I am a student following the “Getting Started with AI on Jetson Nano” course. I am trying to make it so that if the value in the prediction widget reaches ~0.8, then it will play a sound file. I have imported the audio file into the Jupyter Notebook and am planning on playing the audio through an HDMI cable to a monitor.
My question is whether the JetPack comes with an audio player installed and if I can just run:
import os
file = “file.mp3”
os.system("mpg123 " + file)
to play audio or if I need some other module. In addition, what would be the variable inside of the code that is the inference value itself? Here is some of the code below:
Live Evaluation
import threading
import time
from utils import preprocess
import torch.nn.functional as F
state_widget = ipywidgets.ToggleButtons(options=['stop', 'live'], description='state', value='stop')
prediction_widget = ipywidgets.Text(description='prediction')
score_widgets = []
for category in dataset.categories:
score_widget = ipywidgets.FloatSlider(min=0.0, max=1.0, description=category, orientation='vertical')
score_widgets.append(score_widget)
def live(state_widget, model, camera, prediction_widget, score_widget):
global dataset
while state_widget.value == 'live':
image = camera.value
preprocessed = preprocess(image)
output = model(preprocessed)
output = F.softmax(output, dim=1).detach().cpu().numpy().flatten()
category_index = output.argmax()
prediction_widget.value = dataset.categories[category_index]
for i, score in enumerate(list(output)):
score_widgets[i].value = score
def start_live(change):
if change['new'] == 'live':
execute_thread = threading.Thread(target=live, args=(state_widget, model, camera, prediction_widget, score_widget))
execute_thread.start()
state_widget.observe(start_live, names='value')
live_execution_widget = ipywidgets.VBox([
ipywidgets.HBox(score_widgets),
prediction_widget,
state_widget
print("live_execution_widget created")
Training and Evaluation
BATCH_SIZE = 8
optimizer = torch.optim.Adam(model.parameters())
epochs_widget = ipywidgets.IntText(description='epochs', value=1)
eval_button = ipywidgets.Button(description='evaluate')
train_button = ipywidgets.Button(description='train')
loss_widget = ipywidgets.FloatText(description='loss')
accuracy_widget = ipywidgets.FloatText(description='accuracy')
progress_widget = ipywidgets.FloatProgress(min=0.0, max=1.0, description='progress')
def train_eval(is_training):
global BATCH_SIZE, LEARNING_RATE, MOMENTUM, model, dataset, optimizer, eval_button, train_button, accuracy_widget, loss_widget, progress_widget, state_widget
try:
train_loader = torch.utils.data.DataLoader(
dataset,
batch_size=BATCH_SIZE,
shuffle=True
state_widget.value = 'stop'
train_button.disabled = True
eval_button.disabled = True
time.sleep(1)
if is_training:
model = model.train()
else:
model = model.eval()
while epochs_widget.value > 0:
i = 0
sum_loss = 0.0
error_count = 0.0
for images, labels in iter(train_loader):
# send data to device
images = images.to(device)
labels = labels.to(device)
if is_training:
# zero gradients of parameters
optimizer.zero_grad()
# execute model to get outputs
outputs = model(images)
# compute loss
loss = F.cross_entropy(outputs, labels)
if is_training:
# run backpropogation to accumulate gradients
loss.backward()
# step optimizer to adjust parameters
optimizer.step()
# increment progress
error_count += len(torch.nonzero(outputs.argmax(1) - labels).flatten())
count = len(labels.flatten())
i += count
sum_loss += float(loss)
progress_widget.value = i / len(dataset)
loss_widget.value = sum_loss / i
accuracy_widget.value = 1.0 - error_count / i
if is_training:
epochs_widget.value = epochs_widget.value - 1
else:
break
except e:
pass
train_button.disabled = False
eval_button.disabled = False
state_widget.value = 'live'
train_button.on_click(lambda c: train_eval(is_training=True))
eval_button.on_click(lambda c: train_eval(is_training=False))
train_eval_widget = ipywidgets.VBox([
epochs_widget,
progress_widget,
loss_widget,
accuracy_widget,
ipywidgets.HBox([train_button, eval_button])
print("trainer configured and train_eval_widget created")
Trying to play noise when the slider on right reaches certain value
Thank you for your help.
