Hey Dusty, thanks so much for the quick reply. I’ve tried running the ros:humble-pytorch container you’ve mentioned and using this command ros2 launch ros_deep_learning video_viewer.ros2.launch input:=v4l2:///dev/video0
. This runs well and spits out the following text:
[INFO] [launch]: Default logging verbosity is set to INFO
[INFO] [video_source-1]: process started with pid [140]
[INFO] [video_output-2]: process started with pid [141]
[video_output-2] [INFO] [1706232782.492688042] [video_output]: opening video output: display://0
[video_output-2] [ERROR] [1706232782.493367365] [video_output]: failed to open video output
[video_source-1] [INFO] [1706232782.496821219] [video_source]: opening video source: v4l2:///dev/video0
[video_output-2] [OpenGL] failed to open X11 server connection.
[video_output-2] [OpenGL] failed to create X11 Window.
[INFO] [video_output-2]: process has finished cleanly [pid 141]
[video_output-2]
[video_source-1] [gstreamer] initialized gstreamer, version 1.14.5.0
[video_source-1] [gstreamer] gstCamera -- attempting to create device v4l2:///dev/video0
[video_source-1] [gstreamer] gstCamera -- found v4l2 device: UVC Camera (046d:081d)
[video_source-1] [gstreamer] v4l2-proplist, device.path=(string)/dev/video0, udev-probed=(boolean)false, device.api=(string)v4l2, v4l2.device.driver=(string)uvcvideo, v4l2.device.card=(string)"UVC\ Camera\ \(046d:081d\)", v4l2.device.bus_info=(string)usb-70090000.xusb-2.3, v4l2.device.version=(uint)264703, v4l2.device.capabilities=(uint)2216689665, v4l2.device.device_caps=(uint)69206017;
[video_source-1] [gstreamer] gstCamera -- found 48 caps for v4l2 device /dev/video0
[video_source-1] [gstreamer] [0] video/x-raw, format=(string)YUY2, width=(int)1600, height=(int)1200, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)5/1;
[video_source-1] [gstreamer] [1] video/x-raw, format=(string)YUY2, width=(int)1600, height=(int)896, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/2, 5/1 };
[video_source-1] [gstreamer] [2] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)1024, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/2, 5/1 };
[video_source-1] [gstreamer] [3] video/x-raw, format=(string)YUY2, width=(int)1504, height=(int)832, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/2, 5/1 };
[video_source-1] [gstreamer] [4] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)960, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/2, 5/1 };
[video_source-1] [gstreamer] [5] video/x-raw, format=(string)YUY2, width=(int)1392, height=(int)768, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [6] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [7] video/x-raw, format=(string)YUY2, width=(int)1184, height=(int)656, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [8] video/x-raw, format=(string)YUY2, width=(int)960, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [9] video/x-raw, format=(string)YUY2, width=(int)1024, height=(int)576, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [10] video/x-raw, format=(string)YUY2, width=(int)960, height=(int)544, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [11] video/x-raw, format=(string)YUY2, width=(int)800, height=(int)600, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [12] video/x-raw, format=(string)YUY2, width=(int)864, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [13] video/x-raw, format=(string)YUY2, width=(int)800, height=(int)448, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [14] video/x-raw, format=(string)YUY2, width=(int)752, height=(int)416, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [15] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [16] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [17] video/x-raw, format=(string)YUY2, width=(int)544, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [18] video/x-raw, format=(string)YUY2, width=(int)432, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [19] video/x-raw, format=(string)YUY2, width=(int)352, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [20] video/x-raw, format=(string)YUY2, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [21] video/x-raw, format=(string)YUY2, width=(int)320, height=(int)176, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [22] video/x-raw, format=(string)YUY2, width=(int)176, height=(int)144, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [23] video/x-raw, format=(string)YUY2, width=(int)160, height=(int)120, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [24] image/jpeg, width=(int)1600, height=(int)1200, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [25] image/jpeg, width=(int)1600, height=(int)896, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [26] image/jpeg, width=(int)1280, height=(int)1024, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [27] image/jpeg, width=(int)1504, height=(int)832, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [28] image/jpeg, width=(int)1280, height=(int)960, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [29] image/jpeg, width=(int)1392, height=(int)768, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [30] image/jpeg, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [31] image/jpeg, width=(int)1184, height=(int)656, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [32] image/jpeg, width=(int)960, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [33] image/jpeg, width=(int)1024, height=(int)576, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [34] image/jpeg, width=(int)960, height=(int)544, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [35] image/jpeg, width=(int)800, height=(int)600, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [36] image/jpeg, width=(int)864, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [37] image/jpeg, width=(int)800, height=(int)448, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [38] image/jpeg, width=(int)752, height=(int)416, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [39] image/jpeg, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [40] image/jpeg, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [41] image/jpeg, width=(int)544, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [42] image/jpeg, width=(int)432, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [43] image/jpeg, width=(int)352, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [gstreamer] [44] image/jpeg, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
[video_source-1] [INFO] [1706232783.321445646] [video_source]: allocated CUDA memory for 1280x720 image conversion
This also creates a ros topic, /video_source/raw
. I then try to view this topic on both rqt and rviz, which both allow me to subscribe but only show a blank screen, pushing this error to the terminal:
[rqt_gui_cpp_node_6279]: [image_transport] It looks like you are trying to subscribe directly to a transport-specific image topic '/video_source/raw', in which case you will likely get a connection error. Try subscribing to the base topic '/video_source' instead with parameter ~image_transport set to 'raw' (on the command line, _image_transport:=raw). See http://ros.org/wiki/image_transport for details.
I’ve tried messing around with this today, but I can’t seem to make it work. I know that you recommended the video_output
node, but I can’t figure out how to get this to push to a ros topic. I need to use rviz or rqt for my application, so (I believe) I need the image data to be published from a topic.
Is there any advice you can give? This may be a very simple problem but I can’t seem to figure it out.
