HDMI is always on connected status although cable don’t plug in
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 16384 x 16384
HDMI-0 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 890mm x 500mm
1280x720 60.00*+ 59.94 50.00
720x576 50.00
720x480 59.94
640x480 59.94
DP-0 connected primary 600x1024+0+0 right (normal left inverted right x axis y axis) 150mm x 100mm
1024x600 60.04*+
Screen resolution is not correct.
when i plug in hdmi to device, log show as below:
ac@vsm:~$ xrandr
720x576 50.00
720x480 59.94
640x480 59.94
1024x600 60.04*+
Screen resolution correct is 600x1024
This issue lead to touch issue
So, please help me for resolve this issue
Thank you
From the dmesg, below log shows tegra side is not able to read the edid from your monitor at all. Fallback edid is a hardcoded one we wrote in driver.
This means the display driver is not in expected behavior. What is the environment? Is this a custom carrier board or just NV nano developer kit?
What kind of HDMI monitor is that? Do you use any kind of adapter on it?
Sorry, i don’t understand “kind of HDMI monitor”, hdmi is same with devkit. Device is not connect to external monitor. We also don’t use any kind of adapter on it
Thank you
Then please check your hardware design and check why i2c is not able to read the edid first…
yes, i will check again.
Do you understand that we are talking about different issue here?
sorry about my understand ^^. I think that we should focus on hdmi always connected issue firstly.
Thank you!
The HDMI connected problem should not happen at all.
I just tried on my devkit and when hdmi cable is disconnected, xrandr will remove other modes.
Thus, you should check your hardware design regarding the hotplug detection first. And that may affect your edid read as well.
Plug out
$ xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
HDMI-0 disconnected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
1920x1080 (0x144) 148.500MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
Plug in
$ xrandr
HDMI-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 510mm x 290mm
1920x1080 60.00*+ 59.95 50.00
1680x1050 59.96
1600x1200 60.01
1600x900 60.00
1440x900 59.89
1280x1024 60.00
1280x800 59.81
1280x720 60.00 59.94 50.00
1024x768 60.01
800x600 60.32
720x576 50.00
720x480 59.94
720x400 70.04
640x480 59.94
