I have been working with the Jetson Nano since the past week. I was successful in booting up and running deep learning programs on the Jetson Nano using SanDisk 16 GB memory cards. The board is connected to a Samsung monitor via HDMI. a keyboard and mouse via USB.
I wanted to use a 32 GB SD card so I flashed the jetson nano image onto that (a microSDHC Memory Card by MetroPCS - last minute buy) and tried booting up with the same configuration as above. I run into an error:
[1.099316] tegradc tegradc.1: dpd enable lookup fail:-19
cp: not writing through dangling symlink ‘etc/resolv.conf’
[340.0486791] cgroup: cgroup2: unknown option “nsdelegate”
The system hangs after this.
I have checked the forum for answers but most answers pertain to proper connection of the peripherals (HDMI cable, etc). Since my system worked with the same setup for a different SD card, I was wondering if the current SD card is not supported.
Edit: I seem to be getting the above messages for successful bootups too. But why is the bootup failing with this SD card?
