Hello, I’m working on a camera project with the following setup:
- Jetson Nano b01 module
- Custom carrier
- Single CSI camera
I’m developing for Jetpack 4.5 and have had the following behavior:
- RAW frame capture with v4l2-ctl is possible and works as expected.
- Attempted capture with nvarguscamerasrc produces error and causes board reboot.
- Attempted capture with nvarguscamerasrc causes driver to start executing constant power on/off sequences on the camera.
The pipeline I’m using to capture with nvarguscamerasrc is:
GST_DEBUG=2,*nvarguscamerasrc*:9 gst-launch-1.0 -e nvarguscamerasrc num-buffers=10 sensor-id=0 ! "video/x-raw(memory:NVMM),width=2840,height=2840,format=NV12,framerate=43/1" ! nvvidconv ! "video/x-raw" ! identity silent=false ! fakesink silent=false -v
The gstreamer log shows:
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
0:00:04.886367335 7551 0x559b11bca0 DEBUG nvarguscamerasrc gstnvarguscamerasrc.cpp:1311:gst_nv_argus_camera_set_caps:<nvarguscamerasrc0> Received caps video/x- raw(memory:NVMM), width=(int)2840, height=(int)2840, format=(string)NV12, framerate=(fraction)43/1
/GstPipeline:pipeline0/GstIdentity:identity0: last-message = event ******* (identity0:sink) E (type: stream-start (10254), GstEventStreamStart, stream-id=(string)0b005d52adc96adbba7e610bf954e53e, flags=(GstStreamFlags)GST_STREAM_FLAG_NONE, group-id=(uint)1;) 0x559b126110
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = event ******* (fakesink0:sink) E (type: stream-start (10254), GstEventStreamStart, stream-id=(string)0b005d52adc96adbba7e610bf954e53e, flags=(GstStreamFlags)GST_STREAM_FLAG_NONE, group-id=(uint)1;) 0x559b126110
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)2840, height=(int)2840, format=(string)NV12, framerate=(fraction)43/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)2840, height=(int)2840, format=(string)NV12, framerate=(fraction)43/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw, width=(int)2840, height=(int)2840, framerate=(fraction)43/1, format=(string)NV12
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-raw, width=(int)2840, height=(int)2840, framerate=(fraction)43/1, format=(string)NV12
/GstPipeline:pipeline0/GstIdentity:identity0: last-message = event ******* (identity0:sink) E (type: caps (12814), GstEventCaps, caps=(GstCaps)"video/x-raw\,\ width\=\(int\)2840\,\ height\=\(int\)2840\,\ framerate\=\(fraction\)43/1\,\ format\=\(string\)NV12";) 0x559b1262d0
/GstPipeline:pipeline0/GstIdentity:identity0.GstPad:src: caps = video/x-raw, width=(int)2840, height=(int)2840, framerate=(fraction)43/1, format=(string)NV12
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = event ******* (fakesink0:sink) E (type: caps (12814), GstEventCaps, caps=(GstCaps)"video/x-raw\,\ width\=\(int\)2840\,\ height\=\(int\)2840\,\ framerate\=\(fraction\)43/1\,\ format\=\(string\)NV12";) 0x559b126340
/GstPipeline:pipeline0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-raw, width=(int)2840, height=(int)2840, framerate=(fraction)43/1, format=(string)NV12
/GstPipeline:pipeline0/GstIdentity:identity0.GstPad:sink: caps = video/x-raw, width=(int)2840, height=(int)2840, framerate=(fraction)43/1, format=(string)NV12
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw, width=(int)2840, height=(int)2840, framerate=(fraction)43/1, format=(string)NV12
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)2840, height=(int)2840, format=(string)NV12, framerate=(fraction)43/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)2840, height=(int)2840, format=(string)NV12, framerate=(fraction)43/1
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 2840 x 2840 FR = 43,000000 fps Duration = 23255814 ; Analog Gain range min 0,062500, max 63,937500; Exposure Range min 25000, max 683709000;
GST_ARGUS: 1420 x 1420 FR = 81,000000 fps Duration = 12345679 ; Analog Gain range min 0,062500, max 63,937500; Exposure Range min 25000, max 683709000;
GST_ARGUS: 1920 x 1088 FR = 106,000003 fps Duration = 9433962 ; Analog Gain range min 0,062500, max 63,937500; Exposure Range min 25000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 2840 H = 2840
seconds to Run = 0
Frame Rate = 43,000000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD... Exiting...
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: CANCELLED
Additional debug info:
Argus Error Status
EOS on shutdown enabled -- waiting for EOS after Error
Waiting for EOS...
0:00:16.914390128 7551 0x7f90003450 DEBUG nvarguscamerasrc
gstnvarguscamerasrc.cpp:1596:consumer_thread:<nvarguscamerasrc0> consumer_thread: stop_requested=1
(gst-launch-1.0:7551): GStreamer-CRITICAL **: 17:24:15.075: gst_mini_object_set_qdata: assertion 'object != NULL' failed
/GstPipeline:pipeline0/GstIdentity:identity0: last-message = event ******* (identity0:sink) E (type: eos (28174), ) 0x7f90004800
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = event ******* (fakesink0:sink) E (type: eos (28174), ) 0x7f90004800
The nvargus-daemon log shows:
=== NVIDIA Libargus Camera Service (0.97.3)=== Listening for connections...
=== gst-launch-1.0[8087]: Connection established (7F984611D0)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: No override file found. ----
LSC: LSC surface is not based on full res!
=== gst-launch-1.0[8087]: CameraProvider initialized (0x7f909365f0)LSC: LSC surface is not based on full res!
NvIspAfConfigParamsSanityCheck: Error: positionWorkingHigh is not larger than positionWorkingLow positionWorkingHigh = 0, positionWorkingLow = 0
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
SCF: Error Timeout: ISP Stats timed out! (in src/services/capture/NvIspHw.cpp, function waitIspStatsFinished(), line 566)
SCF: Error Timeout: ISP port 0 timed out! (in src/services/capture/NvIspHw.cpp, function waitIspFrameEnd(), line 478)
SCF: Error Timeout: (propagating from src/services/capture/NvIspHw.cpp, function waitIspFrameEnd(), line 524)
SCF: Error Timeout: (propagating from src/common/Utils.cpp, function workerThread(), line 116)
SCF: Error Timeout: Worker thread IspHw frameComplete failed (in src/common/Utils.cpp, function workerThread(), line 133)
These are the logs up until the carrier board reboots. If any other logs are needed, please let me know
Jafeth García
