NVIDIA Jetson Nano does not boot
Hello!
I have a NVIDIA Jetson Nano (Seeed ReComputer J1010) that does not boot, it only shows the NVIDIA logo.
Using MiniCom I got the following logs:
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Aug 13 2017, 15:25:34.
Port /dev/ttyUSB0, 08:53:13
Press CTRL-A Z for help on special keys
[0000.232] [L4T TegraBoot] (version 00.00.2018.01-l4t-8728f3cb)
[0000.237] Processing in cold boot mode Bootloader 2
[0000.242] A02 Bootrom Patch rev = 1023
[0000.245] Power-up reason: pmc por
[0000.248] No Battery Present
[0000.251] pmic max77620 reset reason
[0000.254] pmic max77620 NVERC : 0x40
[0000.258] RamCode = 1
[0000.260] Platform has DDR4 type RAM
[0000.264] max77620 disabling SD1 Remote Sense
[0000.268] Setting DDR voltage to 1125mv
[0000.272] Serial Number of Pmic Max77663: 0x1a176a
[0000.279] Entering ramdump check
[0000.282] Get RamDumpCarveOut = 0x0
[0000.286] RamDumpCarveOut=0x0,  RamDumperFlag=0xe59ff3f8
[0000.291] Last reboot was clean, booting normally!
[0000.295] Sdram initialization is successful
[0000.299] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.306] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.311] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.317] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.323] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.329] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.335] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.341] GSC3 Carveout Base=0x00000000bf300000 Size=0x00d00000
[0000.357] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.363] Platform-DebugCarveout: 0
[0000.366] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.372] Non secure mode, and RB not enabled.
[0000.376] *** Booting BFS0.
[0000.379] Initialize FailControl
[0000.382] Read PT from (0:3)
[0000.397] Csd NumOfBlocks=0
[0000.436] PT crc32 and magic check passed.
[0000.440] Using BFS PT to query partitions
[0000.444] PT: Partition LNX NOT found !
[0000.448] *** Booting KFS0.
[0000.450] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.456] BoardID = 3448, SKU = 0x2
[0000.460] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.465] Read GPT from (0:3)
[0000.473] Using GPT Primary to query partitions
[0000.478] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.484] Loading Tboot-CPU binary
[0000.490] Verifying TBC in OdmNonSecureSBK mode
[0000.500] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.507] Bootloader downloaded successfully.
[0000.511] Downloaded Tboot-CPU binary to 0xa0000258
[0000.516] MAX77620_GPIO5 configured
[0000.519] CPU power rail is up
[0000.522] CPU clock enabled
[0000.526] Performing RAM repair
[0000.529] Updating A64 Warmreset Address to 0xa00002e9
[0000.534] BoardID = 3448, SKU = 0x2
[0000.537] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.543] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.549] Loading NvTbootBootloaderDTB
[0000.566] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.638] Bootloader DTB Load Address: 0x83000000
[0000.642] BoardID = 3448, SKU = 0x2
[0000.646] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.651] Loading NvTbootKernelDTB
[0000.673] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.744] Kernel DTB Load Address: 0x83100000
[0000.748] BoardID = 3448, SKU = 0x2
[0000.751] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.757] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.764] Loading cboot binary
[0000.775] Verifying EBT in OdmNonSecureSBK mode
[0000.817] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.824] Bootloader downloaded successfully.
[0000.828] BoardID = 3448, SKU = 0x2
[0000.831] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.837] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.844] PT: Partition NCT NOT found !
[0000.847] Warning: Find Partition via PT Failed
[0000.852] Next binary entry address: 0x92c00258
[0000.856] BoardId: 3448
[0000.861] Overriding pmu board id with proc board id
[0000.865] Display board id is not available
[0000.870] BoardID = 3448, SKU = 0x2
[0000.873] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.879] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.892] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.948] /bpmp deleted
[0000.950] SC7EntryFw header found loaded at 0xff700000
[0001.136] OVR2 PMIC
[0001.138] Bpmp FW successfully loaded
[0001.141] BoardID = 3448, SKU = 0x2
[0001.144] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0001.150] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.158] WB0 init successfully at 0xff780000
[0001.162] Verifying NvTbootWb0 in OdmNonSecureSBK mode
[0001.167] Set NvDecSticky Bits
[0001.171] GSC2 address ff53fffc value c0edbbcc
[0001.177] GSC MC Settings done
[0001.180] BoardID = 3448, SKU = 0x2
[0001.183] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0001.190] TOS Image length 53680
[0001.193]  Monitor size 53680
[0001.196]  OS size 0
[0001.201] Secure Os AES-CMAC Verification Success!
[0001.205] TOS image cipher info: plaintext
[0001.209] Loading and Validation of Secure OS Successful
[0001.225] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.230] NvTbootPackSdramParams: start.
[0001.235] NvTbootPackSdramParams: done.
[0001.239] Tegraboot started after 161396 us
[0001.243] Basic modules init took 745458 us
[0001.247] Sec Bootdevice Read Time = 58 ms, Read Size = 3682 KB
[0001.252] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.258] Next stage binary read took 7399 us
[0001.262] Carveout took -34791 us
[0001.265] CPU initialization took 389406 us
[0001.269] Total time taken by TegraBoot 1107472 us
[0001.274] Starting CPU & Halting co-processor
64NOTICE:  BL31: v1.3(release):b5eeb33
NOTICE:  BL31: Built : 08:56:32, Feb 19 2022
ERROR:   Error initializing runtime service trusty_fast
[0001.395] RamCode = 1
[0001.397] get_emc_table_offset: Can't find emc-table node
[0001.402] LPDDR4 Training: Can't find emc-table node
[0001.445]
[0001.446] Debug Init done
[0001.448] Marked DTB cacheable
[0001.451] Bootloader DTB loaded at 0x83000000
[0001.456] Marked DTB cacheable
[0001.459] Kernel DTB loaded at 0x83100000
[0001.463] DeviceTree Init done
[0001.476] Pinmux applied successfully
[0001.480] gicd_base: 0x50041000
[0001.483] gicc_base: 0x50042000
[0001.486] Interrupts Init done
[0001.491] Using base:0x60005090 & irq:208 for tick-timer
[0001.496] Using base:0x60005098 for delay-timer
[0001.500] platform_init_timer: DONE
[0001.504] Timer(tick) Init done
[0001.508] osc freq = 38400 khz
[0001.511]
[0001.512] Welcome to L4T Cboot
[0001.515]
[0001.517] Cboot Version: 00.00.2018.01-t210-a2f2e4b8
[0001.522] calling constructors
[0001.524] initializing heap
[0001.527] initializing threads
[0001.530] initializing timers
[0001.533] creating bootstrap completion thread
[0001.537] top of bootstrap2()
[0001.540] CPU: ARM Cortex A57
[0001.543] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.548] initializing platform
[0001.602] Config for emmc ddr50 mode completed
[0001.606] sdmmc bdev is already initialized
[0001.610] Enable APE clock
[0001.613] Un-powergate APE partition
[0001.616] of_register: registering tegra_udc to of_hal
[0001.621] of_register: registering inv20628-driver to of_hal
[0001.627] of_register: registering ads1015-driver to of_hal
[0001.632] of_register: registering lp8557-bl-driver to of_hal
[0001.638] of_register: registering bq2419x_charger to of_hal
[0001.644] of_register: registering bq27441_fuel_gauge to of_hal
[0001.655] gpio framework initialized
[0001.659] of_register: registering tca9539_gpio to of_hal
[0001.664] of_register: registering tca9539_gpio to of_hal
[0001.669] of_register: registering i2c_bus_driver to of_hal
[0001.675] of_register: registering i2c_bus_driver to of_hal
[0001.680] of_register: registering i2c_bus_driver to of_hal
[0001.686] pmic framework initialized
[0001.690] of_register: registering max77620_pmic to of_hal
[0001.695] regulator framework initialized
[0001.699] of_register: registering tps65132_bl_driver to of_hal
[0001.705] initializing target
[0001.711] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.719] board ID = D78, board SKU = 2
[0001.725] fixed regulator driver initialized
[0001.743] initializing OF layer
[0001.746] NCK carveout not present
[0001.749] Skipping dts_overrides
[0001.753] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.770] I2C Bus Init done
[0001.772] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.783] I2C Bus Init done
[0001.785] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.796] I2C Bus Init done
[0001.798] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.809] I2C Bus Init done
[0001.811] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.822] I2C Bus Init done
[0001.824] of_children_init: Ops found for compatible string maxim,max77620
[0001.835] max77620_init using irq 118
[0001.839] register 'maxim,max77620' pmic
[0001.844] gpio_driver_register: register 'max77620-gpio' driver
[0001.850] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.860] I2C Bus Init done
[0001.864] NCK carveout not present
[0001.873] Find /i2c@7000c000's alias i2c0
[0001.877] get eeprom at 1-a0, size 256, type 0
[0001.886] Find /i2c@7000c500's alias i2c2
[0001.890] get eeprom at 3-a0, size 256, type 0
[0001.894] get eeprom at 3-ae, size 256, type 0
[0001.899] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.904] I2C slave not started
[0001.907] I2C write failed
[0001.910] Writing offset failed
[0001.913] eeprom_init: EEPROM read failed
[0001.917] pm_ids_update: eeprom init failed
[0001.921] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.951] pm_ids_update: The pm board id is 3448-0002-402
[0001.958] Adding plugin-manager/ids/3448-0002-402=/i2c@7000c500:module@0x50
[0001.966] pm_ids_update: pm id update successful
[0001.971] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.001] pm_ids_update: The pm board id is 3449-0000-rXj
[0002.007] Adding plugin-manager/ids/3449-0000-rXj=/i2c@7000c500:module@0x57
[0002.015] pm_ids_update: pm id update successful
[0002.045] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.051] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.059] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.065] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.073] updating /chosen/nvidia,ethernet-mac node 3c:6d:66:15:00:a4
[0002.079] Plugin Manager: Parse ODM data 0x000a4000
[0002.092] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x7
[0002.106] Find /i2c@7000c000's alias i2c0
[0002.110] get eeprom at 1-a0, size 256, type 0
[0002.119] Find /i2c@7000c500's alias i2c2
[0002.123] get eeprom at 3-a0, size 256, type 0
[0002.127] get eeprom at 3-ae, size 256, type 0
[0002.132] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.137] I2C slave not started
[0002.140] I2C write failed
[0002.142] Writing offset failed
[0002.145] eeprom_init: EEPROM read failed
[0002.149] pm_ids_update: eeprom init failed
[0002.154] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.184] pm_ids_update: The pm board id is 3448-0002-402
[0002.190] Adding plugin-manager/ids/3448-0002-402=/i2c@7000c500:module@0x50
[0002.197] pm_ids_update: pm id update successful
[0002.201] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.231] pm_ids_update: The pm board id is 3449-0000-rXj
[0002.238] Adding plugin-manager/ids/3449-0000-rXj=/i2c@7000c500:module@0x57
[0002.245] pm_ids_update: pm id update successful
[0002.275] Add serial number:1424624335844 as DT property
[0002.283] Applying platform configs
[0002.289] platform-init is not present. Skipping
[0002.294] calling apps_init()
[0002.315] Found 17 GPT partitions in "sdmmc3_user"
[0002.320] Proceeding to Cold Boot
[0002.323] starting app android_boot_app
[0002.327] Device state: unlocked
[0002.330] display console init
[0002.338] could not find regulator
[0002.341] hdmi cable connected
[0002.357] edid read success
[0002.372] eDT entry for leds-pwm not found
d[0002.379] id read success
[0002.382] width = 640, height = 480, frequency = 25174825
[0002.387] width = 640, height = 480, frequency = 25174825
[0002.393] width = 640, height = 480, frequency = 25174825
[0002.398] width = 640, height = 480, frequency = 25174825
[0002.403] width = 1920, height = 1080, frequency = 148500000
[0002.409] width = 720, height = 480, frequency = 27000000
[0002.414] width = 1920, height = 1080, frequency = 148351648
[0002.420] width = 1920, height = 1080, frequency = 148351648
[0002.426] width = 1280, height = 720, frequency = 74175824
[0002.431] width = 1280, height = 720, frequency = 74175824
[0002.437] width = 720, height = 480, frequency = 26973026
[0002.442] width = 720, height = 576, frequency = 26973026
[0002.447] width = 720, height = 480, frequency = 26973026
[0002.453] width = 720, height = 576, frequency = 26973026
[0002.458] width = 640, height = 480, frequency = 25174825
[0002.463] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.471] tmds-config node not found
[0002.475] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltageps
[0002.490] setting 'vdd-1v8' regulator to 1800000 micro volts
[0002.498] could not find regulator
[0002.501] could not find regulator
[0002.504] could not find regulator
[0002.533] using default cmu settings
[0002.536] dc_hdmi_enable, starting HDMI initialisation
[0002.542] dc_hdmi_enable, HDMI initialisation complete
[0002.547] list and configure display window
[0002.556] display console init completed
[0002.567] subnode volume_up is not found !
[0002.571] subnode back is not found !
[0002.575] subnode volume_down is not found !
[0002.579] subnode menu is not found !
[0002.582] Gpio keyboard init success
[0002.630] found decompressor handler: lz4-legacy
[0002.645] decompressing blob (type 1)...
[0002.714] load_bmp_blob: panelresolution=1080 type=3
[0002.718] -------> se_aes_verify_sbk_clear: 747
[0002.723] se_aes_verify_sbk_clear: Error
[0002.727] SE operation failed
[0002.730] bl_battery_charging: connected to external power supply
[0002.745] device_query_partition_size: failed to open partition sdmmc3_user:MS!
[0002.753] MSC Partition not found
[0002.762] device_query_partition_size: failed to open partition sdmmc3_user:US!
[0002.770] USP partition read failed!
[0002.773] blob_init: blob-partition USP header read failed
[0002.779] android_boot Unable to update recovery partition
[0002.784] kfs_getpartname: name = LNX
[0002.788] Loading kernel from LNX
[0002.886] load kernel from storage
[0002.896] decompressor handler not found
[0002.929] Successfully loaded kernel and ramdisk images
[0002.934] board ID = D78, board SKU = 2
[0002.939] load_bmp_blob: panelresolution=1080 type=3
[0003.424] display bmp image done
[0003.427] NCK carveout not present
[0003.431] Skipping dts_overrides
[0003.434] NCK carveout not present
[0003.443] Find /i2c@7000c000's alias i2c0
[0003.447] get eeprom at 1-a0, size 256, type 0
[0003.456] Find /i2c@7000c500's alias i2c2
[0003.460] get eeprom at 3-a0, size 256, type 0
[0003.464] get eeprom at 3-ae, size 256, type 0
[0003.469] pm_ids_update: Updating 1,a0, size 256, type 0
[0003.474] I2C slave not started
[0003.477] I2C write failed
[0003.479] Writing offset failed
[0003.483] eeprom_init: EEPROM read failed
[0003.486] pm_ids_update: eeprom init failed
[0003.491] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.521] pm_ids_update: The pm board id is 3448-0002-402
[0003.527] Adding plugin-manager/ids/3448-0002-402=/i2c@7000c500:module@0x50
[0003.536] pm_ids_update: pm id update successful
[0003.540] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.571] pm_ids_update: The pm board id is 3449-0000-rXj
[0003.577] Adding plugin-manager/ids/3449-0000-rXj=/i2c@7000c500:module@0x57
[0003.585] pm_ids_update: pm id update successful
[0003.615] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.621] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0003.629] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.635] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0003.643] updating /chosen/nvidia,ethernet-mac node 3c:6d:66:15:00:a4
[0003.649] Plugin Manager: Parse ODM data 0x000a4000
[0003.662] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x7
[0003.670] Add serial number:1424624335844 as DT property
[0003.679] "bpmp" doesn't exist, creating
[0003.684] Updated bpmp info to DTB
[0003.689] Updated initrd info to DTB
[0003.693] "proc-board" doesn't exist, creating
[0003.699] Updated board info to DTB
[0003.702] "pmu-board" doesn't exist, creating
[0003.708] Updated board info to DTB
[0003.711] "display-board" doesn't exist, creating
[0003.717] Updated board info to DTB
[0003.721] "reset" doesn't exist, creating
[0003.725] Updated reset info to DTB
[0003.729] Cmdline: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype
[0003.768] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0003.774] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[0003.791] Updated bootarg info to DTB
[0003.795] Adding uuid 000000016441f806080000000ffd8340 to DT
[0003.801] Adding eks info 0 to DT
[0003.806] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0003.812] Updated memory info to DTB
[0003.820] set vdd_core voltage to 1075 mv
[0003.824] setting 'vdd-core' regulator to 1075000 micro volts
[0003.829] Found secure-pmc; disable BPMP
U-Boot 2020.04-g4335beb (Feb 19 2022 - 08:56:35 -0800)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM:  2 GiB
MMC:   sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Hit any key to stop autoboot:  0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
894 bytes read in 20 ms (43 KiB/s)
1:      primary kernel
Retrieving file: /boot/initrd
7159624 bytes read in 174 ms (39.2 MiB/s)
Retrieving file: /boot/Image
34484232 bytes read in 781 ms (42.1 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resiz
## Flattened Device Tree blob at 83100000
   Booting using the fdt blob at 0x83100000
ERROR: reserving fdt memory region failed (addr=0 size=0)
   Using Device Tree in place at 0000000083100000, end 000000008317ce8d
copying carveout for /host1x@50000000/dc@54200000...
copying carveout for /host1x@50000000/dc@54240000...
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5434-d8000) (2
[    0.000000] Boot CPU: AArch64 Processor [411fd071]
[    0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[    0.000000] OF: fdt: - 80000000 ,  3f200000
[    0.000000] OF: fdt: - c0000000 ,  3ee00000
[    0.000000] Found tegra_fbmem: 00800000@92cb4000
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[0000.204] [L4T TegraBoot] (version 00.00.2018.01-l4t-8728f3cb)
[0000.209] Processing in cold boot mode Bootloader 2
[0000.214] A02 Bootrom Patch rev = 1023
[0000.217] Power-up reason: software reset
[0000.221] No Battery Present
[0000.224] pmic max77620 reset reason
[0000.227] pmic max77620 NVERC : 0x0
[0000.230] RamCode = 1
[0000.233] Platform has DDR4 type RAM
[0000.236] max77620 disabling SD1 Remote Sense
[0000.240] Setting DDR voltage to 1125mv
[0000.244] Serial Number of Pmic Max77663: 0x1a176a
[0000.252] Entering ramdump check
[0000.255] Get RamDumpCarveOut = 0x0
[0000.258] RamDumpCarveOut=0x0,  RamDumperFlag=0xe59ff3f8
[0000.263] Last reboot was clean, booting normally!
[0000.268] Sdram initialization is successful
[0000.272] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.278] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.284] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.290] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.296] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.301] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.307] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.313] GSC3 Carveout Base=0x00000000bf300000 Size=0x00d00000
[0000.329] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.335] Platform-DebugCarveout: 0
[0000.338] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.344] Non secure mode, and RB not enabled.
[0000.348] *** Booting BFS0.
[0000.351] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.357] Read PT from (0:3)
[0000.372] Csd NumOfBlocks=0
[0000.411] PT crc32 and magic check passed.
[0000.415] Using BFS PT to query partitions
[0000.419] PT: Partition LNX NOT found !
[0000.423] *** Booting KFS0.
[0000.426] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.432] BoardID = 3448, SKU = 0x2
[0000.435] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.441] Read GPT from (0:3)
[0000.449] Using GPT Primary to query partitions
[0000.454] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.460] Loading Tboot-CPU binary
[0000.466] Verifying TBC in OdmNonSecureSBK mode
[0000.476] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.483] Bootloader downloaded successfully.
[0000.487] Downloaded Tboot-CPU binary to 0xa0000258
[0000.492] MAX77620_GPIO5 configured
[0000.495] CPU power rail is up
[0000.498] CPU clock enabled
[0000.502] Performing RAM repair
[0000.505] Updating A64 Warmreset Address to 0xa00002e9
[0000.510] BoardID = 3448, SKU = 0x2
[0000.513] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.519] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.525] Loading NvTbootBootloaderDTB
[0000.542] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.614] Bootloader DTB Load Address: 0x83000000
[0000.618] BoardID = 3448, SKU = 0x2
[0000.621] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.627] Loading NvTbootKernelDTB
[0000.644] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.715] Kernel DTB Load Address: 0x83100000
[0000.719] BoardID = 3448, SKU = 0x2
[0000.722] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.728] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.736] Loading cboot binary
[0000.746] Verifying EBT in OdmNonSecureSBK mode
[0000.788] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.795] Bootloader downloaded successfully.
[0000.799] BoardID = 3448, SKU = 0x2
[0000.802] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.808] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.815] PT: Partition NCT NOT found !
[0000.818] Warning: Find Partition via PT Failed
[0000.823] Next binary entry address: 0x92c00258
[0000.827] BoardId: 3448
[0000.832] Overriding pmu board id with proc board id
[0000.837] Display board id is not available
[0000.841] BoardID = 3448, SKU = 0x2
[0000.844] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.850] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.863] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.919] /bpmp deleted
[0000.921] SC7EntryFw header found loaded at 0xff700000
[0001.107] OVR2 PMIC
[0001.109] Bpmp FW successfully loaded
[0001.112] BoardID = 3448, SKU = 0x2
[0001.116] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0001.122] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.129] WB0 init successfully at 0xff780000
[0001.133] Verifying NvTbootWb0 in OdmNonSecureSBK mode
[0001.138] Set NvDecSticky Bits
[0001.142] GSC2 address ff53fffc value c0edbbcc
[0001.148] GSC MC Settings done
[0001.151] BoardID = 3448, SKU = 0x2
[0001.154] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0001.161] TOS Image length 53680
[0001.164]  Monitor size 53680
[0001.167]  OS size 0
[0001.172] Secure Os AES-CMAC Verification Success!
[0001.177] TOS image cipher info: plaintext
[0001.181] Loading and Validation of Secure OS Successful
[0001.197] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.201] NvTbootPackSdramParams: start.
[0001.206] NvTbootPackSdramParams: done.
[0001.210] Tegraboot started after 132666 us
[0001.214] Basic modules init took 744584 us
[0001.218] Sec Bootdevice Read Time = 54 ms, Read Size = 3682 KB
[0001.224] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.229] Next stage binary read took 7395 us
[0001.233] Carveout took -34786 us
[0001.237] CPU initialization took 389651 us
[0001.241] Total time taken by TegraBoot 1106844 us
[0001.245] Starting CPU & Halting co-processor
[0001.367] RamCode = 1
[0001.369] get_emc_table_offset: Can't find emc-table node
[0001.374] LPDDR4 Training: Can't find emc-table node
[0001.415]
[0001.416] Debug Init done
[0001.419] Marked DTB cacheable
[0001.422] Bootloader DTB loaded at 0x83000000
[0001.426] Marked DTB cacheable
[0001.429] Kernel DTB loaded at 0x83100000
[0001.433] DeviceTree Init done
[0001.446] Pinmux applied successfully
[0001.451] gicd_base: 0x50041000
[0001.454] gicc_base: 0x50042000
[0001.457] Interrupts Init done
[0001.461] Using base:0x60005090 & irq:208 for tick-timer
[0001.466] Using base:0x60005098 for delay-timer
[0001.471] platform_init_timer: DONE
[0001.474] Timer(tick) Init done
[0001.478] osc freq = 38400 khz
[0001.482]
[0001.483] Welcome to L4T Cboot
[0001.486]
[0001.487] Cboot Version: 00.00.2018.01-t210-a2f2e4b8
[0001.492] calling constructors
[0001.495] initializing heap
[0001.498] initializing threads
[0001.501] initializing timers
[0001.504] creating bootstrap completion thread
[0001.508] top of bootstrap2()
[0001.511] CPU: ARM Cortex A57
[0001.514] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.519] initializing platform
[0001.572] Config for emmc ddr50 mode completed
[0001.576] sdmmc bdev is already initialized
[0001.581] Enable APE clock
[0001.583] Un-powergate APE partition
[0001.587] of_register: registering tegra_udc to of_hal
[0001.592] of_register: registering inv20628-driver to of_hal
[0001.597] of_register: registering ads1015-driver to of_hal
[0001.603] of_register: registering lp8557-bl-driver to of_hal
[0001.609] of_register: registering bq2419x_charger to of_hal
[0001.614] of_register: registering bq27441_fuel_gauge to of_hal
[0001.626] gpio framework initialized
[0001.629] of_register: registering tca9539_gpio to of_hal
[0001.635] of_register: registering tca9539_gpio to of_hal
[0001.640] of_register: registering i2c_bus_driver to of_hal
[0001.646] of_register: registering i2c_bus_driver to of_hal
[0001.651] of_register: registering i2c_bus_driver to of_hal
[0001.657] pmic framework initialized
[0001.660] of_register: registering max77620_pmic to of_hal
[0001.666] regulator framework initialized
[0001.670] of_register: registering tps65132_bl_driver to of_hal
[0001.675] initializing target
[0001.681] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.689] board ID = D78, board SKU = 2
[0001.696] fixed regulator driver initialized
[0001.713] initializing OF layer
[0001.716] NCK carveout not present
[0001.720] Skipping dts_overrides
[0001.724] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.740] I2C Bus Init done
[0001.743] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.753] I2C Bus Init done
[0001.756] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.766] I2C Bus Init done
[0001.769] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.779] I2C Bus Init done
[0001.782] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.792] I2C Bus Init done
[0001.795] of_children_init: Ops found for compatible string maxim,max77620
[0001.805] max77620_init using irq 118
[0001.810] register 'maxim,max77620' pmic
[0001.814] gpio_driver_register: register 'max77620-gpio' driver
[0001.821] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.831] I2C Bus Init done
[0001.835] NCK carveout not present
[0001.844] Find /i2c@7000c000's alias i2c0
[0001.848] get eeprom at 1-a0, size 256, type 0
[0001.857] Find /i2c@7000c500's alias i2c2
[0001.861] get eeprom at 3-a0, size 256, type 0
[0001.865] get eeprom at 3-ae, size 256, type 0
[0001.869] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.875] I2C slave not started
[0001.878] I2C write failed
[0001.880] Writing offset failed
[0001.883] eeprom_init: EEPROM read failed
[0001.887] pm_ids_update: eeprom init failed
[0001.891] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.921] pm_ids_update: The pm board id is 3448-0002-402
[0001.928] Adding plugin-manager/ids/3448-0002-402=/i2c@7000c500:module@0x50
[0001.937] pm_ids_update: pm id update successful
[0001.941] pm_ids_update: Updating 3,ae, size 256, type 0
[0001.971] pm_ids_update: The pm board id is 3449-0000-rXj
[0001.978] Adding plugin-manager/ids/3449-0000-rXj=/i2c@7000c500:module@0x57
[0001.985] pm_ids_update: pm id update successful
[0002.016] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.022] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.030] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.035] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.044] updating /chosen/nvidia,ethernet-mac node 3c:6d:66:15:00:a4
[0002.050] Plugin Manager: Parse ODM data 0x000a4000
[0002.062] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x7
[0002.077] Find /i2c@7000c000's alias i2c0
[0002.081] get eeprom at 1-a0, size 256, type 0
[0002.089] Find /i2c@7000c500's alias i2c2
[0002.093] get eeprom at 3-a0, size 256, type 0
[0002.098] get eeprom at 3-ae, size 256, type 0
[0002.102] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.107] I2C slave not started
[0002.110] I2C write failed
[0002.113] Writing offset failed
[0002.116] eeprom_init: EEPROM read failed
[0002.120] pm_ids_update: eeprom init failed
[0002.124] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.154] pm_ids_update: The pm board id is 3448-0002-402
[0002.161] Adding plugin-manager/ids/3448-0002-402=/i2c@7000c500:module@0x50
[0002.167] pm_ids_update: pm id update successful
[0002.172] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.202] pm_ids_update: The pm board id is 3449-0000-rXj
[0002.208] Adding plugin-manager/ids/3449-0000-rXj=/i2c@7000c500:module@0x57
[0002.215] pm_ids_update: pm id update successful
[0002.246] Add serial number:1424624335844 as DT property
[0002.253] Applying platform configs
[0002.260] platform-init is not present. Skipping
[0002.264] calling apps_init()
[0002.285] Found 17 GPT partitions in "sdmmc3_user"
[0002.290] Proceeding to Cold Boot
[0002.293] starting app android_boot_app
[0002.297] Device state: unlocked
[0002.300] display console init
[0002.309] could not find regulator
[0002.312] hdmi cable connected
[0002.327] edid read success
[0002.343] eDT entry for leds-pwm not found
d[0002.350] id read success
[0002.352] width = 640, height = 480, frequency = 25174825
[0002.358] width = 640, height = 480, frequency = 25174825
[0002.363] width = 640, height = 480, frequency = 25174825
[0002.369] width = 640, height = 480, frequency = 25174825
[0002.374] width = 1920, height = 1080, frequency = 148500000
[0002.380] width = 720, height = 480, frequency = 27000000
[0002.385] width = 1920, height = 1080, frequency = 148351648
[0002.391] width = 1920, height = 1080, frequency = 148351648
[0002.396] width = 1280, height = 720, frequency = 74175824
[0002.402] width = 1280, height = 720, frequency = 74175824
[0002.407] width = 720, height = 480, frequency = 26973026
[0002.413] width = 720, height = 576, frequency = 26973026
[0002.418] width = 720, height = 480, frequency = 26973026
[0002.423] width = 720, height = 576, frequency = 26973026
[0002.429] width = 640, height = 480, frequency = 25174825
[0002.434] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.442] tmds-config node not found
[0002.446] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltageps
[0002.461] setting 'vdd-1v8' regulator to 1800000 micro volts
[0002.468] could not find regulator
[0002.472] could not find regulator
[0002.475] could not find regulator
[0002.503] using default cmu settings
[0002.507] dc_hdmi_enable, starting HDMI initialisation
[0002.513] dc_hdmi_enable, HDMI initialisation complete
[0002.518] list and configure display window
[0002.527] display console init completed
[0002.538] subnode volume_up is not found !
[0002.542] subnode back is not found !
[0002.545] subnode volume_down is not found !
[0002.549] subnode menu is not found !
[0002.553] Gpio keyboard init success
[0002.600] found decompressor handler: lz4-legacy
[0002.615] decompressing blob (type 1)...
[0002.684] load_bmp_blob: panelresolution=1080 type=3
[0002.689] -------> se_aes_verify_sbk_clear: 747
[0002.693] se_aes_verify_sbk_clear: Error
[0002.697] SE operation failed
[0002.700] bl_battery_charging: connected to external power supply
[0002.715] device_query_partition_size: failed to open partition sdmmc3_user:MS!
[0002.723] MSC Partition not found
[0002.732] device_query_partition_size: failed to open partition sdmmc3_user:US!
[0002.740] USP partition read failed!
[0002.743] blob_init: blob-partition USP header read failed
[0002.749] android_boot Unable to update recovery partition
[0002.754] kfs_getpartname: name = LNX
[0002.758] Loading kernel from LNX
[0002.847] load kernel from storage
[0002.856] decompressor handler not found
[0002.890] Successfully loaded kernel and ramdisk images
[0002.895] board ID = D78, board SKU = 2
[0002.900] load_bmp_blob: panelresolution=1080 type=3
[0003.385] display bmp image done
[0003.388] NCK carveout not present
[0003.391] Skipping dts_overrides
[0003.394] NCK carveout not present
[0003.404] Find /i2c@7000c000's alias i2c0
[0003.408] get eeprom at 1-a0, size 256, type 0
[0003.417] Find /i2c@7000c500's alias i2c2
[0003.421] get eeprom at 3-a0, size 256, type 0
[0003.425] get eeprom at 3-ae, size 256, type 0
[0003.429] pm_ids_update: Updating 1,a0, size 256, type 0
[0003.435] I2C slave not started
[0003.438] I2C write failed
[0003.440] Writing offset failed
[0003.443] eeprom_init: EEPROM read failed
[0003.447] pm_ids_update: eeprom init failed
[0003.451] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.481] pm_ids_update: The pm board id is 3448-0002-402
[0003.488] Adding plugin-manager/ids/3448-0002-402=/i2c@7000c500:module@0x50
[0003.497] pm_ids_update: pm id update successful
[0003.501] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.531] pm_ids_update: The pm board id is 3449-0000-rXj
[0003.538] Adding plugin-manager/ids/3449-0000-rXj=/i2c@7000c500:module@0x57
[0003.546] pm_ids_update: pm id update successful
[0003.576] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.582] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0003.590] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.595] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0003.604] updating /chosen/nvidia,ethernet-mac node 3c:6d:66:15:00:a4
[0003.610] Plugin Manager: Parse ODM data 0x000a4000
[0003.622] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x7
[0003.631] Add serial number:1424624335844 as DT property
[0003.640] "bpmp" doesn't exist, creating
[0003.645] Updated bpmp info to DTB
[0003.650] Updated initrd info to DTB
[0003.653] "proc-board" doesn't exist, creating
[0003.660] Updated board info to DTB
[0003.663] "pmu-board" doesn't exist, creating
[0003.669] Updated board info to DTB
[0003.672] "display-board" doesn't exist, creating
[0003.678] Updated board info to DTB
[0003.681] "reset" doesn't exist, creating
[0003.686] Updated reset info to DTB
[0003.690] Cmdline: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype
[0003.729] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0003.734] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[0003.752] Updated bootarg info to DTB
[0003.756] Adding uuid 000000016441f806080000000ffd8340 to DT
[0003.761] Adding eks info 0 to DT
[0003.767] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0003.773] Updated memory info to DTB
[0003.781] set vdd_core voltage to 1075 mv
[0003.784] setting 'vdd-core' regulator to 1075000 micro volts
[0003.790] Found secure-pmc; disable BPMP
After a while the kernel trys to start again.
I have done the following:
  • Used the SDK manager on Ubuntu 18.04;
  • Flashed a new OS (emmc);
  • Installed an image on an SD card using the tutorial found here.
The flashing seems to correctly occur. The terminal of the SDK manager does not mention any error.
Still, nothing seems to change the current state of the device.
Any idea on how to fix this issue?
Is this a non-developer kit carrier board with an eMMC model of Nano? Is this the older Nano, and not Xavier nor Orin? I ask because dev kits don’t have an eMMC model of Nano module, and eMMC modules normally are sold by third parties who attach them to their carrier board. It is possible though to attach an eMMC module to an actual developer’s kit carrier board and have that work. Regardless, the point is that the software required for flashing usually differs if the carrier board is different.
Different pins of the module can have different functions. This aids in designing carrier boards since lane routing can be changed. It also means the lane routing has to be in the firmware via a device tree (the functions on the carrier board are generally not “plug-n-play” and the device tree defines that hardware). Third party carrier board manufacturers will do one of the following:
  • Provide a patch to the dev kit flash software (usually just the device tree).
  • Provide a rebranded flash software (with some sort of device tree change being part of rebranding).
  • State that their carrier board is an exact match to the dev kit board and that no patch is needed.
Please note that in particular a dev kit has the SD card mounted on the bottom of the module, and that an eMMC model only has the SD card mounted on the carrier board. The software support for those two is quite different. The SD card image does not work with (nor apply to) eMMC models. Even if this is an NVIDIA carrier board you would need a full flash due to the eMMC, and SD cards do not flash anything on the module itself.
Incidentally, normal eMMC models put non-rootfs content (the SD card has rootfs content; eMMC puts it in a partition) in various other partitions. The SD card model has the equivalent of that other non-rootfs content in QSPI memory on the module. Even if this were an SD card model you would still have to flash the module once with a release compatible with the rootfs you are putting in before it would work with that SD card content. eMMC models just don’t work with that content without jumping through some very specific flash procedures.
So to start with you have to identify if this is truly an eMMC module, and if it is, exactly which carrier board it is using. Most likely you would then need to look at the documentation from that vendor as to what is needed for flash. It is highly unlikely that an SD card would ever work without special steps for any eMMC model.
