I am in the middle of Getting Started with AI on Jetson Nano to download the docker but i am stuck here. May I know what is the problem as I’ve already follow the instruction from the DLI? I already did retry by removing the “docker_dli_run.sh” and adding it back but same problem occurs. Thank you
Hello there thank you for the response. However, after inserting the command this error occur. May i know what is the solution?
Error response from daemon: Get https://nvcr.io/v2/: EOF
Thank you!
Would like to ask does there any problem if the language setup was in en-UK but for the tag that is available is only in en-US? Would it be a problem that the image is not found? Thanks
