Is there a way to get the cpu temperature via python?
I want to monitor the temperature while I let my nano run object detection for an extended period of time.
Hi angelo_v,
No, we don’t have the sample for python. You may refer to current method to implement it.
Hi you can use.
cat /sys/devices/virtual/thermal/thermal_zone*/temp command from python.
For example
import os
temp = os.popen(“cat /sys/devices/virtual/thermal/thermal_zone0/temp”).read()
print ( temp )
result will be the temperature from the thermal zone 0.
