Jetson Nano ethernet USB3.0 adaptor error when "insmod ax88179_178a.ko" : Device or resource busy
Hi all,
I have an ethernet camera and want to connect to the Jetson Nano via USB port. Therefore, I have bought an Asix AX88179 ethernet-USB3.0 adaptor for this purpose.
I first downloaded the driver from ASIX Electronics Corporation (Linux kernel 5.x/4.x/3.x/2.6.x Driver). Then, I followed the instruction in the Readme file:
  1. tar -xf DRIVER_SOURCE_PACKAGE.tar.bz2
  2. sudo make
  3. sudo make install
  4. sudo modprobe usbnet
  5. sudo insmod ax88179_178a.ko
insmod: ERROR: could not insert module ax88179_178a.ko: Device or resource busy
>> cat /proc/devices
Character devices:
510 ttyGS
  1 mem
511 vfio
  2 pty
  3 ttyp
  4 /dev/vc/0
  4 tty
  4 ttyS
  5 /dev/tty
  5 /dev/console
  5 /dev/ptmx
  7 vcs
 10 misc
 13 input
 29 fb
 81 video4linux
 89 i2c
 90 mtd
108 ppp
116 alsa
128 ptm
136 pts
180 usb
188 ttyUSB
189 usb_device
226 drm
235 pgtool
236 nvme
237 ttyTHS
238 ttyTHS
239 tegra_dc_ext
240 bsg
241 hmm_device
242 nvhost
242 nvhost
242 nvhost
242 nvhost
242 nvhost
242 nvhost
242 nvhost
242 nvhost
242 nvhost
242 nvhost
243 camchar
244 watchdog
245 trusty_ipc
246 iio
247 ptp
248 pps
249 capture-isp-channel
250 capture-vi-channel
251 media
506 57000000.gpu
252 rtc
507 stepper
253 tegra-vi-channel
508 roccat
254 gpiochip
509 hidraw
Block devices:
  1 ramdisk
259 blkext
  7 loop
  8 sd
 31 mtdblock
 65 sd
 66 sd
 67 sd
 68 sd
 69 sd
 70 sd
 71 sd
128 sd
129 sd
130 sd
131 sd
132 sd
133 sd
134 sd
135 sd
179 mmc
252 zram
253 device-mapper
254 virtblk
Can anyone help to solve this problem?
Also, there is another problem in using the adaptor. When I plug in the adaptor to the Jetson Nano, my mouse is very lag and even no response while my keyboard still work very nice (Keyboard and mouse are bluetooth using same USB port). I unplug the adaptor, everything works fine again.
Thank you.
Check the dmesg and see what error got printed after insmod tells you device is busy.
Thank you for your reply. The error messages are listed below:
>> dmesg | grep ax88
[  251.325986] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[  251.550628] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[  251.673184] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x0006: -32
[  251.693296] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0005: -32
[  251.710905] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[  251.729298] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[  251.746463] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[  251.764638] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[  251.782470] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[  251.802141] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[  251.822337] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[  251.841018] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x0001: -32
[  251.858277] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[  251.875454] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -32
[  251.891536] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0019: -32
[  251.908727] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -32
[  251.926239] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[  251.944887] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[  251.962286] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[  251.979576] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x000e: -32
[  251.995549] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[  252.012743] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[  252.029928] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[  252.046170] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[  252.063325] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x0000: -32
[  252.080639] ax88179_178a 2-1.3:2.1 eth2: register 'ax88179_178a' at usb-70090000.xusb-1.3, ASIX AX88179 USB 3.0 Gigabit Ethernet, 76:1a:d2:65:c8:f4
[  252.202252] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0002: -32
[  252.216926] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0002: -32
[  252.439520] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0001: -32
[  252.562254] ax88179_178a 2-1.3:2.1 eth2: Failed to read reg index 0x0001: -32
[  252.576853] ax88179_178a 2-1.3:2.1 eth2: Failed to read reg index 0x0006: -32
[  252.591477] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0005: -32
[  252.606129] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0001: -32
[  252.618083] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0001: -32
[  252.632767] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0001: -32
[  252.647393] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0001: -32
[  252.662053] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0002: -32
[  252.673983] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0001: -32
[  252.688578] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0002: -32
[  252.703418] ax88179_178a 2-1.3:2.1 eth2: Failed to read reg index 0x0001: -32
[  252.718244] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0001: -32
[  252.734270] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x001f: -32
[  252.749179] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0019: -32
[  252.763945] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x001f: -32
[  252.778508] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x000d: -32
[  252.794540] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x000e: -32
[  252.809446] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x000d: -32
[  252.826599] ax88179_178a 2-1.3:2.1 eth2: Failed to read reg index 0x000e: -32
[  252.843217] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x000d: -32
[  252.857601] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x000e: -32
[  252.872387] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x000d: -32
[  252.887269] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x000e: -32
[  252.903374] ax88179_178a 2-1.3:2.1 eth2: Failed to read reg index 0x0000: -32
[  252.920716] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0000: -32
[  252.967550] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0002: -32
[  252.982338] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0002: -32
[  253.202269] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0001: -32
[  253.326669] ax88179_178a 2-1.3:2.0 eth1: Failed to read reg index 0x0001: -32
[  253.341233] ax88179_178a 2-1.3:2.0 eth1: Failed to read reg index 0x0006: -32
[  253.356062] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0005: -32
[  253.370685] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0001: -32
[  253.382574] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0001: -32
[  253.397299] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0001: -32
[  253.412081] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0001: -32
[  253.426714] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0002: -32
[  253.438467] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0001: -32
[  253.454511] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0002: -32
[  253.468083] ax88179_178a 2-1.3:2.0 eth1: Failed to read reg index 0x0001: -32
[  253.482732] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0001: -32
[  253.494526] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x001f: -32
[  253.509270] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0019: -32
[  253.523944] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x001f: -32
[  253.538583] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x000d: -32
[  253.550502] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x000e: -32
[  253.565330] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x000d: -32
[  253.580002] ax88179_178a 2-1.3:2.0 eth1: Failed to read reg index 0x000e: -32
[  253.594800] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x000d: -32
[  253.606767] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x000e: -32
[  253.621377] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x000d: -32
[  253.636149] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x000e: -32
[  253.650774] ax88179_178a 2-1.3:2.0 eth1: Failed to read reg index 0x0000: -32
[  253.662723] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0000: -32
[  254.750513] ax88179_178a 2-1.3:2.0 eth1: unregister 'ax88179_178a' usb-70090000.xusb-1.3, ASIX AX88179 USB 3.0 Gigabit Ethernet
[  254.762685] ax88179_178a 2-1.3:2.0 eth1: Failed to read reg index 0x0002: -71
[  254.782327] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0002: -71
[  254.830669] ax88179_178a 2-1.3:2.0 eth1 (unregistered): Failed to write reg index 0x0002: -71
[  254.851633] ax88179_178a 2-1.3:2.0 eth1 (unregistered): Failed to write reg index 0x0001: -71
[  254.874291] ax88179_178a 2-1.3:2.0 eth1 (unregistered): Failed to write reg index 0x0002: -71
[  254.883177] ax88179_178a 2-1.3:2.1 eth2: unregister 'ax88179_178a' usb-70090000.xusb-1.3, ASIX AX88179 USB 3.0 Gigabit Ethernet
[  254.895299] ax88179_178a 2-1.3:2.1 eth2: Failed to read reg index 0x0002: -71
[  254.914979] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0002: -71
[  254.958575] ax88179_178a 2-1.3:2.1 eth2 (unregistered): Failed to write reg index 0x0002: -71
[  254.979456] ax88179_178a 2-1.3:2.1 eth2 (unregistered): Failed to write reg index 0x0001: -71
[  255.000397] ax88179_178a 2-1.3:2.1 eth2 (unregistered): Failed to write reg index 0x0002: -71
[  255.427952] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[  255.439709] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[  255.654522] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[  255.774419] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0006: -19
[  255.785111] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0005: -19
[  255.795635] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[  255.806652] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[  255.816749] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[  255.827113] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[  255.838066] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[  255.849061] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[  255.860125] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[  255.870255] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0001: -19
[  255.880318] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[  255.890625] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -19
[  255.901475] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0019: -19
[  255.912093] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -19
[  255.922553] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[  255.933200] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -19
[  255.943379] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[  255.953545] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x000e: -19
[  255.965000] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[  255.976039] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -19
[  255.986322] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[  255.996570] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -19
[  256.007333] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0000: -19
[  256.022490] ax88179_178a 2-1.3:2.0 eth1: register 'ax88179_178a' at usb-70090000.xusb-1.3, ASIX AX88179 USB 3.0 Gigabit Ethernet, 76:1a:d2:65:c8:f4
[  256.024267] ax88179_178a 2-1.3:2.0 eth1: unregister 'ax88179_178a' usb-70090000.xusb-1.3, ASIX AX88179 USB 3.0 Gigabit Ethernet
[  256.054777] ax88179_178a 2-1.3:2.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[  256.063465] ax88179_178a 2-1.3:2.0 eth1 (unregistered): Failed to write reg index 0x0001: -19
[  256.072044] ax88179_178a 2-1.3:2.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[  257.345673] ax88179_178a 2-1.3:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0040: -32
[  257.667303] ax88179_178a 2-1.3:1.0 eth1: register 'ax88179_178a' at usb-70090000.xusb-1.3, ASIX AX88179 USB 3.0 Gigabit Ethernet, f8:e4:3b:a9:3e:ac
[  258.290554] ax88179_178a 2-1.3:1.0 eth1: Failed to read reg index 0x0040: -32
[ 1346.884460] ax88179_178a 2-1.3:1.0 eth1: unregister 'ax88179_178a' usb-70090000.xusb-1.3, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 1346.884526] ax88179_178a 2-1.3:1.0 eth1: Failed to read reg index 0x0002: -19
[ 1346.892182] ax88179_178a 2-1.3:1.0 eth1: Failed to write reg index 0x0002: -19
[ 1346.928483] ax88179_178a 2-1.3:1.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 1346.937156] ax88179_178a 2-1.3:1.0 eth1 (unregistered): Failed to write reg index 0x0001: -19
[ 1346.945883] ax88179_178a 2-1.3:1.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 1792.344070] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 1792.361271] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 1792.585669] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1792.709293] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0006: -32
[ 1792.726361] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0005: -32
[ 1792.745532] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1792.765082] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1792.785131] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1792.804445] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1792.820987] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 1792.840664] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1792.863183] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 1792.879268] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0001: -32
[ 1792.899155] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1792.920466] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -32
[ 1792.940261] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0019: -32
[ 1792.958266] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -32
[ 1792.976219] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 1792.993347] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 1793.010554] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 1793.029286] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x000e: -32
[ 1793.046571] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 1793.063999] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 1793.082578] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 1793.099786] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 1793.117003] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0000: -32
[ 1793.137020] ax88179_178a 2-1.4:2.0 eth1: register 'ax88179_178a' at usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet, 76:1a:d2:65:c8:f4
[ 1793.218713] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 1793.236058] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 1793.460633] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1793.585723] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x0006: -32
[ 1793.603293] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0005: -32
[ 1793.620557] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1793.639290] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1793.656576] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1793.676708] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1793.695124] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 1793.712323] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1793.729512] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 1793.745751] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x0001: -32
[ 1793.763108] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 1793.780253] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -32
[ 1793.796332] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0019: -32
[ 1793.813577] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -32
[ 1793.830777] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 1793.849411] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 1793.866588] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 1793.884108] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x000e: -32
[ 1793.902743] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 1793.920087] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 1793.939962] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 1793.958642] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 1793.978547] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x0000: -32
[ 1793.998387] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0000: -32
[ 1794.009884] ax88179_178a 2-1.4:2.1 eth2: register 'ax88179_178a' at usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet, 76:1a:d2:65:c8:f4
[ 1794.206477] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0002: -32
[ 1794.222566] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0002: -32
[ 1794.448295] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0001: -32
[ 1794.569134] ax88179_178a 2-1.4:2.0 eth1: Failed to read reg index 0x0001: -32
[ 1794.583657] ax88179_178a 2-1.4:2.0 eth1: Failed to read reg index 0x0006: -32
[ 1794.595602] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0005: -32
[ 1794.610204] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0001: -32
[ 1794.624885] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0001: -32
[ 1794.642081] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0001: -32
[ 1794.653874] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0001: -32
[ 1794.668518] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0002: -32
[ 1794.683224] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0001: -32
[ 1794.697775] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0002: -32
[ 1794.709606] ax88179_178a 2-1.4:2.0 eth1: Failed to read reg index 0x0001: -32
[ 1794.724354] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0001: -32
[ 1794.739768] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x001f: -32
[ 1794.754000] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0019: -32
[ 1794.770095] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x001f: -32
[ 1794.787391] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x000d: -32
[ 1794.801876] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x000e: -32
[ 1794.817944] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x000d: -32
[ 1794.832613] ax88179_178a 2-1.4:2.0 eth1: Failed to read reg index 0x000e: -32
[ 1794.847714] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x000d: -32
[ 1794.862172] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x000e: -32
[ 1794.878265] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x000d: -32
[ 1794.895473] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x000e: -32
[ 1794.910130] ax88179_178a 2-1.4:2.0 eth1: Failed to read reg index 0x0000: -32
[ 1794.927231] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0000: -32
[ 1794.972320] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0002: -32
[ 1794.988513] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0002: -32
[ 1795.213214] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0001: -32
[ 1795.333757] ax88179_178a 2-1.4:2.1 eth2: Failed to read reg index 0x0001: -32
[ 1795.349624] ax88179_178a 2-1.4:2.1 eth2: Failed to read reg index 0x0006: -32
[ 1795.367267] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0005: -32
[ 1795.382229] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0001: -32
[ 1795.396710] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0001: -32
[ 1795.412589] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0001: -32
[ 1795.430364] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0001: -32
[ 1795.445255] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0002: -32
[ 1795.460988] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0001: -32
[ 1795.475625] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0002: -32
[ 1795.490386] ax88179_178a 2-1.4:2.1 eth2: Failed to read reg index 0x0001: -32
[ 1795.504985] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0001: -32
[ 1795.521192] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x001f: -32
[ 1795.535745] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0019: -32
[ 1795.550335] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x001f: -32
[ 1795.564963] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x000d: -32
[ 1795.576966] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x000e: -32
[ 1795.591590] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x000d: -32
[ 1795.606794] ax88179_178a 2-1.4:2.1 eth2: Failed to read reg index 0x000e: -32
[ 1795.620991] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x000d: -32
[ 1795.632934] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x000e: -32
[ 1795.647618] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x000d: -32
[ 1795.662214] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x000e: -32
[ 1795.676839] ax88179_178a 2-1.4:2.1 eth2: Failed to read reg index 0x0000: -32
[ 1795.688795] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0000: -32
[ 1796.783601] ax88179_178a 2-1.4:2.0 eth1: unregister 'ax88179_178a' usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 1796.783710] ax88179_178a 2-1.4:2.0 eth1: Failed to read reg index 0x0002: -19
[ 1796.791619] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0002: -19
[ 1796.825174] ax88179_178a 2-1.4:2.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 1796.833910] ax88179_178a 2-1.4:2.0 eth1 (unregistered): Failed to write reg index 0x0001: -19
[ 1796.842531] ax88179_178a 2-1.4:2.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 1796.851324] ax88179_178a 2-1.4:2.1 eth2: unregister 'ax88179_178a' usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 1796.851355] ax88179_178a 2-1.4:2.1 eth2: Failed to read reg index 0x0002: -19
[ 1796.858638] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0002: -19
[ 1796.889201] ax88179_178a 2-1.4:2.1 eth2 (unregistered): Failed to write reg index 0x0002: -19
[ 1796.897952] ax88179_178a 2-1.4:2.1 eth2 (unregistered): Failed to write reg index 0x0001: -19
[ 1796.906689] ax88179_178a 2-1.4:2.1 eth2 (unregistered): Failed to write reg index 0x0002: -19
[ 1798.171181] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0040: -32
[ 1798.491698] ax88179_178a 2-1.4:1.0 eth1: register 'ax88179_178a' at usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet, f8:e4:3b:a9:3e:ac
[ 1799.113459] ax88179_178a 2-1.4:1.0 eth1: Failed to read reg index 0x0040: -32
[ 1817.596080] ax88179_178a: loading out-of-tree module taints kernel.
[ 1817.603320] Error: Driver 'ax88179_178a' is already registered, aborting...
[ 2039.060452] Error: Driver 'ax88179_178a' is already registered, aborting...
[ 2211.403038] Error: Driver 'ax88179_178a' is already registered, aborting...
[ 2401.935771] ax88179_178a 2-1.4:1.0 eth1: unregister 'ax88179_178a' usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 2401.948157] ax88179_178a 2-1.4:1.0 eth1: Failed to read reg index 0x0002: -71
[ 2401.967802] ax88179_178a 2-1.4:1.0 eth1: Failed to write reg index 0x0002: -71
[ 2402.014091] ax88179_178a 2-1.4:1.0 eth1 (unregistered): Failed to write reg index 0x0002: -71
[ 2402.034785] ax88179_178a 2-1.4:1.0 eth1 (unregistered): Failed to write reg index 0x0001: -71
[ 2402.055586] ax88179_178a 2-1.4:1.0 eth1 (unregistered): Failed to write reg index 0x0002: -71
[ 2402.749489] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 2402.759576] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 2402.973981] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 2403.093956] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0006: -19
[ 2403.104213] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0005: -19
[ 2403.119330] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 2403.130348] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 2403.141132] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 2403.151244] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 2403.161471] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 2403.171672] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 2403.181731] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 2403.192054] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0001: -19
[ 2403.202022] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 2403.212149] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -19
[ 2403.222380] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0019: -19
[ 2403.232558] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -19
[ 2403.242759] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 2403.252959] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -19
[ 2403.263338] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 2403.273612] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x000e: -19
[ 2403.283599] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 2403.293656] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -19
[ 2403.303693] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 2403.313791] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -19
[ 2403.323886] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0000: -19
[ 2403.335958] ax88179_178a 2-1.4:1.0 eth1: register 'ax88179_178a' at usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet, 76:1a:d2:65:c8:f4
[ 2403.336549] ax88179_178a 2-1.4:1.0 eth1: unregister 'ax88179_178a' usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 2403.357974] ax88179_178a 2-1.4:1.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 2403.366589] ax88179_178a 2-1.4:1.0 eth1 (unregistered): Failed to write reg index 0x0001: -19
[ 2403.375224] ax88179_178a 2-1.4:1.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 2613.446493] Error: Driver 'ax88179_178a' is already registered, aborting...
[ 2634.086012] Error: Driver 'ax88179_178a' is already registered, aborting...
[ 5313.644592] Error: Driver 'ax88179_178a' is already registered, aborting...
[ 5409.880493] Error: Driver 'ax88179_178a' is already registered, aborting...
[ 6064.734674] Error: Driver 'ax88179_178a' is already registered, aborting...
[ 6301.248213] Error: Driver 'ax88179_178a' is already registered, aborting...
[ 6455.783385] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 6455.801041] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 6456.022848] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 6456.146193] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0006: -32
[ 6456.163566] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0005: -32
[ 6456.182161] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 6456.199329] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 6456.216515] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 6456.235326] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 6456.252671] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 6456.269497] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 6456.288090] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 6456.308772] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0001: -32
[ 6456.325389] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 6456.343838] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -32
[ 6456.361044] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0019: -32
[ 6456.378233] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -32
[ 6456.394298] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 6456.411439] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 6456.428703] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 6456.444667] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x000e: -32
[ 6456.461881] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 6456.483272] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 6456.500244] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 6456.517461] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 6456.534713] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0000: -32
[ 6456.545398] ax88179_178a 2-1.4:2.0 eth1: register 'ax88179_178a' at usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet, 76:1a:d2:65:c8:f4
[ 6456.623098] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 6456.640290] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 6456.864429] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 6456.990355] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x0006: -32
[ 6457.009185] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0005: -32
[ 6457.026404] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 6457.045021] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 6457.062219] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 6457.079516] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 6457.095489] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 6457.112838] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 6457.130039] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 6457.148827] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x0001: -32
[ 6457.166018] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 6457.183419] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -32
[ 6457.199493] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0019: -32
[ 6457.217011] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -32
[ 6457.234195] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 6457.252989] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 6457.270201] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 6457.287386] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x000e: -32
[ 6457.303446] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 6457.320675] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 6457.337818] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 6457.356766] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 6457.373886] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x0000: -32
[ 6457.385389] ax88179_178a 2-1.4:2.1 eth2: register 'ax88179_178a' at usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet, 76:1a:d2:65:c8:f4
[ 6457.605415] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0002: -32
[ 6457.621445] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0002: -32
[ 6457.846020] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0001: -32
[ 6457.967970] ax88179_178a 2-1.4:2.0 eth1: Failed to read reg index 0x0001: -32
[ 6457.984048] ax88179_178a 2-1.4:2.0 eth1: Failed to read reg index 0x0006: -32
[ 6457.998846] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0005: -32
[ 6458.013817] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0001: -32
[ 6458.028033] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0001: -32
[ 6458.046823] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0001: -32
[ 6458.061659] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0001: -32
[ 6458.076316] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0002: -32
[ 6458.092594] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0001: -32
[ 6458.107326] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0002: -32
[ 6458.122115] ax88179_178a 2-1.4:2.0 eth1: Failed to read reg index 0x0001: -32
[ 6458.137018] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0001: -32
[ 6458.153212] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x001f: -32
[ 6458.167793] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0019: -32
[ 6458.182417] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x001f: -32
[ 6458.197077] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x000d: -32
[ 6458.208865] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x000e: -32
[ 6458.223464] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x000d: -32
[ 6458.238410] ax88179_178a 2-1.4:2.0 eth1: Failed to read reg index 0x000e: -32
[ 6458.253091] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x000d: -32
[ 6458.269227] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x000e: -32
[ 6458.283837] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x000d: -32
[ 6458.298403] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x000e: -32
[ 6458.313238] ax88179_178a 2-1.4:2.0 eth1: Failed to read reg index 0x0000: -32
[ 6458.329123] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0000: -32
[ 6458.376405] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0002: -32
[ 6458.391031] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0002: -32
[ 6458.613350] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0001: -32
[ 6458.734209] ax88179_178a 2-1.4:2.1 eth2: Failed to read reg index 0x0001: -32
[ 6458.749714] ax88179_178a 2-1.4:2.1 eth2: Failed to read reg index 0x0006: -32
[ 6458.764346] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0005: -32
[ 6458.778911] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0001: -32
[ 6458.793944] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0001: -32
[ 6458.805668] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0001: -32
[ 6458.820494] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0001: -32
[ 6458.835298] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0002: -32
[ 6458.850257] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0001: -32
[ 6458.866590] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0002: -32
[ 6458.880819] ax88179_178a 2-1.4:2.1 eth2: Failed to read reg index 0x0001: -32
[ 6458.895336] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0001: -32
[ 6458.909972] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x001f: -32
[ 6458.921771] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0019: -32
[ 6458.936406] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x001f: -32
[ 6458.951238] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x000d: -32
[ 6458.965918] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x000e: -32
[ 6458.977848] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x000d: -32
[ 6458.992491] ax88179_178a 2-1.4:2.1 eth2: Failed to read reg index 0x000e: -32
[ 6459.007308] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x000d: -32
[ 6459.021936] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x000e: -32
[ 6459.035082] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x000d: -32
[ 6459.048457] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x000e: -32
[ 6459.063208] ax88179_178a 2-1.4:2.1 eth2: Failed to read reg index 0x0000: -32
[ 6459.077723] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0000: -32
[ 6460.158878] ax88179_178a 2-1.4:2.0 eth1: unregister 'ax88179_178a' usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 6460.171161] ax88179_178a 2-1.4:2.0 eth1: Failed to read reg index 0x0002: -71
[ 6460.190844] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0002: -71
[ 6460.231337] ax88179_178a 2-1.4:2.0 eth1 (unregistered): Failed to write reg index 0x0002: -71
[ 6460.252165] ax88179_178a 2-1.4:2.0 eth1 (unregistered): Failed to write reg index 0x0001: -71
[ 6460.273039] ax88179_178a 2-1.4:2.0 eth1 (unregistered): Failed to write reg index 0x0002: -71
[ 6460.281724] ax88179_178a 2-1.4:2.1 eth2: unregister 'ax88179_178a' usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 6460.293900] ax88179_178a 2-1.4:2.1 eth2: Failed to read reg index 0x0002: -71
[ 6460.313366] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0002: -71
[ 6460.363428] ax88179_178a 2-1.4:2.1 eth2 (unregistered): Failed to write reg index 0x0002: -71
[ 6460.384265] ax88179_178a 2-1.4:2.1 eth2 (unregistered): Failed to write reg index 0x0001: -71
[ 6460.405177] ax88179_178a 2-1.4:2.1 eth2 (unregistered): Failed to write reg index 0x0002: -71
[ 6460.839965] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 6460.850282] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 6461.067180] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 6461.183163] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0006: -19
[ 6461.194343] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0005: -19
[ 6461.205586] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 6461.215946] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 6461.227211] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 6461.237383] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 6461.247531] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 6461.257703] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 6461.267934] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 6461.278267] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0001: -19
[ 6461.288401] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 6461.298595] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -19
[ 6461.308861] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0019: -19
[ 6461.319076] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -19
[ 6461.329262] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 6461.339432] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -19
[ 6461.349661] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 6461.360074] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x000e: -19
[ 6461.370261] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 6461.380545] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -19
[ 6461.390746] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 6461.400901] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -19
[ 6461.411180] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0000: -19
[ 6461.422450] ax88179_178a 2-1.4:2.0 eth1: register 'ax88179_178a' at usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet, 76:1a:d2:65:c8:f4
[ 6461.424494] ax88179_178a 2-1.4:2.0 eth1: unregister 'ax88179_178a' usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 6461.443242] ax88179_178a 2-1.4:2.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 6461.451987] ax88179_178a 2-1.4:2.0 eth1 (unregistered): Failed to write reg index 0x0001: -19
[ 6461.460975] ax88179_178a 2-1.4:2.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 6462.738735] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0040: -32
[ 6463.056153] ax88179_178a 2-1.4:1.0 eth1: register 'ax88179_178a' at usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet, f8:e4:3b:a9:3e:ac
[ 6463.748617] ax88179_178a 2-1.4:1.0 eth1: Failed to read reg index 0x0040: -32
[ 6477.247048] Error: Driver 'ax88179_178a' is already registered, aborting...
[ 6509.520880] ax88179_178a 2-1.4:1.0 eth1: unregister 'ax88179_178a' usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 6509.533414] ax88179_178a 2-1.4:1.0 eth1: Failed to read reg index 0x0002: -71
[ 6509.554917] ax88179_178a 2-1.4:1.0 eth1: Failed to write reg index 0x0002: -71
[ 6509.594399] ax88179_178a 2-1.4:1.0 eth1 (unregistered): Failed to write reg index 0x0002: -71
[ 6509.615264] ax88179_178a 2-1.4:1.0 eth1 (unregistered): Failed to write reg index 0x0001: -71
[ 6509.636158] ax88179_178a 2-1.4:1.0 eth1 (unregistered): Failed to write reg index 0x0002: -71
[ 6510.337711] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 6510.348365] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 6510.570300] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 6510.690546] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0006: -19
[ 6510.702593] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0005: -19
[ 6510.712810] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 6510.722972] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 6510.734214] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 6510.744372] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 6510.754388] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 6510.765505] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 6510.776264] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 6510.786342] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0001: -19
[ 6510.796458] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 6510.807151] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -19
[ 6510.817740] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0019: -19
[ 6510.827881] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -19
[ 6510.838124] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 6510.848383] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -19
[ 6510.858567] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 6510.868751] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x000e: -19
[ 6510.878985] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 6510.889368] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -19
[ 6510.899589] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 6510.909840] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -19
[ 6510.920039] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0000: -19
[ 6510.930547] ax88179_178a 2-1.4:1.0 eth1: register 'ax88179_178a' at usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet, 76:1a:d2:65:c8:f4
[ 6510.931180] ax88179_178a 2-1.4:1.0 eth1: unregister 'ax88179_178a' usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 6510.950429] ax88179_178a 2-1.4:1.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 6510.959066] ax88179_178a 2-1.4:1.0 eth1 (unregistered): Failed to write reg index 0x0001: -19
[ 6510.967641] ax88179_178a 2-1.4:1.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 6858.198155] Error: Driver 'ax88179_178a' is already registered, aborting...
[ 7002.659780] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 7002.677504] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 7002.904650] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7003.039206] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0006: -32
[ 7003.056584] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0005: -32
[ 7003.073832] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7003.092586] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7003.109885] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7003.127467] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7003.146048] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 7003.164288] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7003.180792] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 7003.199372] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0001: -32
[ 7003.216529] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7003.233750] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -32
[ 7003.252379] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0019: -32
[ 7003.269547] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -32
[ 7003.286760] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 7003.305540] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 7003.325437] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 7003.342655] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x000e: -32
[ 7003.361395] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 7003.378668] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 7003.395811] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 7003.411896] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 7003.429065] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0000: -32
[ 7003.439604] ax88179_178a 2-1.4:2.0 eth1: register 'ax88179_178a' at usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet, 76:1a:d2:65:c8:f4
[ 7003.516418] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 7003.533596] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 7003.757772] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7003.881330] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x0006: -32
[ 7003.899957] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0005: -32
[ 7003.916995] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7003.934694] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7003.955860] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7003.973097] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7003.993649] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 7004.011643] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7004.031500] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 7004.048703] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x0001: -32
[ 7004.064782] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7004.081970] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -32
[ 7004.101091] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0019: -32
[ 7004.118168] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -32
[ 7004.135841] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 7004.152865] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 7004.171457] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 7004.188885] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x000e: -32
[ 7004.206046] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 7004.222240] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 7004.239427] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 7004.256824] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 7004.275488] ax88179_178a 2-1.4:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x0000: -32
[ 7004.286308] ax88179_178a 2-1.4:2.1 eth2: register 'ax88179_178a' at usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet, 76:1a:d2:65:c8:f4
[ 7004.444932] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0002: -32
[ 7004.459684] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0002: -32
[ 7004.679665] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0001: -32
[ 7004.799760] ax88179_178a 2-1.4:2.0 eth1: Failed to read reg index 0x0001: -32
[ 7004.814451] ax88179_178a 2-1.4:2.0 eth1: Failed to read reg index 0x0006: -32
[ 7004.829218] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0005: -32
[ 7004.843868] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0001: -32
[ 7004.855610] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0001: -32
[ 7004.870454] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0001: -32
[ 7004.885081] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0001: -32
[ 7004.899722] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0002: -32
[ 7004.911689] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0001: -32
[ 7004.926467] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0002: -32
[ 7004.941093] ax88179_178a 2-1.4:2.0 eth1: Failed to read reg index 0x0001: -32
[ 7004.955737] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0001: -32
[ 7004.967719] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x001f: -32
[ 7004.982532] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0019: -32
[ 7004.997184] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x001f: -32
[ 7005.011930] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x000d: -32
[ 7005.023975] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x000e: -32
[ 7005.038460] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x000d: -32
[ 7005.053341] ax88179_178a 2-1.4:2.0 eth1: Failed to read reg index 0x000e: -32
[ 7005.067962] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x000d: -32
[ 7005.079836] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x000e: -32
[ 7005.094711] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x000d: -32
[ 7005.109475] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x000e: -32
[ 7005.124091] ax88179_178a 2-1.4:2.0 eth1: Failed to read reg index 0x0000: -32
[ 7005.136200] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0000: -32
[ 7005.181915] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0002: -32
[ 7005.193851] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0002: -32
[ 7005.415258] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0001: -32
[ 7005.539583] ax88179_178a 2-1.4:2.1 eth2: Failed to read reg index 0x0001: -32
[ 7005.554185] ax88179_178a 2-1.4:2.1 eth2: Failed to read reg index 0x0006: -32
[ 7005.566237] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0005: -32
[ 7005.580914] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0001: -32
[ 7005.595506] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0001: -32
[ 7005.610189] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0001: -32
[ 7005.622306] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0001: -32
[ 7005.636942] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0002: -32
[ 7005.651605] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0001: -32
[ 7005.666216] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0002: -32
[ 7005.678148] ax88179_178a 2-1.4:2.1 eth2: Failed to read reg index 0x0001: -32
[ 7005.692788] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0001: -32
[ 7005.707427] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x001f: -32
[ 7005.722059] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0019: -32
[ 7005.738292] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x001f: -32
[ 7005.752941] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x000d: -32
[ 7005.767520] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x000e: -32
[ 7005.782200] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x000d: -32
[ 7005.794153] ax88179_178a 2-1.4:2.1 eth2: Failed to read reg index 0x000e: -32
[ 7005.808798] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x000d: -32
[ 7005.823419] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x000e: -32
[ 7005.838164] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x000d: -32
[ 7005.850007] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x000e: -32
[ 7005.864652] ax88179_178a 2-1.4:2.1 eth2: Failed to read reg index 0x0000: -32
[ 7005.880831] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0000: -32
[ 7006.974568] ax88179_178a 2-1.4:2.0 eth1: unregister 'ax88179_178a' usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 7006.986811] ax88179_178a 2-1.4:2.0 eth1: Failed to read reg index 0x0002: -71
[ 7007.006293] ax88179_178a 2-1.4:2.0 eth1: Failed to write reg index 0x0002: -71
[ 7007.052902] ax88179_178a 2-1.4:2.0 eth1 (unregistered): Failed to write reg index 0x0002: -71
[ 7007.073914] ax88179_178a 2-1.4:2.0 eth1 (unregistered): Failed to write reg index 0x0001: -71
[ 7007.095010] ax88179_178a 2-1.4:2.0 eth1 (unregistered): Failed to write reg index 0x0002: -71
[ 7007.103708] ax88179_178a 2-1.4:2.1 eth2: unregister 'ax88179_178a' usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 7007.115832] ax88179_178a 2-1.4:2.1 eth2: Failed to read reg index 0x0002: -71
[ 7007.135326] ax88179_178a 2-1.4:2.1 eth2: Failed to write reg index 0x0002: -71
[ 7007.185053] ax88179_178a 2-1.4:2.1 eth2 (unregistered): Failed to write reg index 0x0002: -71
[ 7007.205881] ax88179_178a 2-1.4:2.1 eth2 (unregistered): Failed to write reg index 0x0001: -71
[ 7007.226905] ax88179_178a 2-1.4:2.1 eth2 (unregistered): Failed to write reg index 0x0002: -71
[ 7007.654172] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 7007.665750] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 7007.880994] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 7007.996823] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0006: -19
[ 7008.007024] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0005: -19
[ 7008.017485] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 7008.029526] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 7008.039622] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 7008.049735] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 7008.059848] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 7008.070100] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 7008.080239] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 7008.090435] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0001: -19
[ 7008.100755] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 7008.110805] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -19
[ 7008.121006] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0019: -19
[ 7008.131225] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -19
[ 7008.141425] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 7008.151671] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -19
[ 7008.161715] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 7008.171917] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x000e: -19
[ 7008.182111] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 7008.192990] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -19
[ 7008.203769] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 7008.213918] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -19
[ 7008.224022] ax88179_178a 2-1.4:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0000: -19
[ 7008.240507] ax88179_178a 2-1.4:2.0 eth1: register 'ax88179_178a' at usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet, 76:1a:d2:65:c8:f4
[ 7008.242019] ax88179_178a 2-1.4:2.0 eth1: unregister 'ax88179_178a' usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 7008.268764] ax88179_178a 2-1.4:2.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 7008.277350] ax88179_178a 2-1.4:2.0 eth1 (unregistered): Failed to write reg index 0x0001: -19
[ 7008.286195] ax88179_178a 2-1.4:2.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 7009.560033] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0040: -32
[ 7009.882286] ax88179_178a 2-1.4:1.0 eth1: register 'ax88179_178a' at usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet, f8:e4:3b:a9:3e:ac
[ 7010.520908] ax88179_178a 2-1.4:1.0 eth1: Failed to read reg index 0x0040: -32
[ 7055.679164] ax88179_178a 2-1.4:1.0 eth1: unregister 'ax88179_178a' usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 7055.691611] ax88179_178a 2-1.4:1.0 eth1: Failed to read reg index 0x0002: -71
[ 7055.711431] ax88179_178a 2-1.4:1.0 eth1: Failed to write reg index 0x0002: -71
[ 7055.756469] ax88179_178a 2-1.4:1.0 eth1 (unregistered): Failed to write reg index 0x0002: -71
[ 7055.777255] ax88179_178a 2-1.4:1.0 eth1 (unregistered): Failed to write reg index 0x0001: -71
[ 7055.798081] ax88179_178a 2-1.4:1.0 eth1 (unregistered): Failed to write reg index 0x0002: -71
[ 7056.501146] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 7056.511684] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 7056.727907] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 7056.847944] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0006: -19
[ 7056.858174] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0005: -19
[ 7056.869010] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 7056.880019] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 7056.890089] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 7056.900163] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 7056.910294] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 7056.921055] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 7056.932811] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 7056.942897] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0001: -19
[ 7056.952885] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 7056.962954] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -19
[ 7056.973683] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0019: -19
[ 7056.983946] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -19
[ 7056.994172] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 7057.004754] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -19
[ 7057.015727] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 7057.028321] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x000e: -19
[ 7057.038296] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 7057.048341] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -19
[ 7057.058388] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 7057.068485] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -19
[ 7057.078598] ax88179_178a 2-1.4:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0000: -19
[ 7057.089402] ax88179_178a 2-1.4:1.0 eth1: register 'ax88179_178a' at usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet, 76:1a:d2:65:c8:f4
[ 7057.090030] ax88179_178a 2-1.4:1.0 eth1: unregister 'ax88179_178a' usb-70090000.xusb-1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 7057.115864] ax88179_178a 2-1.4:1.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 7057.124471] ax88179_178a 2-1.4:1.0 eth1 (unregistered): Failed to write reg index 0x0001: -19
[ 7057.133176] ax88179_178a 2-1.4:1.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 7066.965226] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 7066.983428] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 7067.207336] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7067.330939] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0006: -32
[ 7067.351706] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0005: -32
[ 7067.369705] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7067.386953] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7067.405573] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7067.422722] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7067.439970] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 7067.458502] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7067.475703] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 7067.492919] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0001: -32
[ 7067.511507] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7067.528720] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -32
[ 7067.545972] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0019: -32
[ 7067.564987] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -32
[ 7067.581723] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 7067.601504] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 7067.620519] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 7067.637484] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x000e: -32
[ 7067.654893] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 7067.673519] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 7067.690640] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 7067.708504] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 7067.726755] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0000: -32
[ 7067.739904] ax88179_178a 2-1.3:2.0 eth1: register 'ax88179_178a' at usb-70090000.xusb-1.3, ASIX AX88179 USB 3.0 Gigabit Ethernet, 76:1a:d2:65:c8:f4
[ 7067.816502] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 7067.833682] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 7068.057742] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7068.188089] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x0006: -32
[ 7068.205501] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0005: -32
[ 7068.222761] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7068.241341] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7068.261496] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7068.278649] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7068.298208] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 7068.317252] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7068.334680] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -32
[ 7068.353304] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x0001: -32
[ 7068.372856] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -32
[ 7068.390217] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -32
[ 7068.406293] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x0019: -32
[ 7068.423739] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -32
[ 7068.443427] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 7068.462218] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 7068.479393] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 7068.499330] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x000e: -32
[ 7068.518139] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 7068.535331] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 7068.552669] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -32
[ 7068.568792] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -32
[ 7068.586134] ax88179_178a 2-1.3:2.1 (unnamed net_device) (uninitialized): Failed to read reg index 0x0000: -32
[ 7068.596900] ax88179_178a 2-1.3:2.1 eth2: register 'ax88179_178a' at usb-70090000.xusb-1.3, ASIX AX88179 USB 3.0 Gigabit Ethernet, 76:1a:d2:65:c8:f4
[ 7068.705167] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0002: -32
[ 7068.721235] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0002: -32
[ 7068.944045] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0001: -32
[ 7069.066367] ax88179_178a 2-1.3:2.0 eth1: Failed to read reg index 0x0001: -32
[ 7069.080987] ax88179_178a 2-1.3:2.0 eth1: Failed to read reg index 0x0006: -32
[ 7069.092785] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0005: -32
[ 7069.107498] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0001: -32
[ 7069.122396] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0001: -32
[ 7069.137036] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0001: -32
[ 7069.148966] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0001: -32
[ 7069.163683] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0002: -32
[ 7069.178453] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0001: -32
[ 7069.193247] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0002: -32
[ 7069.204989] ax88179_178a 2-1.3:2.0 eth1: Failed to read reg index 0x0001: -32
[ 7069.223222] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0001: -32
[ 7069.239726] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x001f: -32
[ 7069.255816] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0019: -32
[ 7069.270332] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x001f: -32
[ 7069.285240] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x000d: -32
[ 7069.299746] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x000e: -32
[ 7069.311719] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x000d: -32
[ 7069.326563] ax88179_178a 2-1.3:2.0 eth1: Failed to read reg index 0x000e: -32
[ 7069.341354] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x000d: -32
[ 7069.355966] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x000e: -32
[ 7069.367929] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x000d: -32
[ 7069.382570] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x000e: -32
[ 7069.397358] ax88179_178a 2-1.3:2.0 eth1: Failed to read reg index 0x0000: -32
[ 7069.412110] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0000: -32
[ 7069.455126] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0002: -32
[ 7069.469763] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0002: -32
[ 7069.693057] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0001: -32
[ 7069.816866] ax88179_178a 2-1.3:2.1 eth2: Failed to read reg index 0x0001: -32
[ 7069.831311] ax88179_178a 2-1.3:2.1 eth2: Failed to read reg index 0x0006: -32
[ 7069.846102] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0005: -32
[ 7069.862978] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0001: -32
[ 7069.879587] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0001: -32
[ 7069.894492] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0001: -32
[ 7069.910331] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0001: -32
[ 7069.925123] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0002: -32
[ 7069.939784] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0001: -32
[ 7069.954584] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0002: -32
[ 7069.970748] ax88179_178a 2-1.3:2.1 eth2: Failed to read reg index 0x0001: -32
[ 7069.985396] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0001: -32
[ 7070.000061] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x001f: -32
[ 7070.014648] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0019: -32
[ 7070.026705] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x001f: -32
[ 7070.041291] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x000d: -32
[ 7070.056709] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x000e: -32
[ 7070.070668] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x000d: -32
[ 7070.082620] ax88179_178a 2-1.3:2.1 eth2: Failed to read reg index 0x000e: -32
[ 7070.097296] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x000d: -32
[ 7070.112051] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x000e: -32
[ 7070.126692] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x000d: -32
[ 7070.138681] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x000e: -32
[ 7070.153478] ax88179_178a 2-1.3:2.1 eth2: Failed to read reg index 0x0000: -32
[ 7070.168228] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0000: -32
[ 7071.262884] ax88179_178a 2-1.3:2.0 eth1: unregister 'ax88179_178a' usb-70090000.xusb-1.3, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 7071.275517] ax88179_178a 2-1.3:2.0 eth1: Failed to read reg index 0x0002: -71
[ 7071.298538] ax88179_178a 2-1.3:2.0 eth1: Failed to write reg index 0x0002: -71
[ 7071.343873] ax88179_178a 2-1.3:2.0 eth1 (unregistered): Failed to write reg index 0x0002: -71
[ 7071.364933] ax88179_178a 2-1.3:2.0 eth1 (unregistered): Failed to write reg index 0x0001: -71
[ 7071.385660] ax88179_178a 2-1.3:2.0 eth1 (unregistered): Failed to write reg index 0x0002: -71
[ 7071.394438] ax88179_178a 2-1.3:2.1 eth2: unregister 'ax88179_178a' usb-70090000.xusb-1.3, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 7071.406557] ax88179_178a 2-1.3:2.1 eth2: Failed to read reg index 0x0002: -71
[ 7071.426028] ax88179_178a 2-1.3:2.1 eth2: Failed to write reg index 0x0002: -71
[ 7071.467743] ax88179_178a 2-1.3:2.1 eth2 (unregistered): Failed to write reg index 0x0002: -71
[ 7071.488539] ax88179_178a 2-1.3:2.1 eth2 (unregistered): Failed to write reg index 0x0001: -71
[ 7071.509658] ax88179_178a 2-1.3:2.1 eth2 (unregistered): Failed to write reg index 0x0002: -71
[ 7071.941041] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 7071.951273] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 7072.167566] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 7072.283541] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0006: -19
[ 7072.293691] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0005: -19
[ 7072.303845] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 7072.314003] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 7072.324190] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 7072.334362] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 7072.344661] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 7072.354866] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 7072.365084] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[ 7072.375353] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0001: -19
[ 7072.385483] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[ 7072.395714] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -19
[ 7072.405963] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0019: -19
[ 7072.416160] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -19
[ 7072.426191] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 7072.436243] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -19
[ 7072.446486] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 7072.456735] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x000e: -19
[ 7072.468635] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 7072.478944] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -19
[ 7072.489037] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[ 7072.499905] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -19
[ 7072.510556] ax88179_178a 2-1.3:2.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0000: -19
[ 7072.526081] ax88179_178a 2-1.3:2.0 eth1: register 'ax88179_178a' at usb-70090000.xusb-1.3, ASIX AX88179 USB 3.0 Gigabit Ethernet, 76:1a:d2:65:c8:f4
[ 7072.532541] ax88179_178a 2-1.3:2.0 eth1: unregister 'ax88179_178a' usb-70090000.xusb-1.3, ASIX AX88179 USB 3.0 Gigabit Ethernet
[ 7072.559909] ax88179_178a 2-1.3:2.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 7072.568503] ax88179_178a 2-1.3:2.0 eth1 (unregistered): Failed to write reg index 0x0001: -19
[ 7072.577095] ax88179_178a 2-1.3:2.0 eth1 (unregistered): Failed to write reg index 0x0002: -19
[ 7073.873391] ax88179_178a 2-1.3:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0040: -32
[ 7074.191020] ax88179_178a 2-1.3:1.0 eth1: register 'ax88179_178a' at usb-70090000.xusb-1.3, ASIX AX88179 USB 3.0 Gigabit Ethernet, f8:e4:3b:a9:3e:ac
[ 7074.828808] ax88179_178a 2-1.3:1.0 eth1: Failed to read reg index 0x0040: -32
[ 7088.845706] Error: Driver 'ax88179_178a' is already registered, aborting...
[ 7509.869444] Error: Driver 'ax88179_178a' is already registered, aborting...
[69693.310228] Error: Driver 'ax88179_178a' is already registered, aborting...
Please check whether there is any known issue of this vendor driver. Or if they launched any new version.
Thxx @WayneWWW. I have just download the driver from their company webpage and it should be the latest version. Others can use the same AX88179 on Jetson Nano (Jetson Nano AX88179 USB speed help!).
I have also searched awhile and found someone have the same error message from other .ko.
insmod: ERROR: could not insert module xxxxx.ko: Device or resource busy
They said the problem exists since the device number claimed in the new device are already being used (check by using cat /proc/devices). However, I cannot see any line in “ax88179_178a.c” “ax88179_178a.h” defining the device number (Exactly I do not know which command is for the defining as I am really fresh on it…). Do you have any idea on it?
Could you attach the full dmesg as a text file?
@WayneWWW , the full dmesg is attached below. Thxxx a lot!
dmesg.txt (94.0 KB)
No, this is not full log. Please dump from the beginning of system boot.
And did you ever try the in stock kernel before use the latest one from their website?
@WayneWWW I type dmesg on terminal and those are the print out results. For the full log, do you mean not just enter “dmesg”?
Thxxx
Your dmesg does not have any log prior to timestamp 251. We need those previous logs.
What does it means? Do you mean direct usage of the adaptor without any insmod command?
No, I didn’t mean that. I mean we also provide this driver in our public source too. This may be a old version but may be compatible with kernel4.9 version.
How can I generate the previous logs? I type dmesg and it starts from 251… Or are there any command I can type to show them out?
Thxxx!
You can just dump dmesg first before you insmod the driver…
Did you meant Jetson Nano already have ax88179_178a driver? And I do not need to download anything from their webpage and I just need to plug in the adaptor and type
sudo modprobe usbnet
sudo insmod ax88179_178a.ko
and the adaptor can work? I have not try it and download their driver directly and use it… How can I undo the make and installation of their driver…
We provide the kernel source here.
And you can follow this method to build original kernel.
Welcome — Jetson Linux<br/>Developer Guide 34.1 documentation → Kernel customization.
But our default driver does not enable this. So you need to manually add this driver in tegra_defconfig.
I don’t know. We didn’t test this usb adapter.
So I need to reboot the Jetson Nano and dump dmesg? Or I can enter some command to un-insmod the driver and can dump the dmesg?
Thxxx a lot!
Just reboot… dump dmesg… insmod the driver and then dump the dmesg again…
Dmesg after reboot :
dmesg_after_reboot.txt (71.4 KB)
Dmesg after insmod the driver (I just type sudo insmod ax88179_178a.ko but NO modprobe usbnet before it):
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-4263) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Oct 16 12:32:46 PDT 2020
[    0.000000] Boot CPU: AArch64 Processor [411fd071]
[    0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[    0.000000] OF: fdt: - 80000000 ,  7ee00000
[    0.000000] OF: fdt: - 100000000 ,  7f200000
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[    0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[    0.000000] On node 0 totalpages: 1039872
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 519168 pages, LIFO batch:31
[    0.000000]   Normal zone: 8136 pages used for memmap
[    0.000000]   Normal zone: 520704 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefb1000 s61656 r8192 d32552 u102400
[    0.000000] pcpu-alloc: s61656 r8192 d32552 u102400 alloc=25*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] CPU features: enabling workaround for ARM erratum 832075
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1023544
[    0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt  earlycon=uart8250,mmio32,0x70006000  root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 131072 bytes
[    0.000000] early log buf free: 29336(89%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Memory: 3570252K/4159488K available (15294K kernel code, 2936K rwdata, 6644K rodata, 8576K init, 611K bss, 114100K reserved, 475136K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008f70000   ( 15296 KB)
[    0.000000]     .rodata : 0xffffff8008f70000 - 0xffffff8009600000   (  6720 KB)
[    0.000000]       .init : 0xffffff8009600000 - 0xffffff8009e60000   (  8576 KB)
[    0.000000]       .data : 0xffffff8009e60000 - 0xffffff800a13e008   (  2937 KB)
[    0.000000]        .bss : 0xffffff800a13e008 - 0xffffff800a1d6f7c   (   612 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf03fc8000   (    63 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc0ff200000   (  4082 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[    0.000000] t210 clock and reset probe
[    0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[    0.000000] clk_cbus_recalc_rate: no gbus parent
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.001696] Console: colour dummy device 80x25
[    0.001705] console [tty0] enabled
[    0.001711] bootconsole [uart8250] disabled
[    0.001729] kmemleak: Kernel memory leak detector disabled
[    0.001747] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[    0.001759] pid_max: default: 32768 minimum: 301
[    0.002209] Security Framework initialized
[    0.002432] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.002440] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.003557] ftrace: allocating 47119 entries in 185 pages
[    0.171901] sched-energy: CPU device node has no sched-energy-costs
[    0.171935] ASID allocator initialised with 65536 entries
[    0.207662] tegra-id: chipid=22117.
[    0.207675] tegra-id: opt_subrevision=0.
[    0.207692] Tegra Speedo/IDDQ fuse revision 4
[    0.207696] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[    0.207700] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[    0.207706] Tegra: CPU Speedo Value 2067, SoC Speedo Value 1966, GPU Speedo Value 2074
[    0.207710] Tegra: CPU IDDQ Value 1972, SoC IDDQ Value 2100, GPU IDDQ Value 2705
[    0.207727] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[    0.207741] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[    0.207748] DTB Build time: Jul 26 2021 12:16:29
[    0.257058] CPU1: Booted secondary processor [411fd071]
[    0.288956] CPU2: Booted secondary processor [411fd071]
[    0.320940] CPU3: Booted secondary processor [411fd071]
[    0.321027] Brought up 4 CPUs
[    0.321033] SMP: Total of 4 processors activated.
[    0.321041] CPU features: detected feature: 32-bit EL0 Support
[    0.321300] CPU: All CPU(s) started at EL2
[    0.321318] alternatives: patching kernel code
[    0.329429] devtmpfs: initialized
[    0.366420] Initilizing CustomIPI irq domain
[    0.366788] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.366810] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.377312] pinctrl core: initialized pinctrl subsystem
[    0.377881] OS set in device tree is not L4T.
[    0.378283] regulator-dummy: no parameters
[    0.378541] Initializing plugin-manager
[    0.378686] Plugin module not found
[    0.378874] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[    0.379365] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[    0.380334] node /plugin-manager/fragement@7 match with odm-data enable-pmic-wdt
[    0.380550] node /plugin-manager/fragement@8 match with odm-data enable-pmic-wdt
[    0.381212] node /plugin-manager/fragement@13 match with board >=3448-0000-300
[    0.384753] NET: Registered protocol family 16
[    0.390221] pstore: using zlib compression
[    0.390257] console [pstore-1] enabled
[    0.390262] pstore: Registered ramoops as persistent store backend
[    0.390268] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[    0.409080] cpuidle: using governor menu
[    0.413309] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[    0.414981] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e64000)
[    0.415002] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.417515] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.419862] Serial: AMBA PL011 UART driver
[    0.420362] tegra_powergate_init: DONE
[    0.420377] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[    0.420385] DTB Build time: Jul 26 2021 12:16:29
[    0.422193] Tegra reboot handler registered.
[    0.426677] iommu: Adding device tegra-carveouts to group 0
[    0.426819] platform tegra-carveouts: domain=ffffffc0f94623d8 allocates as[0]=ffffffc0f94480a8
[    0.427166] iommu: Adding device smmu_test to group 1
[    0.427216] platform smmu_test: domain=ffffffc0f9462618 allocates as[0]=ffffffc0f9448110
[    0.428019] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[    0.428075] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[    0.428133] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[    0.428142] nv-tegra-mc 70019000.mc: No mssnvlink node
[    0.428164] mc-err: mcerr ops are set to t21x
[    0.438154] iommu: Adding device 70090000.xusb to group 2
[    0.438430] iommu: Adding device 70006000.serial to group 3
[    0.438498] platform 70006000.serial: domain=ffffffc0f94dc618 allocates as[0]=ffffffc0f9448178
[    0.438919] iommu: Adding device 70006040.serial to group 4
[    0.439180] iommu: Adding device 70006200.serial to group 5
[    0.439393] iommu: Adding device sound to group 6
[    0.439438] platform sound: domain=ffffffc0f94dcb58 allocates as[0]=ffffffc0f94481e0
[    0.439978] iommu: Adding device 7000d400.spi to group 7
[    0.440236] iommu: Adding device 7000d600.spi to group 8
[    0.440516] iommu: Adding device 70410000.spi to group 9
[    0.440822] iommu: Adding device 50000000.host1x to group 10
[    0.441140] iommu: Adding device 54080000.vi to group 11
[    0.441528] iommu: Adding device 54600000.isp to group 12
[    0.441784] iommu: Adding device 54680000.isp to group 13
[    0.442088] iommu: Adding device tegradc.0 to group 14
[    0.442147] platform tegradc.0: domain=ffffffc0f94e9a98 allocates as[0]=ffffffc0f9448248
[    0.442662] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[    0.442988] iommu: Adding device tegradc.1 to group 15
[    0.443039] platform tegradc.1: domain=ffffffc0f94e9cd8 allocates as[0]=ffffffc0f94482b0
[    0.443537] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[    0.443790] iommu: Adding device 54340000.vic to group 16
[    0.443995] iommu: Adding device 544c0000.nvenc to group 17
[    0.444191] iommu: Adding device 54500000.tsec to group 18
[    0.444395] iommu: Adding device 54100000.tsecb to group 19
[    0.444592] iommu: Adding device 54480000.nvdec to group 20
[    0.444803] iommu: Adding device 54380000.nvjpg to group 21
[    0.445892] iommu: Adding device 546c0000.i2c to group 22
[    0.446225] iommu: Adding device 57000000.gpu to group 23
[    0.446277] platform 57000000.gpu: domain=ffffffc0f94f5cd8 allocates as[0]=ffffffc0f9448318
[    0.446317] platform 57000000.gpu: domain=ffffffc0f94f5cd8 allocates as[1]=ffffffc0f9448380
[    0.446360] platform 57000000.gpu: domain=ffffffc0f94f5cd8 allocates as[2]=ffffffc0f94483e8
[    0.446395] platform 57000000.gpu: domain=ffffffc0f94f5cd8 allocates as[3]=ffffffc0f9448450
[    0.447271] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[    0.447280] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[    0.447292] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[    0.447297] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[    0.447302] tegra-pmc: ### PMC reset status reg: 0x3
[    0.497172] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.497181] tegra-pmc: Clear bootloader IO dpd settings
[    0.497203] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[    0.497264] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[    0.497577] iommu: Adding device 70012000.se to group 24
[    0.498354] iommu: Adding device 7000c000.i2c to group 25
[    0.498605] iommu: Adding device 7000c400.i2c to group 26
[    0.498874] iommu: Adding device 7000c500.i2c to group 27
[    0.499127] iommu: Adding device 7000c700.i2c to group 28
[    0.499382] iommu: Adding device 7000d000.i2c to group 29
[    0.499626] iommu: Adding device 7000d100.i2c to group 30
[    0.499956] iommu: Adding device sdhci-tegra.0 to group 31
[    0.500036] platform sdhci-tegra.0: domain=ffffffc0f9b13f18 allocates as[0]=ffffffc0f94484b8
[    0.500848] iommu: Adding device 700d0000.xudc to group 32
[    0.504048] vdd-ac-bat: 5000 mV
[    0.504382] vdd-5v0-sys: 5000 mV
[    0.505358] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[    0.505400] vdd-5v0-hdmi: 5000 mV
[    0.505823] vdd-1v8-sys: 1800 mV
[    0.506215] vdd-fan: supplied by vdd-5v0-sys
[    0.506254] vdd-fan: 5000 mV
[    0.506621] vdd-usb-vbus: supplied by vdd-5v0-sys
[    0.506653] vdd-usb-vbus: 5000 mV
[    0.507200] vdd-usb-vbus2: 5000 mV
[    0.542145] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.544536] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[    0.545795] GPIO line 6 (system-suspend-gpio) hogged as output/high
[    0.545821] GPIO line 151 (camera-control-output-low) hogged as output/low
[    0.545840] GPIO line 152 (camera-control-output-low) hogged as output/low
[    0.546178] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[    0.554043] eventlib_kernel: keventlib is initialized, test id: 0
[    0.554385] SCSI subsystem initialized
[    0.554597] libata version 3.00 loaded.
[    0.554920] usbcore: registered new interface driver usbfs
[    0.554982] usbcore: registered new interface driver hub
[    0.555058] usbcore: registered new device driver usb
[    0.559077] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[    0.564347] vdd-core: 600 <--> 1162 mV at 1075 mV
[    0.565181] random: fast init done
[    0.565311] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[    0.568245] vdd-ddr-1v1: 1150 mV
[    0.572238] vdd-pre-reg-1v35: 1350 mV
[    0.576360] vdd-1v8: 1800 mV
[    0.580241] avdd-sys-1v2: 1200 mV
[    0.584237] vdd-pex-1v0: 1050 mV
[    0.584904] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[    0.585453] max77620-ldo3: at 3100 mV
[    0.588244] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[    0.588787] max77620-ldo5: at 3100 mV
[    0.592242] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 2800 mV
[    0.596237] avdd-1v05-pll: 1050 mV
[    0.600244] avdd-io-hdmi-dp: 1050 mV
[    0.602714] GPIO line 505 (spmic-default-output-high) hogged as output/high
[    0.603023] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[    0.603318] max77620 4-003c: max77620 probe successful
[    0.606057] media: Linux media interface: v0.10
[    0.606114] Linux video capture interface: v2.00
[    0.607041] pps_core: LinuxPPS API ver. 1 registered
[    0.607046] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.607076] PTP clock support registered
[    0.610188] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[    0.611025] Advanced Linux Sound Architecture Driver Initialized.
[    0.611654] Bluetooth: Core ver 2.22
[    0.611696] NET: Registered protocol family 31
[    0.611700] Bluetooth: HCI device and connection manager initialized
[    0.611713] Bluetooth: HCI socket layer initialized
[    0.611721] Bluetooth: L2CAP socket layer initialized
[    0.611777] Bluetooth: SCO socket layer initialized
[    0.613619] tegra210_dvfs: no clock found for sdmmc2_ddr
[    0.613637] tegra210_dvfs: no clock found for sdmmc4_ddr
[    0.613694] tegra210_dvfs: no clock found for sdmmc1_ddr
[    0.613710] tegra210_dvfs: no clock found for sdmmc3_ddr
[    0.616881] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[    0.618185] vdd-3v3-sys: supplied by vdd-5v0-sys
[    0.618254] vdd-3v3-sys: 3300 mV
[    0.618508] vdd-1v8-sys: supplied by vdd-3v3-sys
[    0.621268] vdd-usb-vbus2: supplied by vdd-3v3-sys
[    0.621717] vdd-3v3-sd: supplied by vdd-3v3-sys
[    0.621783] vdd-3v3-sd: 3300 mV
[    0.622623] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[    0.622665] avdd-io-edp-1v05: 1050 mV
[    0.623076] vdd-usb-hub-en: supplied by vdd-1v8-sys
[    0.623112] vdd-usb-hub-en: 5000 mV
[    0.624541] camchar: rtcpu character device driver loaded
[    0.625389] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[    0.626781] clocksource: Switched to clocksource arch_sys_counter
[    0.666920] VFS: Disk quotas dquot_6.6.0
[    0.667046] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.667526] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.667931] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[    0.667949]  dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[    0.668167] cma: enabled page replacement for spfn=d7000, epfn=f0000
[    0.668171] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[    0.668183] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[    0.668212] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[    0.668218] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[    0.668231] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[    0.668238] nvmap_page_pool_init: Total RAM pages: 1011347
[    0.668242] nvmap_page_pool_init: nvmap page pool size: 126418 pages (493 MB)
[    0.668326] nvmap_background_zero_thread: PP zeroing thread starting.
[    0.668759] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[    0.669468] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[    0.679357] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[    0.679794] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[    0.680155] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[    0.680434] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.680617] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[    0.680874] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[    0.680878] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[    0.681303] NET: Registered protocol family 2
[    0.682338] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.682548] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.683105] TCP: Hash tables configured (established 32768 bind 32768)
[    0.683258] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.683339] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.683763] NET: Registered protocol family 1
[    0.684390] RPC: Registered named UNIX socket transport module.
[    0.684395] RPC: Registered udp transport module.
[    0.684398] RPC: Registered tcp transport module.
[    0.684402] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.684418] PCI: CLS 0 bytes, default 64
[    0.684649] Trying to unpack rootfs image as initramfs...
[    0.915330] Freeing initrd memory: 5356K
[    0.925044] host1x 50000000.host1x: initialized
[    0.926888] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.930067] audit: initializing netlink subsys (disabled)
[    0.930163] audit: type=2000 audit(0.779:1): initialized
[    0.930945] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.940810] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.942259] ntfs: driver 2.1.32 [Flags: R/W].
[    0.943077] 9p: Installing v9fs 9p2000 file system support
[    0.946257] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    0.946402] io scheduler noop registered
[    0.946690] io scheduler cfq registered (default)
[    0.949353] gic 702f9000.agic: GIC IRQ controller registered
[    0.952720] iommu: Adding device 702ef000.adsp to group 33
[    0.961511] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[    0.961669] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[    0.962295] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x8269412
[    0.962304] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[    0.964022] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[    0.964119] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[    0.964217] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[    0.964417] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[    0.964500] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[    0.964597] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[    0.964683] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[    0.964770] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[    0.964851] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[    0.964936] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[    0.970897] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[    0.972497] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[    0.974339] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[    0.975665] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[    0.976005] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[    0.977194] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    0.977403] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[    0.977604] Adding domain tsec-pd to PM domain host1x-pd
[    0.979825] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[    0.980695] tsec 54500000.tsec: initialized
[    0.982256] tsec 54100000.tsecb: initialized
[    0.982995] Adding domain nvdec-pd to PM domain host1x-pd
[    0.986331] nvdec 54480000.nvdec: initialized
[    0.987428] Adding domain vic03-pd to PM domain host1x-pd
[    0.987615] Adding domain msenc-pd to PM domain host1x-pd
[    0.987774] Adding domain nvjpg-pd to PM domain host1x-pd
[    0.991845] falcon 54340000.vic: initialized
[    0.993082] falcon 544c0000.nvenc: initialized
[    0.994368] falcon 54380000.nvjpg: initialized
[    0.998698] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[    0.998741] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[    0.998798] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[    0.998976] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[    0.999074] display board info: id 0x0, fab 0x0
[    0.999082] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[    0.999087] tegra_cec 70015000.tegra_cec: probed
[    0.999143] generic_infoframe_type: 0x87
[    0.999288] tegradc tegradc.0: DT parsed successfully
[    0.999335] tegradc tegradc.0: Display dc.ffffff800ab80000 registered with id=0
[    1.006863] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[    1.008042] tegradc tegradc.0: probed
[    1.008836] Console: switching to colour frame buffer device 80x30
[    1.008873] tegradc tegradc.0: fb registered
[    1.010228] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[    1.010320] tegradc tegradc.1: No lt-data, using default setting
[    1.010344] tegradc tegradc.1: No hpd-gpio in DT
[    1.010385] tegradc tegradc.1: DT parsed successfully
[    1.010440] tegradc tegradc.1: Display dc.ffffff800ad00000 registered with id=1
[    1.012322] tegradc tegradc.1: dpd enable lookup fail:-19
[    1.013010] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[    1.013837] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[    1.013843] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[    1.014159] kfuse 7000fc00.kfuse: initialized
[    1.015023] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[    1.015784] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[    1.518497] Host read timeout at address 545c00c4
[    1.519517] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[    1.519530] vdd-cpu: 708 <--> 1322 mV at 708 mV
[    1.519901] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[    1.520006] tegradc tegradc.1: probed
[    1.520388] tegradc tegradc.1: fb registered
[    1.521195] vdd-gpu: applied init 1000000uV constraint
[    1.521203] vdd-gpu: 708 <--> 1323 mV at 997 mV
[    1.521568] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[    1.525157] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.525259] No Device Node present for smmu client: serial8250 !!
[    1.525269] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[    1.525318] iommu: Adding device serial8250 to group 35
[    1.527993] console [ttyS0] disabled
[    1.528090] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[    1.538519] console [ttyS0] enabled
[    1.539719] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[    1.540033] serial-tegra 70006200.serial: RX in PIO mode
[    1.540133] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[    1.541263] [drm] Initialized
[    1.545514] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[    1.546492] tegradc tegradc.1: dp: aux read defer (0x10020000) -- 6
[    1.551028] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10600000 did not specify bpp
[    1.552001] brd: module loaded
[    1.554901] tegradc tegradc.1: DP: no prod_c_hbr prod settings node in device tree
[    1.557399] loop: module loaded
[    1.557503] tegra_profiler: version: 1.141, samples/io: 48/28
[    1.557617] tegra_profiler: auth: init
[    1.558683] tegradc tegradc.1: dp: aux write defer (0x10020000) -- 6
[    1.558937] THERMAL EST: found 2 subdevs
[    1.558945] THERMAL EST num_resources: 0
[    1.558951] [THERMAL EST subdev 0]
[    1.558960] [THERMAL EST subdev 1]
[    1.559415] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[    1.559419] THERMAL EST: thz register success.
[    1.559580] THERMAL EST: end of probe, return err: 0
[    1.560399] tegradc tegradc.1: dp: aux write defer (0x10020000) -- 6
[    1.560767] sd: No Scsi addr parsed to reserve index
[    1.560804] hisi_sas: driver version v1.6
[    1.562106] tegradc tegradc.1: dp: aux read defer (0x10020000) -- 6
[    1.564155] tegradc tegradc.1: dp: aux read defer (0x10020000) -- 6
[    1.565551] tegra-qspi 70410000.spi: Prod settings list not found
[    1.566194] dp lt: state 0 (Reset), pending_lt_evt 1
[    1.566199] dp lt: switching from state 0 (Reset) to state 0 (Reset)
[    1.566205] dp lt: state 0 (Reset), pending_lt_evt 0
[    1.567029] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[    1.567041] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[    1.568230] tegradc tegradc.1: DP: no prod_c_hbr prod settings node in device tree
[    1.568407] dp lt: switching from state 0 (Reset) to state 2 (clock recovery)
[    1.568415] dp lt: state 2 (clock recovery), pending_lt_evt 0
[    1.568862] tegradc tegradc.1: dp: aux write defer (0x10020000) -- 6
[    1.570118] libphy: Fixed MDIO Bus: probed
[    1.570264] dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[    1.570276] dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[    1.570287] dp lt: config: lane 2: vs level: 0, pe level: 0, pc2 level: 0
[    1.570299] dp lt: config: lane 3: vs level: 0, pe level: 0, pc2 level: 0
[    1.570311] dp lt: tx_pu: 0x20
[    1.570832] tegradc tegradc.1: dp: aux write defer (0x10020000) -- 6
[    1.570931] tun: Universal TUN/TAP device driver, 1.6
[    1.570936] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.572136] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    1.572144] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.572206] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[    1.572210] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.572266] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    1.572271] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.572320] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[    1.572326] Copyright(c) 1999 - 2017 Intel Corporation.
[    1.572765] tegradc tegradc.1: dp: aux read defer (0x10020000) -- 6
[    1.573459] PPP generic driver version 2.4.2
[    1.573659] PPP BSD Compression module registered
[    1.573667] PPP Deflate Compression module registered
[    1.573707] PPP MPPE Compression module registered
[    1.573714] NET: Registered protocol family 24
[    1.573787] usbcore: registered new interface driver r8152
[    1.573831] usbcore: registered new interface driver asix
[    1.573885] usbcore: registered new interface driver ax88179_178a
[    1.573924] usbcore: registered new interface driver cdc_ether
[    1.573958] usbcore: registered new interface driver net1080
[    1.573997] usbcore: registered new interface driver cdc_subset
[    1.574036] usbcore: registered new interface driver zaurus
[    1.574090] usbcore: registered new interface driver cdc_ncm
[    1.574253] VFIO - User Level meta-driver version: 0.3
[    1.574492] dp lt: CR not done
[    1.575386] dp lt: new config: lane 0: vs level: 1, pe level: 0, pc2 level: 0
[    1.575391] dp lt: new config: lane 1: vs level: 1, pe level: 0, pc2 level: 0
[    1.575395] dp lt: new config: lane 2: vs level: 1, pe level: 0, pc2 level: 0
[    1.575398] dp lt: new config: lane 3: vs level: 1, pe level: 0, pc2 level: 0
[    1.575402] dp lt: CR retry
[    1.575408] dp lt: switching from state 2 (clock recovery) to state 2 (clock recovery)
[    1.575419] dp lt: state 2 (clock recovery), pending_lt_evt 0
[    1.575442] dp lt: config: lane 0: vs level: 1, pe level: 0, pc2 level: 0
[    1.575458] dp lt: config: lane 1: vs level: 1, pe level: 0, pc2 level: 0
[    1.575470] dp lt: config: lane 2: vs level: 1, pe level: 0, pc2 level: 0
[    1.575485] dp lt: config: lane 3: vs level: 1, pe level: 0, pc2 level: 0
[    1.575496] dp lt: tx_pu: 0x30
[    1.575693] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.575721] ehci-pci: EHCI PCI platform driver
[    1.575765] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.575777] ohci-pci: OHCI PCI platform driver
[    1.575817] ohci-platform: OHCI generic platform driver
[    1.576634] tegradc tegradc.1: dp: aux read defer (0x10020000) -- 6
[    1.578471] dp lt: CR done
[    1.578476] dp lt: switching from state 2 (clock recovery) to state 3 (channel equalization)
[    1.578487] dp lt: state 3 (channel equalization), pending_lt_evt 0
[    1.578547] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[    1.579163] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[    1.579899] tegradc tegradc.1: dp: aux read defer (0x10020000) -- 6
[    1.580357] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f9567000 id
[    1.582054] dp lt: CE not done
[    1.582608] usbcore: registered new interface driver uas
[    1.582676] usbcore: registered new interface driver usb-storage
[    1.582830] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[    1.582886] tegra-xusb 70090000.xusb: xHCI Host Controller
[    1.582916] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[    1.582957] dp lt: new config: lane 0: vs level: 2, pe level: 0, pc2 level: 0
[    1.582963] dp lt: new config: lane 1: vs level: 2, pe level: 0, pc2 level: 0
[    1.582966] dp lt: new config: lane 2: vs level: 2, pe level: 0, pc2 level: 0
[    1.582969] dp lt: new config: lane 3: vs level: 2, pe level: 0, pc2 level: 0
[    1.582985] dp lt: config: lane 0: vs level: 2, pe level: 0, pc2 level: 0
[    1.582997] dp lt: config: lane 1: vs level: 2, pe level: 0, pc2 level: 0
[    1.583010] dp lt: config: lane 2: vs level: 2, pe level: 0, pc2 level: 0
[    1.583022] dp lt: config: lane 3: vs level: 2, pe level: 0, pc2 level: 0
[    1.583032] dp lt: tx_pu: 0x40
[    1.583501] dp lt: CE retry
[    1.583507] dp lt: switching from state 3 (channel equalization) to state 3 (channel equalization)
[    1.583516] dp lt: state 3 (channel equalization), pending_lt_evt 0
[    1.583711] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[    1.583771] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[    1.583977] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.583984] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.583990] usb usb1: Product: xHCI Host Controller
[    1.583995] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[    1.584000] usb usb1: SerialNumber: 70090000.xusb
[    1.584273] usbcore: registered new interface driver usbserial
[    1.584474] tegradc tegradc.1: dp: aux read defer (0x10020000) -- 6
[    1.584635] hub 1-0:1.0: USB hub found
[    1.584684] hub 1-0:1.0: 5 ports detected
[    1.585330] tegra-xusb 70090000.xusb: xHCI Host Controller
[    1.585345] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[    1.585429] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.585535] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    1.585542] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.585546] usb usb2: Product: xHCI Host Controller
[    1.585551] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[    1.585556] usb usb2: SerialNumber: 70090000.xusb
[    1.586077] hub 2-0:1.0: USB hub found
[    1.586121] hub 2-0:1.0: 4 ports detected
[    1.588712] tegra-xudc-new 700d0000.xudc: device count: 1
[    1.589140] dp lt: CE done
[    1.589148] dp lt: switching from state 3 (channel equalization) to state 5 (link training pass)
[    1.589702] hpd: state 7 (Takeover from bootloader), hpd 1, pending_hpd_evt 1
[    1.589708] hpd: switching from state 7 (Takeover from bootloader) to state 1 (Check Plug)
[    1.590123] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[    1.590136] tegra-xudc-new 700d0000.xudc: vbus state: 1
[    1.590152] tegra-xudc-new 700d0000.xudc: device mode on: 0
[    1.590178] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[    1.590205] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[    1.591149] mousedev: PS/2 mouse device common for all mice
[    1.591265] usbcore: registered new interface driver xpad
[    1.677482] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    1.679899] rtc rtc1: alarm rtc device
[    1.679919] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[    1.679974] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[    1.680558] i2c /dev entries driver
[    1.682367] i2c i2c-6: Added multiplexed i2c bus 7
[    1.682736] i2c i2c-6: Added multiplexed i2c bus 8
[    1.682745] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[    1.683554] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[    1.686921] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[    1.690801] hpd: state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[    1.690810] hpd: switching from state 1 (Check Plug) to state 2 (Check EDID)
[    1.702787] hpd: state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[    1.706904] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[    1.707001] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.711608] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10600000 did not specify bpp
[    1.714698] imx219 7-0010: board setup failed
[    1.719337] imx219: probe of 7-0010 failed with error -121
[    1.720563] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[    1.732390] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[    1.739672] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10600000 did not specify bpp
[    1.740121] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    1.740567] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000000 did not specify bpp
[    1.741014] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    1.741461] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    1.741909] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    1.742356] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000000 did not specify bpp
[    1.742808] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    1.743264] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    1.743712] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    1.743895] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[    1.743991] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.744022] imx219 8-0010: board setup failed
[    1.744132] imx219: probe of 8-0010 failed with error -121
[    1.744158] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    1.744620] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    1.745082] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000000 did not specify bpp
[    1.745093] tegradc tegradc.1: blank - powerdown
[    1.745962] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[    1.748982] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[    1.748987] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[    1.749467] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.749484] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[    1.749493] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[    1.749640] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.749651] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[    1.749657] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[    1.749805] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.749818] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[    1.749823] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[    1.750000] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[    1.750938] tegra_aotag tegra-aotag: Registering sensor 0
[    1.750998] tegra_aotag tegra-aotag: Invalid temp readout
[    1.751028] tegra_aotag tegra-aotag: Invalid temp readout
[    1.751045] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[    1.751053] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[    1.752041] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.752063] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[    1.752270] tegra_aotag tegra-aotag: Invalid temp readout
[    1.752301] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[    1.752737] parse_throttle_dt_data: Num cap clks = 6
[    1.752741] parse_throttle_dt_data: clk=cclk_g type=2
[    1.752757] parse_throttle_dt_data: clk=gpu type=4
[    1.752781] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[    1.752799] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[    1.752821] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[    1.752824] parse_throttle_dt_data: clk=emc type=3
[    1.753264] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.753424] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.753630] tegra_throttle_probe: probe successful. #cdevs=4
[    1.754569] FAN dev name: pwm-fan
[    1.754659] FAN:gpio request success.
[    1.754738] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[    1.755098] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[    1.755294] pwm_fan_driver pwm-fan: fan tach request irq success
[    1.755305] pwm_fan_driver pwm-fan: tach period: 1000
[    1.755401] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    1.755406] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[    1.755410] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[    1.755414] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[    1.755418] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    1.755422] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    1.755426] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    1.755429] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    1.755433] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    1.755437] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    1.758064] device-mapper: uevent: version 1.0.3
[    1.758535] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    1.764425] tegra210-cpufreq cpufreq: probe()...completed
[    1.765162] sdhci: Secure Digital Host Controller Interface driver
[    1.765163] sdhci: Copyright(c) Pierre Ossman
[    1.765165] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.765646] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[    1.765996] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[    1.766122] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[    1.773646] tegra-se 70012000.se: tegra_se_probe: complete
[    1.774399] hidraw: raw HID events driver (C) Jiri Kosina
[    1.775640] usbcore: registered new interface driver usbhid
[    1.775641] usbhid: USB HID core driver
[    1.777757] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[    1.777923] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[    1.779776] nvpmodel: initialized successfully
[    1.780959] usbcore: registered new interface driver snd-usb-audio
[    1.781026] No Device Node present for smmu client: snd-soc-dummy !!
[    1.781031] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[    1.781050] iommu: Adding device snd-soc-dummy to group 36
[    1.786444] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[    1.793265] dp lt: state 5 (link training pass), pending_lt_evt 1
[    1.793268] dp lt: switching from state 5 (link training pass) to state 0 (Reset)
[    1.793271] dp lt: state 0 (Reset), pending_lt_evt 0
[    1.793278] dp lt: link training force disable
[    1.793280] dp lt: switching from state 0 (Reset) to state 4 (link training fail/disable)
[    1.797141] OPE platform probe
[    1.797228] OPE platform probe successful
[    1.797253] OPE platform probe
[    1.797329] OPE platform probe successful
[    1.810365] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10600000 did not specify bpp
[    1.810375] tegradc tegradc.1: unblank
[    1.810955] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[    1.821019] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[    1.821150] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[    1.821280] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[    1.821406] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[    1.821535] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[    1.821660] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[    1.821784] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[    1.821916] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[    1.822040] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[    1.822165] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[    1.833612] u32 classifier
[    1.833614]     Actions configured
[    1.833682] Initializing XFRM netlink socket
[    1.834386] NET: Registered protocol family 10
[    1.835054] NET: Registered protocol family 17
[    1.835065] NET: Registered protocol family 15
[    1.835137] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    1.835182] Bluetooth: RFCOMM socket layer initialized
[    1.835191] Bluetooth: RFCOMM ver 1.11
[    1.835195] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.835199] Bluetooth: HIDP socket layer initialized
[    1.835217] 9pnet: Installing 9P2000 support
[    1.835250] Key type dns_resolver registered
[    1.835624] Registered cp15_barrier emulation handler
[    1.835630] Registered setend emulation handler
[    1.836644] registered taskstats version 1
[    1.837189] Adding domain ve2-pd to PM domain host1x-pd
[    1.837442] Adding domain ve-pd to PM domain host1x-pd
[    1.839503] isp 54600000.isp: initialized
[    1.840484] isp 54680000.isp: initialized
[    1.844338] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[    1.845259] tegradc tegradc.1: dp: aux read defer (0x10020000) -- 6
[    1.848244] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10600000 did not specify bpp
[    1.850743] last reset is due to software reset
[    1.850745] KERNEL: PMC reset status reg: 0x3
[    1.850886] BL: PMC reset status reg: 0x3
[    1.850888] BL: PMIC poweroff Event Recorder: 0x0
[    1.852308] clk_cbus_recalc_rate: no gbus parent
[    1.852312] clk_cbus_round_rate: no gbus parent
[    1.852313] clk_cbus_round_rate: no gbus parent
[    1.852320] clk_cbus_recalc_rate: no gbus parent
[    1.852418] clk_cbus_recalc_rate: no gbus parent
[    1.852421] clk_cbus_round_rate: no gbus parent
[    1.852422] clk_cbus_round_rate: no gbus parent
[    1.852426] clk_cbus_recalc_rate: no gbus parent
[    1.852624] tegradc tegradc.1: DP: no prod_c_hbr prod settings node in device tree
[    1.853095] tegra_dvfs: GPU-cap: registered
[    1.853158] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[    1.853160] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[    1.853162] tegra dvfs: vdd-gpu: nominal 1058mV, offset 708000uV, step 10000uV, scaling enabled
[    1.854523] tegra_dvfs: vdd-gpu-vts: registered
[    1.855242] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[    1.855864] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[    1.855913] tegradc tegradc.1: dp: aux write defer (0x10020000) -- 6
[    1.856334] input: gpio-keys as /devices/gpio-keys/input/input1
[    1.857573] tegradc tegradc.1: dp: aux write defer (0x10020000) -- 6
[    1.859207] tegradc tegradc.1: dp: aux read defer (0x10020000) -- 6
[    1.861296] tegradc tegradc.1: dp: aux read defer (0x10020000) -- 6
[    1.863074] dp lt: state 4 (link training fail/disable), pending_lt_evt 1
[    1.863076] dp lt: switching from state 4 (link training fail/disable) to state 0 (Reset)
[    1.863078] dp lt: state 0 (Reset), pending_lt_evt 0
[    1.864468] tegradc tegradc.1: dp: aux read defer (0x10020000) -- 6
[    1.866137] tegradc tegradc.1: DP: no prod_c_hbr prod settings node in device tree
[    1.866281] dp lt: switching from state 0 (Reset) to state 2 (clock recovery)
[    1.866285] dp lt: state 2 (clock recovery), pending_lt_evt 0
[    1.866727] tegradc tegradc.1: dp: aux write defer (0x10020000) -- 6
[    1.867975] dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[    1.867984] dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[    1.867994] dp lt: config: lane 2: vs level: 0, pe level: 0, pc2 level: 0
[    1.868003] dp lt: config: lane 3: vs level: 0, pe level: 0, pc2 level: 0
[    1.868009] dp lt: tx_pu: 0x20
[    1.868467] tegradc tegradc.1: dp: aux write defer (0x10020000) -- 6
[    1.870326] tegradc tegradc.1: dp: aux read defer (0x10020000) -- 6
[    1.871629] dp lt: CR not done
[    1.872486] dp lt: new config: lane 0: vs level: 1, pe level: 0, pc2 level: 0
[    1.872487] dp lt: new config: lane 1: vs level: 1, pe level: 0, pc2 level: 0
[    1.872489] dp lt: new config: lane 2: vs level: 1, pe level: 0, pc2 level: 0
[    1.872490] dp lt: new config: lane 3: vs level: 1, pe level: 0, pc2 level: 0
[    1.872492] dp lt: CR retry
[    1.872494] dp lt: switching from state 2 (clock recovery) to state 2 (clock recovery)
[    1.872497] dp lt: state 2 (clock recovery), pending_lt_evt 0
[    1.872507] dp lt: config: lane 0: vs level: 1, pe level: 0, pc2 level: 0
[    1.872515] dp lt: config: lane 1: vs level: 1, pe level: 0, pc2 level: 0
[    1.872523] dp lt: config: lane 2: vs level: 1, pe level: 0, pc2 level: 0
[    1.872530] dp lt: config: lane 3: vs level: 1, pe level: 0, pc2 level: 0
[    1.872535] dp lt: tx_pu: 0x30
[    1.873622] tegradc tegradc.1: dp: aux read defer (0x10020000) -- 6
[    1.875433] dp lt: CR done
[    1.875435] dp lt: switching from state 2 (clock recovery) to state 3 (channel equalization)
[    1.875438] dp lt: state 3 (channel equalization), pending_lt_evt 0
[    1.876800] tegradc tegradc.1: dp: aux read defer (0x10020000) -- 6
[    1.878888] dp lt: CE not done
[    1.879746] dp lt: new config: lane 0: vs level: 2, pe level: 0, pc2 level: 0
[    1.879748] dp lt: new config: lane 1: vs level: 2, pe level: 0, pc2 level: 0
[    1.879749] dp lt: new config: lane 2: vs level: 2, pe level: 0, pc2 level: 0
[    1.879750] dp lt: new config: lane 3: vs level: 2, pe level: 0, pc2 level: 0
[    1.879759] dp lt: config: lane 0: vs level: 2, pe level: 0, pc2 level: 0
[    1.879766] dp lt: config: lane 1: vs level: 2, pe level: 0, pc2 level: 0
[    1.879774] dp lt: config: lane 2: vs level: 2, pe level: 0, pc2 level: 0
[    1.879783] dp lt: config: lane 3: vs level: 2, pe level: 0, pc2 level: 0
[    1.879787] dp lt: tx_pu: 0x40
[    1.880240] dp lt: CE retry
[    1.880242] dp lt: switching from state 3 (channel equalization) to state 3 (channel equalization)
[    1.880245] dp lt: state 3 (channel equalization), pending_lt_evt 0
[    1.881180] tegradc tegradc.1: dp: aux read defer (0x10020000) -- 6
[    1.885006] dp lt: CE done
[    1.885009] dp lt: switching from state 3 (channel equalization) to state 5 (link training pass)
[    1.888298] tegra_rtc 7000e000.rtc: setting system clock to 2022-04-07 04:16:42 UTC (1649305002)
[    1.889291] vi 54080000.vi: vi_probe: ++
[    1.892062] vi 54080000.vi: initialized
[    1.894051] vi 54080000.vi: subdev nvcsi--2 bound
[    1.894152] vi 54080000.vi: subdev nvcsi--1 bound
[    1.895561] Disable partitions left on by BL
[    1.895564]   disb
[    1.895611] bwmgr: missing cdev-type property
[    1.895705] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.895711] DRAM derating cdev registered.
[    1.896707] vdd-fan: disabling
[    1.896709] vdd-usb-vbus: disabling
[    1.896711] vdd-usb-vbus2: disabling
[    1.896720] vddio-sdmmc3-ap: disabling
[    1.896802] vdd-usb-hub-en: disabling
[    1.896883] ALSA device list:
[    1.896885]   #0: tegra-hda at 0x70038000 irq 83
[    1.896887]   #1: tegra-snd-t210ref-mobile-rt565x
[    1.901812] tegradc tegradc.1: sync windows ret = 246
[    1.909210] tegra-pcie 1003000.pcie: link 0 down, retrying
[    1.910839] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    1.914191] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10600000 did not specify bpp
[    1.914626] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    1.915200] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000000 did not specify bpp
[    1.915635] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    1.916068] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    1.916503] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    1.916937] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000000 did not specify bpp
[    1.917372] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    1.917824] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    1.918258] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    1.918692] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    1.919127] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    1.919561] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000000 did not specify bpp
[    1.919564] tegradc tegradc.1: blank - powerdown
[    1.940455] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[    1.940458] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.940461] usb 1-2: Product: 4-Port USB 2.1 Hub
[    1.940463] usb 1-2: Manufacturer: Generic
[    1.941440] hub 1-2:1.0: USB hub found
[    1.942414] hub 1-2:1.0: 4 ports detected
[    1.968480] dp lt: state 5 (link training pass), pending_lt_evt 1
[    1.968482] dp lt: switching from state 5 (link training pass) to state 0 (Reset)
[    1.968485] dp lt: state 0 (Reset), pending_lt_evt 0
[    1.968489] dp lt: link training force disable
[    1.968491] dp lt: switching from state 0 (Reset) to state 4 (link training fail/disable)
[    1.989693] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10600000 did not specify bpp
[    1.989702] tegradc tegradc.1: unblank
[    2.002793] tegra_cec 70015000.tegra_cec: Can't find physical addresse.
[    2.002795] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[    2.004979] mmc0: hw tuning done ...
[    2.005023] mmc0: new ultra high speed SDR104 SDXC card at address 59b4
[    2.009321] mmcblk0: mmc0:59b4 EC1S5 59.7 GiB
[    2.012520]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[    2.021488] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[    2.022396] tegradc tegradc.1: dp: aux read defer (0x10020000) -- 6
[    2.025387] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10600000 did not specify bpp
[    2.029193] tegradc tegradc.1: DP: no prod_c_hbr prod settings node in device tree
[    2.032882] tegradc tegradc.1: dp: aux write defer (0x10020000) -- 6
[    2.034560] tegradc tegradc.1: dp: aux write defer (0x10020000) -- 6
[    2.036227] tegradc tegradc.1: dp: aux read defer (0x10020000) -- 6
[    2.038331] tegradc tegradc.1: dp: aux read defer (0x10020000) -- 6
[    2.039740] dp lt: state 4 (link training fail/disable), pending_lt_evt 1
[    2.039743] dp lt: switching from state 4 (link training fail/disable) to state 0 (Reset)
[    2.039745] dp lt: state 0 (Reset), pending_lt_evt 0
[    2.041141] tegradc tegradc.1: dp: aux read defer (0x10020000) -- 6
[    2.042823] tegradc tegradc.1: DP: no prod_c_hbr prod settings node in device tree
[    2.042966] dp lt: switching from state 0 (Reset) to state 2 (clock recovery)
[    2.042969] dp lt: state 2 (clock recovery), pending_lt_evt 0
[    2.043411] tegradc tegradc.1: dp: aux write defer (0x10020000) -- 6
[    2.044661] dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[    2.044670] dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[    2.044679] dp lt: config: lane 2: vs level: 0, pe level: 0, pc2 level: 0
[    2.044688] dp lt: config: lane 3: vs level: 0, pe level: 0, pc2 level: 0
[    2.044694] dp lt: tx_pu: 0x20
[    2.045158] tegradc tegradc.1: dp: aux write defer (0x10020000) -- 6
[    2.047045] tegradc tegradc.1: dp: aux read defer (0x10020000) -- 6
[    2.048728] dp lt: CR not done
[    2.049600] dp lt: new config: lane 0: vs level: 1, pe level: 0, pc2 level: 0
[    2.049602] dp lt: new config: lane 1: vs level: 1, pe level: 0, pc2 level: 0
[    2.049604] dp lt: new config: lane 2: vs level: 1, pe level: 0, pc2 level: 0
[    2.049606] dp lt: new config: lane 3: vs level: 1, pe level: 0, pc2 level: 0
[    2.049608] dp lt: CR retry
[    2.049610] dp lt: switching from state 2 (clock recovery) to state 2 (clock recovery)
[    2.049613] dp lt: state 2 (clock recovery), pending_lt_evt 0
[    2.049625] dp lt: config: lane 0: vs level: 1, pe level: 0, pc2 level: 0
[    2.049634] dp lt: config: lane 1: vs level: 1, pe level: 0, pc2 level: 0
[    2.049642] dp lt: config: lane 2: vs level: 1, pe level: 0, pc2 level: 0
[    2.049650] dp lt: config: lane 3: vs level: 1, pe level: 0, pc2 level: 0
[    2.049655] dp lt: tx_pu: 0x30
[    2.050782] tegradc tegradc.1: dp: aux read defer (0x10020000) -- 6
[    2.052465] dp lt: CR done
[    2.052467] dp lt: switching from state 2 (clock recovery) to state 3 (channel equalization)
[    2.052471] dp lt: state 3 (channel equalization), pending_lt_evt 0
[    2.053856] tegradc tegradc.1: dp: aux read defer (0x10020000) -- 6
[    2.055973] dp lt: CE not done
[    2.056848] dp lt: new config: lane 0: vs level: 2, pe level: 0, pc2 level: 0
[    2.056850] dp lt: new config: lane 1: vs level: 2, pe level: 0, pc2 level: 0
[    2.056852] dp lt: new config: lane 2: vs level: 2, pe level: 0, pc2 level: 0
[    2.056854] dp lt: new config: lane 3: vs level: 2, pe level: 0, pc2 level: 0
[    2.056864] dp lt: config: lane 0: vs level: 2, pe level: 0, pc2 level: 0
[    2.056872] dp lt: config: lane 1: vs level: 2, pe level: 0, pc2 level: 0
[    2.056881] dp lt: config: lane 2: vs level: 2, pe level: 0, pc2 level: 0
[    2.056891] dp lt: config: lane 3: vs level: 2, pe level: 0, pc2 level: 0
[    2.056896] dp lt: tx_pu: 0x40
[    2.057360] dp lt: CE retry
[    2.057362] dp lt: switching from state 3 (channel equalization) to state 3 (channel equalization)
[    2.057365] dp lt: state 3 (channel equalization), pending_lt_evt 0
[    2.058317] tegradc tegradc.1: dp: aux read defer (0x10020000) -- 6
[    2.062049] dp lt: CE done
[    2.062052] dp lt: switching from state 3 (channel equalization) to state 5 (link training pass)
[    2.078835] tegradc tegradc.1: sync windows ret = 245
[    2.078917] extcon-disp-state extcon:disp-state: cable 44 state 1
[    2.078920] Extcon DP: HPD enabled
[    2.078930] hpd: Display connected, hpd_switch 1
[    2.078932] hpd: switching from state 2 (Check EDID) to state 4 (Enabled)
[    2.081970] Freeing unused kernel memory: 8576K
[    2.106105] Root device found: mmcblk0p1
[    2.107225] Found dev node: /dev/mmcblk0p1
[    2.190543] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    2.191370] Rootfs mounted over mmcblk0p1
[    2.211937] Switching from initrd to actual rootfs
[    2.230809] usb 1-2.2: new full-speed USB device number 3 using tegra-xusb
[    2.255463] usb 1-2.2: New USB device found, idVendor=413c, idProduct=2514
[    2.255468] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.255471] usb 1-2.2: Product: Dell Universal Receiver
[    2.255473] usb 1-2.2: Manufacturer: Dell Computer Corp
[    2.258313] input: Dell Computer Corp Dell Universal Receiver as /devices/70090000.xusb/usb1/1-2/1-2.2/1-2.2:1.0/0003:413C:2514.0001/input/input2
[    2.312801] tegra-pcie 1003000.pcie: link 0 down, retrying
[    2.315266] hid-generic 0003:413C:2514.0001: input,hidraw0: USB HID v1.11 Keyboard [Dell Computer Corp Dell Universal Receiver] on usb-70090000.xusb-2.2/input0
[    2.317841] input: Dell Computer Corp Dell Universal Receiver as /devices/70090000.xusb/usb1/1-2/1-2.2/1-2.2:1.1/0003:413C:2514.0002/input/input3
[    2.375153] hid-generic 0003:413C:2514.0002: input,hidraw1: USB HID v1.11 Mouse [Dell Computer Corp Dell Universal Receiver] on usb-70090000.xusb-2.2/input1
[    2.377945] hid-generic 0003:413C:2514.0003: hidraw2: USB HID v1.11 Device [Dell Computer Corp Dell Universal Receiver] on usb-70090000.xusb-2.2/input2
[    2.413529] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.425551] cgroup: cgroup2: unknown option "nsdelegate"
[    2.449082] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    2.449890] systemd[1]: Detected architecture arm64.
[    2.472932] systemd[1]: Set hostname to <rp4-desktop>.
[    2.508594] systemd-fstab-generator[1922]: Failed to create unit file /run/systemd/generator/var-swapfile.swap, as it already exists. Duplicate entry in /etc/fstab?
[    2.523521] systemd-fstab-generator[1922]: Failed to create unit file /run/systemd/generator/var-swapfile.swap, as it already exists. Duplicate entry in /etc/fstab?
[    2.563186] systemd[1918]: /lib/systemd/system-generators/systemd-fstab-generator failed with exit status 1.
[    2.583965] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    2.583975] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    2.705460] random: systemd: uninitialized urandom read (16 bytes read)
[    2.707156] systemd[1]: Created slice User and Session Slice.
[    2.707276] random: systemd: uninitialized urandom read (16 bytes read)
[    2.707394] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    2.707440] random: systemd: uninitialized urandom read (16 bytes read)
[    2.708216] systemd[1]: Created slice System Slice.
[    2.709095] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    2.720958] tegra-pcie 1003000.pcie: link 0 down, retrying
[    2.722810] tegra-pcie 1003000.pcie: link 0 down, ignoring
[    2.756648] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[    2.830360] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[    2.830367] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    2.830372] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[    2.830376] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[    2.830382] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.830404] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[    2.830466] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[    2.830633] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.830903] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[    2.830928] pci 0000:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    2.830958] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[    2.830979] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[    2.831118] pci 0000:01:00.0: supports D1 D2
[    2.831122] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    2.842923] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    2.842977] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[    2.842991] pci 0000:00:02.0: BAR 13: assigned [io  0x1000-0x1fff]
[    2.843012] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[    2.843044] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[    2.843072] pci 0000:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    2.843088] pci 0000:00:02.0: PCI bridge to [bus 01]
[    2.843100] pci 0000:00:02.0:   bridge window [io  0x1000-0x1fff]
[    2.843110] pci 0000:00:02.0:   bridge window [mem 0x13000000-0x130fffff]
[    2.843416] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[    2.843420] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    2.843425] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[    2.843514] aer 0000:00:02.0:pcie002: service driver aer loaded
[    2.843694] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[    2.843712] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[    2.861618] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[    2.861690] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 48:b0:2d:3d:1d:dd from device tree
[    2.862390] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[    2.862515] r8168  Copyright (C) 2017  Realtek NIC software team <nicfae@realtek.com>
                This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[    2.866079] nvgpu: 57000000.gpu           gm20b_init_clk_setup_sw:1268 [INFO]  GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[    2.870817] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    2.870840] cpu-throttle-alert cooling device registered.
[    2.870965] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    2.870979] gpu-throttle-alert cooling device registered.
[    2.871130] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    2.871143] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    2.871156] hot-surface-alert cooling device registered.
[    3.085620] systemd-journald[2040]: Received request to flush runtime journal from PID 1
[    3.744436] using random self ethernet address
[    3.749089] using random host ethernet address
[    4.138617] random: crng init done
[    4.142023] random: 7 urandom warning(s) missed due to ratelimiting
[    4.672779] Mass Storage Function, version: 2009/09/11
[    4.672785] LUN: removable file: (no medium)
[    4.721444] using random self ethernet address
[    4.727864] using random host ethernet address
[    4.916598] rndis0: HOST MAC e2:0e:46:3d:2b:b8
[    4.917079] rndis0: MAC e2:0e:46:3d:2b:b9
[    4.919514] usb0: HOST MAC e2:0e:46:3d:2b:ba
[    4.919546] usb0: MAC e2:0e:46:3d:2b:bb
[    4.919572] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[    4.925063] l4tbr0: port 1(rndis0) entered blocking state
[    4.925068] l4tbr0: port 1(rndis0) entered disabled state
[    4.925242] device rndis0 entered promiscuous mode
[    4.946151] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[    4.954972] l4tbr0: port 2(usb0) entered blocking state
[    4.954977] l4tbr0: port 2(usb0) entered disabled state
[    4.965152] device usb0 entered promiscuous mode
[    4.990558] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[    5.745261] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[    5.745268] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[    5.795736] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    5.798562] eth0: 0xffffff800acfe000, 48:b0:2d:3d:1d:dd, IRQ 407
[    5.937490] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    5.987277] zram: Added device: zram0
[    5.991466] zram: Added device: zram1
[    5.993815] zram: Added device: zram2
[    5.995223] zram: Added device: zram3
[    6.044141] zram0: detected capacity change from 0 to 519593984
[    6.081123] Adding 507412k swap on /dev/zram0.  Priority:5 extents:1 across:507412k SS
[    6.083229] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[    6.092637] zram1: detected capacity change from 0 to 519593984
[    6.111514] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[    6.111522] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    6.111526] usb 2-1: Product: 4-Port USB 3.1 Hub
[    6.111529] usb 2-1: Manufacturer: Generic
[    6.115041] hub 2-1:1.0: USB hub found
[    6.115849] hub 2-1:1.0: 4 ports detected
[    6.138726] Adding 507412k swap on /dev/zram1.  Priority:5 extents:1 across:507412k SS
[    6.151953] zram2: detected capacity change from 0 to 519593984
[    6.173288] Adding 507412k swap on /dev/zram2.  Priority:5 extents:1 across:507412k SS
[    6.183133] zram3: detected capacity change from 0 to 519593984
[    6.198432] Adding 507412k swap on /dev/zram3.  Priority:5 extents:1 across:507412k SS
[    6.408958] usb 2-1.3: new SuperSpeed USB device number 3 using tegra-xusb
[    6.574991] usb 2-1.3: New USB device found, idVendor=0b95, idProduct=1790
[    6.574998] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    6.575002] usb 2-1.3: Product: AX88179A
[    6.575006] usb 2-1.3: Manufacturer: ASIX
[    6.575009] usb 2-1.3: SerialNumber: 00A93EAC
[    7.189472] ax88179_178a 2-1.3:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0040: -32
[    7.510332] ax88179_178a 2-1.3:1.0 eth1: register 'ax88179_178a' at usb-70090000.xusb-1.3, ASIX AX88179 USB 3.0 Gigabit Ethernet, f8:e4:3b:a9:3e:ac
[    7.618330] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[    7.828762] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10600000 did not specify bpp
[    7.829232] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    7.829683] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000000 did not specify bpp
[    7.830123] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    7.830585] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    7.831014] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    7.831469] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000000 did not specify bpp
[    7.831914] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    7.832367] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    7.832810] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    7.833253] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    7.833697] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[    7.834139] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000000 did not specify bpp
[    7.907770] tegradc tegradc.1: unblank
[    7.907992] tegradc tegradc.0: blank - powerdown
[    8.167415] ax88179_178a 2-1.3:1.0 eth1: Failed to read reg index 0x0040: -32
[    8.481209] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[    9.010926] r8168: eth0: link up
[    9.011064] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[    9.879827] tegradc tegradc.1: unblank
[    9.879836] tegradc tegradc.0: blank - powerdown
[   11.189218] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   11.189229] Bluetooth: BNEP socket layer initialized
[  226.497485] ax88179_178a: loading out-of-tree module taints kernel.
[  226.506060] Error: Driver 'ax88179_178a' is already registered, aborting...
