When the Jetson Nano is connected to power, it does not boot and nothing is displayed on the monitor.
I need help
The message from the debug console is:
[0000.130] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.138] Power-up reason: pmc por
[0000.141] No Battery Present
[0000.144] pmic max77620 reset reason
[0000.147] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 0
[0000.153] Platform has DDR4 type RAM
[0000.156] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x2a116d
[0000.172] Entering ramdump check
[0000.175] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.188] Sdram initialization is successful
[0000.192] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.204] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.210] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.269] BoardID = 3448, SKU = 0x0
[0000.272] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.276] Nano-SD: checking PT table on QSPI ...
[0000.281] Read PT from (2:0)
[0000.296] Using BFS PT to query partitions
[0000.302] Loading Tboot-CPU binary
[0000.330] Verifying TBC in OdmNonSecureSBK mode
[0000.340] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.347] Bootloader downloaded successfully.
[0000.351] Downloaded Tboot-CPU binary to 0xa0000258
[0000.356] MAX77620_GPIO5 configured
[0000.359] CPU power rail is up
[0000.362] CPU clock enabled
[0000.366] Performing RAM repair
[0000.369] Updating A64 Warmreset Address to 0xa00002e9
[0000.374] BoardID = 3448, SKU = 0x0
[0000.377] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.381] Nano-SD: checking PT table on QSPI ...
[0000.385] Loading NvTbootBootloaderDTB
[0000.452] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.523] Bootloader DTB Load Address: 0x83000000
[0000.528] BoardID = 3448, SKU = 0x0
[0000.531] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.535] Nano-SD: checking PT table on QSPI ...
[0000.540] Loading NvTbootKernelDTB
[0000.606] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.679] Kernel DTB Load Address: 0x83100000
[0000.683] BoardID = 3448, SKU = 0x0
[0000.686] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.690] Nano-SD: checking PT table on QSPI ...
[0000.696] Loading cboot binary
[0000.812] Verifying EBT in OdmNonSecureSBK mode
[0000.854] Bootloader is corrupted!
[0000.857] Error in NvTbootLoadBinary: 0x14 !
[0000.861] BoardID = 3448, SKU = 0x0
[0000.864] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.868] Nano-SD: checking PT table on QSPI ...
[0000.873] PT: Partition RBL NOT found !
[0000.876] Warning: Find Partition via PT Failed
[0000.881] Error is 1
