Hello, I have a custom-designed Jetson Nano board, and I am using the TCA9548 multiplexer for the camera connections on this board.
I have set up the necessary configurations on the Jetson Nano, and most features are working correctly. However, I am encountering issues with the CSI camera.
When I connect two IMX219 cameras, only one is detected, and only /dev/video0 is created, while /dev/video1 is not. Additionally, when I try to capture an image from /dev/video0, no output is received.
I am unsure whether this issue is caused by the device tree or a hardware-related problem.
On another board from a different manufacturer, where I set up everything the same way, the cameras work without any issues. The working board uses the TCA9544 chip as the I2C multiplexer, whereas my custom board uses the TCA9548.
My assumption is that the issue could be both hardware-related and require changes on the Device Tree side. Could you help me with this? I will share the necessary visuals and command outputs below.
Mux Circuit:
DTS File: this
i2cdetect -l
i2c-3 i2c 7000c700.i2c I2C adapter
i2c-1 i2c 7000c400.i2c I2C adapter
i2c-8 i2c i2c-6-mux (chan_id 1) I2C adapter
i2c-6 i2c Tegra I2C adapter I2C adapter
i2c-4 i2c 7000d000.i2c I2C adapter
i2c-2 i2c 7000c500.i2c I2C adapter
i2c-0 i2c 7000c000.i2c I2C adapter
i2c-9 i2c i2c-6-mux (chan_id 2) I2C adapter
i2c-10 i2c i2c-6-mux (chan_id 3) I2C adapter
i2c-7 i2c i2c-6-mux (chan_id 0) I2C adapter
i2c-5 i2c 7000d100.i2c I2C adapter
i2cdetect -y -r 6
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: UU -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: UU -- -- -- -- -- -- --
i2cdetect -y -r 7
i2cdetect -y -r 8
60: -- -- -- -- 64 -- -- -- -- -- -- -- -- -- -- --
i2cdetect -y -r 9
i2cdetect -y -r 10
dmesg | grep imx
[ 4.076744] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 4.113010] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 4.120541] imx219 7-0010: board setup failed
[ 4.125002] imx219: probe of 7-0010 failed with error -121
[ 4.131021] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 4.167262] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 4.174788] imx219 8-0010: board setup failed
[ 4.179219] imx219: probe of 8-0010 failed with error -121
dmesg | grep -i "video"
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200 console=tty0 fbcon=map:0 net.ifnames=0 pcie_aspm=off
[ 0.619108] Linux video capture interface: v2.00
