My GPU is not working on Jetson Nano which I have checked using the following command:
tf.config.list_physical_devices('GPU')
I am using “Jetson nano” My Jetpack is 4.6.1 I have cuda 10.2 I have cudatoolkit and cudnn installed in my environment with following versions:
cudatoolkit: 11.7.0
cudnn: 8.4.1.50
How can I enable the GPU on “Jetson Nano”?
Could you double-check your CUDA toolkit version?
We don’t support CUDA 11 on Jetson Nano.
$ apt show nvidia-jetpack
I have cuda 10-2 which came with jetpack 4.6.1, Not cuda-11
How do you install the TensorFlow package?
Is the package built with CUDA enabled?
Or could you try to install our prebuilt?
https://developer.download.nvidia.com/compute/redist/jp/v461/tensorflow/
