What is the command to set the pwm fan to auto mode?
I used, To set max RPM: 100%
#echo 0 > /sys/devices/pwm-fan/target_pwm
(use 255 to 0 values to change the duty cycle/ RPM)
for 50%
#echo 127 > /sys/devices/pwm-fan/target_pwm
for 0%
#echo 255 > /sys/devices/pwm-fan/target_pwm
but now wanted to set it to automatic based on the module temp
hello vbhm,
do nothing. fan should turn-on by default when thermal above 51 degree.
please refer to Thermal Specifications for reference,
thanks
I have set it to echo 0 > /sys/devices/pwm-fan/target_pwm and now fan is off,but not getting ON even temp is more than 50
hello vbhm,
you should not have specify the target_pwm, since it’ll overwrite the settings.
Ok, my requirement is to set the fan to 100% duty cycle, then 50 then 0 and then reset to auto. how should I make this?
spatra
8
Hi Vbhm,
Can you please try simulating the callbacks from thermal subsystem to override the pwm values and let us know the status.
Steps:
Allow sw override: /sys/kernel/debug/bpmp/debug/soctherm/temp_sw_override
temp override knobs to tweak:
/sys/kernel/debug/bpmp/debug/soctherm/group_<Thermal_Group>/temp
Thermal_Group: AUX, CPU, GPU, PLLX
Modifying the temp will essentially invoke the callbacks and adjusts pwm value dynamically irrespective of the earlier set target_pwm value.
Thanks & Regards,
Sandipan
system
Closed
10
