As I see PKC is still disabled. What did I do wrong?
If I skip the device restart and try to flash the device right after burning the fuses I get the following error message: sudo ./flash.sh -x 0x21 -y PKC -u ../nano_priv.pem jetson-nano-qspi-sd mmcblk0p1
# L4T BSP Information:# R32 , REVISION: 3.1
Error: probing the target board failed.
Make sure the target board is connected through
USB port and is in recovery mode.
If I reset the device in recovery mode between burning the fuses and flashing the device I get the following error message:
*** The fuse configuration is saved in bootloader/odmfuse_pkc.xml
*** The ODM fuse has been secured with PKC keys.
*** Flash "signed BCT and bootloader(s)".
*** done.
Then I restarted the device to check if it was going to refuse to boot (because I haven’t uploaded a signed image at that time so it contained an unsigned one), but it started without error. Then I ran sudo ./tegrafuse.sh (on the device) and I got the followings:
It is really sad because (as far as I know) I can not change the pkc_disable fuse anymore. Could you help me what happened? I explicitly told odmfuse to use PKC (-c PKC) and provided the key (-k …/nano_priv.pem), pkc_disable should be 0x0. What did I do wrong?
The fuse bit is irreversible. The following is from README_secureboot.txt:
Tegra devices contain multiple fuses that control different items for
security and boot. Programming a fuse, such as changing a value of a
fuse bit from 0 to 1, is non-reversible. Once a fuse bit is programmed
by setting to 1, you cannot change the fuse value from 1 to 0.
For example, a value of 1(0x01) can be changed to 3(0x03) or 5(0x5),
but not to 4(0x4) because the bit 0 is already programmed to 1.
Yes, I know that it is irreversible, but could you tell me what was my mistake? If I try the same command on a different board the outcome will be the same.
Before I ran the command odm_production_mode was 0x0 (the dev board was right out of the box).
Then I ran the command (with the production flag):
