I was using the odmfuse.sh script to burn the secure boot fuses. I was able to perform the burn of the secure-boot fuses in a jetson nano emmc board; however, I couldn’t burn the userspace fuses after that. In my test, I used the r32.4.3 L4T, which required a fix of an issue that provoked the disable of the secure boot during fuse burning following this post answer: topic144888
The command used to burn the secure boot fuses are the following:
sudo ./odmfuse.sh -i 0x21 -p -c PKC -k keys_priv.pem
Then, when trying to burd the userspace fuses, using the -o option of the odmfuse script, I got the following error:
*** Start fusing ...
./tegraflash.py --chip 0x21 --applet nvtboot_recovery.bin --cmd "blowfuses odmfuse_pkc.xml;"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0013 ] Parsing fuse info as per xml file
[ 0.0020 ] tegraparser --fuse_info odmfuse_pkc.xml blow_fuse_data.bin
[ 0.0028 ]
[ 0.0028 ] Generating RCM messages
[ 0.0035 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0041 ] RCM 0 is saved as rcm_0.rcm
[ 0.0046 ] RCM 1 is saved as rcm_1.rcm
[ 0.0046 ] List of rcm files are saved in rcm_list.xml
[ 0.0046 ]
[ 0.0046 ] Signing RCM messages
[ 0.0053 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0060 ] Assuming zero filled SBK key
[ 0.0099 ]
[ 0.0099 ] Copying signature to RCM mesages
[ 0.0106 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0116 ]
[ 0.0116 ] Boot Rom communication
[ 0.0122 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
[ 0.0129 ] BR_CID: 0x621010016445b507200000000c000100
[ 0.1298 ] RCM version 0X13
[ 0.2582 ] Boot Rom communication failed
[ 0.2582 ]
Error: Return value 3
Command tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
failed.
Regarding the procedure I followed, what could be causing this error?
Thanks,
Luis
