Hi everyone,
We want to improve the rtsp stream latency with the before topic:
Hi everyone, We are developing the webcam streaming with rtsp server on Jetson Nano, when we use the vlc (PC client) to connect the server, we get connection fail with the error message in Nano (rtsp server). 0:06:44.760563336 9974 0x5589b321e0 ERROR rtspclient rtsp-client.c:2651:handle_setup_request: client 0x5589d04220: no control in path '/test’ Install gstreamer rtsp server with command: sudo apt-get install libgstrtspserver-1.0 And git clone the rtsp server example: …
We running the rtsp server with gst-rtsp-server in the Nano.
And when we use the client player (VLC) with wired to connect the rtsp server, the client player will get 800ms latency. Could you have any advice to improve the latency?
Nano side command: ./test-launch v4l2src device=/dev/video1 ! “video/x-raw, width=640, height=480, format=(string)YUY2” ! queue ! nvvidconv ! “video/x-raw(memory:NVMM), width=640, height=480, format=(string)NV12” ! nvv4l2h264enc bitrate=912000 ! ‘video/x-h264, stream-format=(string)byte-stream’ ! rtph264pay name=pay0 pt=96
On Jetson Nano, please run sudo jetson_clocks and set the property in nvv4l2h264enc :
maxperf-enable : Enable or Disable Max Performance mode
flags: readable, writable, changeable only in NULL or READY state
Boolean. Default: false
And some latency is from source, you may refer to the post:
and check glass-to-glass latency of the v4l2 source.
