I bought a Jetson Nano on Amazon and discovered it’s a hybrid board - it reports as P3450-0000 (Developer Kit) but has an internal eMMC storage. DRAM is 2GB.
Update: I downloaded the PCN211181 overlay, applied it to my Linux_for_Tegra folder, and re-flashed the board using: sudo ./flash.sh jetson-nano-emmc mmcblk0p1
Unfortunately, the result is exactly the same:
The UART log still shows: Board: NVIDIA P3450-0000 and DRAM: 2 GiB.
The kernel still hangs/loops at: [ 0.000000] bootconsole [uart8250] enabled.
As I mentioned, the board was sold as a 4GB RAM version and physically appears to have the 4GB module, but the software seems stuck in this 2GB/P3450 identification.
Is there any way to force the installer or the bootloader to ignore the EEPROM ID and treat it as a P3448 (4GB) board? Or is there another specific DTB/configuration I should use for these hybrid eMMC boards that report as P3450?
No, your issue has nothing to do with “forcing” anything.
The value got 2GB is a known symptom when you didn’t apply the overlay correctly.
The overlay is to make the DRAM config correctly.
Please be aware that this overlay should not be applied to “Linux_for_Tegra” directly but to run on the “parent directory” of your Linux_for_Tegra.
Also, make sure every of your “P3448_A00_lpddr4_204Mhz_P987.cfg” got overwrite with the overlay correctly. I mean find “P3448_A00_lpddr4_204Mhz_P987.cfg” under your Linux_for_Tegra/bootloader directory and make sure only one file that has this name. If there are multiple, then make sure every of them got updated.
