Hi
I am kind of new in this world,
I am trying to install Tensorflow in my Jetson nano, problem is that CUDA version installed is 10.2 but when I try to run TF I got next error:
import error: libculas.so.10.0: cannot open shared object file: no such file or directory
How can I downgrade my CUDA version?
In case you need more info about my problem please let me know :)
To downgrade CUDA 10.0, you will need to reflash the device with the corresponding JetPack version.
For version 10.0, it should be JetPack4.3 or lower.
However, we recommends to use a TensorFlow package that supports CUDA 10.2 instead.
If you are using JetPack4.4 GA, you can use v2.2.0+nv20.6 or v1.15.2+nv20.6 for compatibility.
https://developer.download.nvidia.com/compute/redist/jp/v44/tensorflow/
