We have a code for object tracking using YOLOv4-Tiny that we are running on Jetson Nano 2gb as well as Jetson Nano 4gb. We upgraded to 4gb as the FPS on 2gb was 1.7-1.8.
After running the codes on 4gb Jetson Nano we are still getting the same FPS as that of 2gb Jetson Nano.
How can I Increase FPS??
I tried to put down commands but no change in output and with respect to example code from github I am not able to find specific reason why am I getting 1-2 fps
Support you are using TensorRT with FP16 mode, is that correct?
If yes, could you monitor the device with tegrastats to see if the GPU resources are fully utilized?
I am using similar codes used in this repo…What will be the reason cause I am not using TensorRT with FP16 mode??
GPU is not used by the system after I check status GPU was at 0% use
