Jetson Nano - Error response from daemon: Get https://nvcr.io/v2/: EOF
when entering this command : sudo docker pull nvcr.io/nvidia/dli/dli-nano-ai:v2.0.2-r32.7.1
may i know why it is unable to find an image? Isn’t it supposed tho be downloaded during the session?
Could you double-check your network connection and test it again?
The command works well in our environment:
$ sudo docker pull nvcr.io/nvidia/dli/dli-nano-ai:v2.0.2-r32.7.1
v2.0.2-r32.7.1: Pulling from nvidia/dli/dli-nano-ai
f46992f278c2: Pulling fs layer
d0ec296fcb76: Pulling fs layer
9e18ddc8ca7a: Pulling fs layer
did tried to reconnect to other network and yet the error occurs the same
Unable to find image ‘nvcr.io/nvidia/dli/dli-nano-ai:v2.0.1-r32.7.1’ locally
docker: Error response from daemon: Get https://nvcr.io/v2/: x509: certificate has expired or is not yet valid.
been trying those solution there is on the internet but still no difference.
Please check if the below link helps:
