I have a Jetson Nano (2GB) connected to a HP (EliteBook) laptop running Ubuntu 18.04.5. With a HDMI monitor along with a keyboard/mouse, I completed the DLI class “Intro to AI on Jetson Nano”. With the next class I’m attempting to connect the Nano in a head-less mode (USB-C for power and USB microB for data). I’ve completely erased the 64G micro-SD card and completed a fresh install of the “jp451” image and verified this with a monitor and keyboard. With the Nano powered up I see the “L4T-README” disk on my laptop GUI and I can view the README files. I can also run “screen” and login to the Nano from the laptop using the “/dev/ttyACM0” device. What I cannot do is connect Firefox on the laptop to the Nano using the 192.168.55.1 address. The connection fails. Digging a little further I noticed that no Ethernet interface on the laptop gets a 192.168.55.100 address as the documentation suggests. I tried manually setting the “enp0s29u1u1i5” interface to 192.168.55.100 and confirmed I can ping in each direction on the USB cable. However the Web page connection still fails.
Here is the Tegra version from the Nano:
R32 (release), REVISION: 5.1, GCID: 26202423, BOARD: t210ref, EABI: aarch64, DATE: Fri Feb 19 16:45:52 UTC 2021
Here are “ifconfig -a” listings from before and after USB cable connect:
BEFORE:
root@hp1:~# ifconfig -a
enp0s25: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.30 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::6631:50ff:fe9c:1c4e prefixlen 64 scopeid 0x20
ether 64:31:50:9c:1c:4e txqueuelen 1000 (Ethernet)
RX packets 2538 bytes 1439604 (1.4 MB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 761 bytes 72348 (72.3 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 20 memory 0xd7400000-d7420000
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1000 (Local Loopback)
RX packets 170 bytes 14468 (14.4 KB)
TX packets 170 bytes 14468 (14.4 KB)
wlo1: flags=4098<BROADCAST,MULTICAST> mtu 1500
ether 00:24:d7:c2:23:08 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
AFTER:
RX packets 5694 bytes 3878077 (3.8 MB)
TX packets 2512 bytes 270529 (270.5 KB)
enp0s29u1u1: flags=4098<BROADCAST,MULTICAST> mtu 1500
ether e6:ae:33:9b:04:da txqueuelen 1000 (Ethernet)
enp0s29u1u1i5: flags=4098<BROADCAST,MULTICAST> mtu 1500
ether 92:0b:c7:48:74:72 txqueuelen 1000 (Ethernet)
RX packets 435 bytes 43849 (43.8 KB)
TX packets 435 bytes 43849 (43.8 KB)
Here is the dmesg output after a USB cable connect:
root@hp1:~# cat dm1
[ 1483.613311] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 1504.098290] usb 2-1.1: new high-speed USB device number 4 using ehci-pci
[ 1504.208263] usb 2-1.1: New USB device found, idVendor=0955, idProduct=7020
[ 1504.208268] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1504.208270] usb 2-1.1: Product: Linux for Tegra
[ 1504.208273] usb 2-1.1: Manufacturer: NVIDIA
[ 1504.208275] usb 2-1.1: SerialNumber: 1424320071556
[ 1504.351750] cdc_acm 2-1.1:1.2: ttyACM0: USB ACM device
[ 1504.352220] usbcore: registered new interface driver cdc_acm
[ 1504.352222] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1504.405710] usbcore: registered new interface driver cdc_ether
[ 1504.426843] cdc_ncm 2-1.1:1.5: MAC-Address: 92:0b:c7:48:74:72
[ 1504.427311] cdc_ncm 2-1.1:1.5 usb0: register ‘cdc_ncm’ at usb-0000:00:1d.0-1.1, CDC NCM, 92:0b:c7:48:74:72
[ 1504.428036] usbcore: registered new interface driver cdc_ncm
[ 1504.431243] rndis_host 2-1.1:1.0 usb1: register ‘rndis_host’ at usb-0000:00:1d.0-1.1, RNDIS device, 3e:63:aa:45:a0:a1
[ 1504.432069] usbcore: registered new interface driver rndis_host
[ 1504.434015] usb-storage 2-1.1:1.4: USB Mass Storage device detected
[ 1504.437621] scsi host7: usb-storage 2-1.1:1.4
[ 1504.437790] usbcore: registered new interface driver usb-storage
[ 1504.446222] usbcore: registered new interface driver cdc_wdm
[ 1504.463373] usbcore: registered new interface driver rndis_wlan
[ 1504.481053] usbcore: registered new interface driver uas
[ 1504.489462] usbcore: registered new interface driver cdc_mbim
[ 1504.497048] rndis_host 2-1.1:1.0 enp0s29u1u1: renamed from usb1
[ 1504.511560] cdc_ncm 2-1.1:1.5 enp0s29u1u1i5: renamed from usb0
[ 1505.455171] scsi 7:0:0:0: Direct-Access Linux File-Stor Gadget 0409 PQ: 0 ANSI: 2
[ 1505.455802] sd 7:0:0:0: Attached scsi generic sg2 type 0
[ 1505.456378] sd 7:0:0:0: Power-on or device reset occurred
[ 1505.457114] sd 7:0:0:0: [sdb] 32768 512-byte logical blocks: (16.8 MB/16.0 MiB)
[ 1505.458027] sd 7:0:0:0: [sdb] Write Protect is on
[ 1505.458033] sd 7:0:0:0: [sdb] Mode Sense: 0f 00 80 00
[ 1505.458749] sd 7:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[ 1505.461997] sdb:
[ 1505.464753] sd 7:0:0:0: [sdb] Attached SCSI removable disk
Is there something I’m missing on the laptop (Ubuntu) side to allow the usb-dev-mode connection. Is there something I can check on the Nano side using the “screen” login?
