d/1ZILpCBfT6hqbtlv-eseexoi_aGOi8zyQ/view?usp=sharing
refrence link to reproduce error -
- git clone GitHub - linghu8812/YOLOv3-TensorRT
- python3 onnx_to_tensorrt.py --onnx_file yolov3.onnx --engine_file yolov3.trt
Dear @user71960,
we have yolov3 python sample(/usr/src/tensorrt/samples/python/yolov3_onnx) in TensorRT. Could you check if it helps in your use case?
Dear @user71960,
Does the yolov3 TensorRT sample helps?
Dear @user71960,
Do you still have this issue?
This project will install both yoloV3 and yoloV4 on a nano with one command in a way that won’t crash. It does require a USB connected SSD though:
https://github.com/hcfman/sbts-install
(If you had a bigger machine than a nano (8G or higher) it would also install scaled-yolov4, yolor and yolov7 again with one command).
Maybe that helps.
