SD card reader failing, trying to boot from USB
No problem booting, then it failed to boot, just came up with the Jetson flash screen.
Tried a number of SD cards and got the same.
Used balenaEtcher to burn sd-blob.img to 1TB USB hard drive and changed primary boot device in extlinux.conf to
root=UUID=5cfbe20f-1ee9-40d7-a9b3-4624a787e31a
On Linux x86_64 /dev/sde1: UUID=“5cfbe20f-1ee9-40d7-a9b3-4624a787e31a” BLOCK_SIZE=“4096” TYPE=“ext4” PARTLABEL=“APP” PARTUUID=“7f5794e5-20cd-4c58-99d7-1ef8c6d7a8d4”
After the boot went through about 20 cycles, it then came up with can’t find UUID 5cfbe20f-1ee9-40d7-a9b3-4624a787e31a, then USB 1-3-2 not accepting addresses.`
Same when using the PARTUUID.
Can you please dump the serial console log during booting here?
How long is the interval between each boot attempt?
