Hi Everyone,
I tried to found ‘‘How Can I solve this problem ?’’ But I’m not success. When I started my code , camera open with green screen. Who can wants to help for solve this problem ?
Thanks a lot.
Hi Everyone,
Thanks a lot.
• DeepStream Version
• TensorRT Version
• The pipeline being used
I will also suggest attaching the log of “/var/log/Xorg.0.log
” to the forum.
hello musa.karagoz,
please also share the Jetpack release you’re using. please check $ cat /etc/nv_tegra_relaese
for confirmation.
since it’s the camera ribbon flex, please also check your camera connections, you should have correct pin directions.
furthermore, please attach kernel logs (i.e. $ dmesg > klog.txt
) for digging into the actual failure.
