Hello, I am trying to get the Jetson Nano to work with a small HDMI display, but when connected to the jetson’s HDMI port nothing is displayed. both the settings menu and xrandr claim the display only supports 640x480, although it is a 2560x1440 display, and the same display works fine when connected to other computers.
According to other threads on this forum, the jetson driver blocks any attempt to create a custom resolution with xrandr and will only output resolutions supported by the monitor’s EDID data. Is there any possible way to override this behavior, or give the OS a different EDID to read from instead of the one from the display? I need to get this specific display working with the jetson because it is part of an embedded project i am working on and I have no other options.
Here is the display’s raw EDID hex data and the output of edid-decode:
00 ff ff ff ff ff ff 00 33 54 01 00 00 00 00 00
0c 1b 01 03 80 00 00 78 0a 07 f5 9a 56 4e 86 26
1e 50 54 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 ff 4f a0 96 50 00 10 a0 46 23
c2 00 5a a0 00 00 00 18 00 00 00 fc 00 4c 53 30
36 30 52 31 53 58 30 31 20 20 00 00 00 ff 00 30
30 30 30 30 30 30 30 20 20 20 20 20 00 00 00 fd
00 17 4b 0f f0 1e 00 0a 20 20 20 20 20 20 01 82
02 03 17 74 47 00 00 00 00 00 00 00 23 09 7f 07
66 03 0c 00 30 00 80 ff 4f a0 96 50 00 10 a0 46
23 c2 00 5a a0 00 00 00 18 ff 4f a0 96 50 00 10
a0 46 23 c2 00 5a a0 00 00 00 18 ff 4f a0 96 50
00 10 a0 46 23 c2 00 5a a0 00 00 00 18 ff 4f a0
96 50 00 10 a0 46 23 c2 00 5a a0 00 00 00 18 ff
4f a0 96 50 00 10 a0 46 23 c2 00 5a a0 00 00 00
18 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8d
Extracted contents:
header: 00 ff ff ff ff ff ff 00
serial number: 33 54 01 00 00 00 00 00 0c 1b
version: 01 03
basic params: 80 00 00 78 0a
chroma info: 07 f5 9a 56 4e 86 26 1e 50 54
established: 00 00 00
standard: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
descriptor 1: ff 4f a0 96 50 00 10 a0 46 23 c2 00 5a a0 00 00 00 18
descriptor 2: 00 00 00 fc 00 4c 53 30 36 30 52 31 53 58 30 31 20 20
descriptor 3: 00 00 00 ff 00 30 30 30 30 30 30 30 30 20 20 20 20 20
descriptor 4: 00 00 00 fd 00 17 4b 0f f0 1e 00 0a 20 20 20 20 20 20
extensions: 01
checksum: 82
Manufacturer: LZT Model 1 Serial Number 0
Made week 12 of 2017
EDID version: 1.3
Digital display
Image size is variable
Gamma: 2.20
Supported color formats: RGB 4:4:4, YCrCb 4:4:4
First detailed timing is preferred timing
Established timings supported:
Standard timings supported:
non-conformant standard timing (0 horiz)
Detailed mode: Clock 204.790 MHz, 90 mm x 160 mm
1440 1510 1545 1590 hborder 0
2560 2572 2574 2576 vborder 0
-hsync -vsync
Serial number: 00000000
Monitor ranges (GTF): 23-75Hz V, 15-240kHz H, max dotclock 300MHz
Has 1 extension blocks
Checksum: 0x82 (valid)
CEA extension block
Extension version: 3
19 bytes of CEA data
Video data block
Audio data block
Linear PCM, max channels 2
Supported sample rates (kHz): 192 176.4 96 88.2 48 44.1 32
Supported sample sizes (bits): 24 20 16
Vendor-specific data block, OUI 000c03 (HDMI)
Source physical address 3.0.0.0
Supports_AI
Basic audio support
Supports YCbCr 4:4:4
Supports YCbCr 4:2:2
4 native detailed modes
-hsync -vsync
-hsync -vsync
-hsync -vsync
-hsync -vsync
-hsync -vsync
Checksum: 0x8d (valid)
EDID block does NOT conform to EDID 1.3!
Name descriptor not terminated with a newline
Detailed block string not properly terminated
