Hi all~
We need to use NX core board to develop a system with 3 camera, and 4 lanes output for each camera,we use 3 LT6911UXC (HDMI to MIPI/CSI) chips on the carrier board designed by ourselves, camera1 connects CSI0 2 lane + CSI1 2 lane, camera2 connects to CSI2 2 lane + CSI3 2 lane, camera3 connects to CSI4 4 lane. And mounted on three different i2c buses, as shown in the figure.
Is the description of our dts file correct? Thanks for giving tips.
#include <dt-bindings/media/camera.h>
host1x {
vi@15c10000 {
num-channels = <3>;
ports {
#address-cells = <1>;
#size-cells = <0>;
vi_port0: port@0 {
reg = <0>;
rbpcv2_lt6911_vi_in0: endpoint {
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&rbpcv2_lt6911_csi_out0>
status = “okay”;
vi_port1: port@1 {
reg = <1>;
rbpcv2_lt6911_vi_in1: endpoint {
port-index = <2>;
bus-width = <4>;
remote-endpoint = <&rbpcv2_lt6911_csi_out1>;
status = “okay”;
vi_port2: port@2 {
reg = <2>;
rbpcv2_lt6911_vi_in2: endpoint {
port-index = <4>;
bus-width = <4>;
remote-endpoint = <&rbpcv2_lt6911_csi_out2>;
status = “okay”;
nvcsi@15a00000 {
**num-channels = <3>;**
#size-cells = <0>;
status = "okay";
csi_chan0: channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
csi_chan0_port0: port@0 {
reg = <0>;
rbpcv2_lt6911_csi_in0: **endpoint@0** {
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&rbpcv2_lt6911_out0>;
status = "okay";
csi_chan0_port1: port@1 {
reg = <1>;
rbpcv2_lt6911_csi_out0: **endpoint@1** {
remote-endpoint = <&rbpcv2_lt6911_vi_in0>;
**status = "okay";**
csi_chan1: channel@1 {
reg = <1>;
ports {
#size-cells = <0>;
csi_chan1_port0: port@0 {
reg = <0>;
rbpcv2_lt6911_csi_in1: **endpoint@2** {
port-index = <2>;
bus-width = <4>;
remote-endpoint = <&rbpcv2_lt6911_out1>;
csi_chan1_port1: port@1 {
reg = <1>;
rbpcv2_lt6911_csi_out1: **endpoint@3** {
remote-endpoint = <&rbpcv2_lt6911_vi_in1>;
csi_chan2: channel@2 {
reg = <2>;
ports {
#size-cells = <0>;
csi_chan2_port0: port@0 {
reg = <0>;
rbpcv2_lt6911_csi_in2: **endpoint@4** {
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&rbpcv2_lt6911_out2>;
status = "okay";
csi_chan2_port1: port@1 {
reg = <1>;
rbpcv2_lt6911_csi_out2: **endpoint@5** {
remote-endpoint = <&rbpcv2_lt6911_vi_in2>;
i2c@3160000 {
lt6911_cam0: rbpcv2_lt6911_a@2b {
**compatible = "nvidia,lt6911uxc";**
/* I2C device address */
**reg = <0x2b>;**
/* V4L2 device node location */
devnode = "video0";
/* Physical dimensions of sensor */
physical_w = "5.6";
physical_h = "3.1";
sensor_model = "lt6911";
use_sensor_mode_id = "false";
mode0 { /* CS307_MODE_1920X1080_30FPS */
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
discontinuous_clk = "yes";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "1920";
active_h = "1080";
pixel_t = "yuv_uyvy16";
readout_orientation = "0";
line_length = "2200";
inherent_gain = "1";
mclk_multiplier = "2";
pix_clk_hz = "74250000";
gain_factor = "16";
framerate_factor = "1000000";
exposure_factor = "1000000";
min_gain_val = "16"; /* 1.00x */
max_gain_val = "170"; /* 10.66x */
step_gain_val = "1";
default_gain = "16"; /* 1.00x */
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_framerate = "2000000"; /* 2.0 fps */
max_framerate = "30000000"; /* 30 fps */
step_framerate = "1";
default_framerate = "30000000"; /* 30 fps */
min_exp_time = "13"; /* us */
max_exp_time = "333333"; /* us */
step_exp_time = "1";
default_exp_time = "2495"; /* us */
embedded_metadata_height = "0";
mode1 { /* CS307_MODE_1280X720_CROP_60FPS */
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "1280";
active_h = "720";
line_length = "1650";
gain_factor = "16";
max_framerate = "60000000"; /* 60 fps */
default_framerate = "60000000"; /* 60 fps */
max_exp_time = "166666"; /* us */
mode2 { /* CS307_MODE_640X480_CROP_130FPS */
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "640";
active_h = "480";
line_length = "1100";
gain_factor = "16";
max_framerate = "130000000"; /* 130 fps */
default_framerate = "130000000"; /* 130 fps */
max_exp_time = "7692"; /* us */
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
rbpcv2_lt6911_out0: endpoint {
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&rbpcv2_lt6911_csi_in0>;
i2c@c240000 {
lt6911_cam1: rbpcv2_lt6911_b@2b {
**reg = <0x2b>;**
devnode = "video1";
physical_w = "5.6";
physical_h = "3.1";
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1080";
gain_factor = "16";
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "1280";
active_h = "720";
gain_factor = "16";
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "640";
active_h = "480";
gain_factor = "16";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
rbpcv2_lt6911_out1: endpoint {
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&rbpcv2_lt6911_csi_in1>;
i2c@3180000 {
lt6911_cam2: rbpcv2_lt6911_c@2b {
**reg = <0x2b>;**
devnode = "video2";
physical_w = "5.6";
physical_h = "3.1";
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1080";
gain_factor = "16";
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "1280";
active_h = "720";
gain_factor = "16";
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "640";
active_h = "480";
gain_factor = "16";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
rbpcv2_lt6911_out2: endpoint {
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&rbpcv2_lt6911_csi_in2>;
tcp: tegra-camera-platform {
compatible = “nvidia, tegra-camera-platform”;
**num_csi_lanes = <12>;**
max_lane_speed = <1500000>;
min_bits_per_pixel = <8>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <240000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. "rear" or "front".
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vendor.
modules {
cam_module0: module0 {
**badge = "jakku_bottom_lt6911";**
position = "bottom";
orientation = "1";
cam_module0_drivernode0: drivernode0 {
pcl_id = "v4l2_sensor";
devname = "lt6911 0-002b";
proc-device-tree = "/proc/device-tree/i2c@3160000/rbpcv2_lt6911_a@2b";
cam_module1: module1 {
**badge = "jakku_center_lt6911";**
position = "center";
orientation = "1";
cam_module1_drivernode0: drivernode0 {
devname = "lt6911 1-002b";
proc-device-tree = "/proc/device-tree/i2c@c240000/rbpcv2_lt6911_b@2b";
cam_module2: module2 {
**badge = "jakku_top_lt6911";**
position = "top";
orientation = "1";
cam_module2_drivernode0: drivernode0 {
devname = "lt6911 2-002b";
proc-device-tree = "/proc/device-tree/i2c@3180000/rbpcv2_lt6911_c@2b";
