Jetson nano r32.2.1 PARTUUID not working while booting from USB
OK, I just tried the same thing with a clean/imaged sdcard and and a USB drive yes, it’s broken.
Here’s why…
Although the usb driver is built into the kernel, the firmware is not. Unfortunately, it’s also not in the initrd image so by the time the root filesystem gets mounted, the usb controller isn’t initialized so /dev/sda isn’t available. In this case, the earlier “root=” command line parameter takes effect and is used. Once that filesystem is mounted, /lib/firmware/tegra21x_xusb_firmware becomes available and the usb controller initializes and adds /dev/sda. By that time it’s too late of course.
Here’s how you fix it WITHOUT HAVING TO COMPILE YOUR OWN KERNEL (or anything else).
Boot to the sdcard then…
# cd /etc/initramfs-tools/hooks
Create a new file “usb-firmware” with the following contents:
if [ "$1" = "prereqs" ]; then exit 0; fi
. /usr/share/initramfs-tools/hook-functions
copy_file firmware /lib/firmware/tegra21x_xusb_firmware
Make the file executable
# chmod a+x usb-firmware
That causes the mkinitramfs process to include the firmware in the image.
Regenerate the initrd:
# mkinitramfs -o /boot/initrd-xusb.img
There’ll be some warnings but don’t worry about them.
Make sure it worked.
# lsinitramfs /boot/initrd-xusb.img | grep xusb
Now edit your /boot/extlinux/extlinux.conf file and update the INITRD line to point to /boot/initrd-xusb.img
LABEL primary
      MENU LABEL primary kernel
      LINUX /boot/Image
      INITRD /boot/initrd-xusb.img
      APPEND ${cbootargs} root=UUID=<your sda1 uuid> rootwait rootfstype=ext4
Reboot and enjoy.
Don’t forget to copy the usb-firmware script to /etc/initramfs-tools on /dev/sda1.
EDIT:
Oh yeah… The reason I didn’t notice this earlier is that I use a Fedora root filesystem :)
