Jetson NVENC Spatial AQ
Hi, is it possible to enable Spatial AQ for Jetson/NVENC?
For the desktop API can use:
NV_ENC_INITIALIZE_PARAMS::encodeconfig->rcParams. enableAQ
NV_ENC_INITIALIZE_PARAMS::encodeconfig->rcParams.aqStrength
//Henrik
The parameters are not supported on Jetson platforms. The paramters of external rate control is different. For further information, please check populate_ext_rate_ctrl_Param() in the sample:
/usr/src/jetson_multimedia_api/samples/01_video_encode
Hi, thanks for the quick response. I found this topic where it is mentioned that you are working on unifying dGPU and Jetson interfaces. Will Spatial AQ be available later on? If so, do you have an estimation of when?
//Henrik
I’m also interested in the follow-up question by Henrik; is there a time frame for when the NVENC APIs will be the single software stack for both desktop and Jetson? And will the feature set be the same, like e.g. Spatial AQ?
For Jetson Orin series, we will not have new parameters. We will evaluate it for Jetson Thor.
