I’m trying to connect Raspberry Pi V2.1 camera (IMX219) to Jetson NX CSI-B port on custom carrier board. It seems, camera is detected but can’t get video from it. When I try gst-launch I got:
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:557 No cameras available
May I ask to review my media0 topology? Device tree and dmesg attached for reference.
Media controller API version 0.1.0
Media device information
driver tegra194-vi5
model NVIDIA Tegra Video Input Device
serial
bus info
hw revision 0x3
driver version 0.0.0
Device topology
- entity 1: imx219 1-0010 (1 pad, 1 link)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev0
pad0: Source
[fmt:SRGGB10_1X10/3264x2464 field:none colorspace:srgb]
-> "15a00000.nvcsi--1":0 [ENABLED]
- entity 3: 15a00000.nvcsi--1 (2 pads, 2 links)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev1
pad0: Sink
<- "imx219 1-0010":0 [ENABLED]
pad1: Source
-> "vi-output, imx219 1-0010":0 [ENABLED]
- entity 6: vi-output, imx219 1-0010 (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
<- "15a00000.nvcsi--1":1 [ENABLED]
Thank you for reply. I changed devname, but still got the same error. I test using this pipeline:
jetson@jetson:~$ gst-launch-1.0 -e nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=1920, height=1080, framerate=30/1' ! nvv4l2h264enc bitrate=8000000 insert-sps-pps=true ! h264parse ! mpegtsmux ! filesink location=test.vid
Setting pipeline to PAUSED ...
Opening in BLOCKING MODE
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Redistribute latency...
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
Got EOS from element "pipeline0".
Execution ended after 0:00:00.119911869
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
which worked on different carrier board, but there is camera on CSI0.
Could you take a look at vi->nvcsi->sensor ‘wiring’? Does it look correct for you? I paid attention to port-index and tegra-sinterface to set to CSI B. On my eye all looks good, but maybe I made a mistake with nvcsi or vi section?
Sensor settings I basically copied from DevKit DT.
